About the tool box bracket on Panhead frames - The Jockey Journal Board
Old 07-19-2020, 12:32 PM   #1
shoveljp
shoveljp's Avatar
Default About the tool box bracket on Panhead frames
hi guys
i am actually looking for buying a 52 Panhead. The seller says it is original frame , and i am waiting the pics of forging numbers.but I have noticed i could not see on the frame the usual welded tool box bracket welded between the upper and lower parts on the rigid frame; Who can tell me when that bracket disappeared , just to to be changed for the smaller one only welded on the lower part of the frame? thanks
Freedom is when you choose your chains
shoveljp is offline   Reply With Quote
Old 07-19-2020, 12:44 PM   #2
HD48FL
Default Re: About the tool box bracket on Panhead frames
1952 used the smaller bracket that you're describing.
Old 07-19-2020, 12:57 PM   #3
HD48FL
Not trying to push anything with this, but you might benefit greatly from having a copy of the third edition of Palmer's "How to Restore Your Harley-Davidson":
http://www.howtorestoreyourharleydavidson.com
Old 07-19-2020, 01:25 PM   #4
shoveljp
shoveljp's Avatar
Yes for sure , i have ordered it and it is on the way to home !
Old 07-20-2020, 01:44 AM   #5
Speeding Big Twin
The new-for-52 toolbox bracket was recorded on at least one Harley drawing and the copy I have is dated 8-22-51. Hereís a close-up of the bracket from that drawing.
Also introduced for 52 models was a new top engine mount but if itís a real 52 frame then the top mount wonít have a date code. The date code came later and its addition was recorded on the drawing on 1-5-53.
Something else to check for 52 is the front engine mount. It may have been unique to that model year although itís possible some late-51s also had it. (As of 53 the front mount changed again.)
Eric
Speeding Big Twin is offline   Reply With Quote
