Thread Tools | Search this Thread | Display Modes |
#161 |
Sponsored Links | |||
#162 |
Mod Squad
#163 |
Well, the weather's been shit (working under a tin roof outside), but I did make some progress on my customized 2.2 gal. Mustang tank a few weeks ago.
Made a small dash out of some 18 gauge for the speedo I frenched into the tank (wiring runs inside the tank): ![]() Did some more metal finishing on the lead work on my extended tunnel and welded some nuts inside to mount the coil: ![]() Finished the lead on the recessed front mount: ![]() Rear mount to peak transition: ![]() |
#164 |
I put this in my build thread but what the hell its pretty cool, made with me own two hands for the cost of free scrap from work.
Home made oil filter adapter, using the same oil filter as my Buell. ![]() ![]() |
#165 |
I might as well post some pictures on my oiltank build.
Making the both sides in the tree stump whit my ball hammer and the e-wheel: ![]() ![]() Mock up after welding it together and a lot of grinding: ![]() ![]() The final pice, after I nickel plated it and fucked up, did a dee chrome, and one more nickel plating: ![]() |
#166 |
#167 |
The starter snout for my LSR sidecar.
![]() The sidecar. Nearly there. ![]()
El Mirage record 500 APS/PG 129.817 mph El Mirage record 500 SC/PG 122.240 mph El Mirage record 500 SC/PF 120.157 mph Bonneville record 500 SC/PG 119.667 mph Bonneville record 500 SC/PF 117.186 mph Bonneville record 500 SC/PBG 111.494 mph Bonneville record 500 SC/PBF 112.717 mph Bonneville record 650 SC/PF 128.703 mph Bonneville record 650 SC/PG 121.553 mph El Mirage record 650 SC/PG 130.224 mph Last edited by Hoofhearted; 03-15-2009 at 11:38 PM. |
#168 |
#169 |
The "Tiki Pan" gas tank
#170 |
here's a few from the last bike.
shovel front rod brake pedal, brass foot board... ![]() rock shift knob... ![]() old ford tail light mounted on a hunk of crash bar tube... ![]() oliver tractor headlight... ![]() and here's one from the past. steel tube plumbing, filter behind trans that also mounts risers and cut buck horn bar turned to rear pegs... ![]() |
#171 |
Some bars I made for an old Sportster...
http://speedshifters.blogspot.com/ www.speedshifters15.com www.britironrebels.com |
#172 |
Headlight Mount
![]() Yeah I know It looks like a miniature toilet. |
#173 |
Frame mount remote me working on:
#174 |
How bout some cast gas caps
#175 |
I live in Africa so I have to make my own!!! Couldn't figure what ratio so I m
#176 |
from my build. . . made the mid controls, right hand jockey shift, round electric box and end caps, and the battery box.
#177 |
other side of motor
#178 |
My contoured dome nut on my springer.
#179 |
Got the starter for the sidecar done. It works fantastic. Cranks the engine no problem.
![]() I was so happy with the starter I made a dolly to wheel it around El Mirage. ![]()
El Mirage record 500 APS/PG 129.817 mph El Mirage record 500 SC/PG 122.240 mph El Mirage record 500 SC/PF 120.157 mph Bonneville record 500 SC/PG 119.667 mph Bonneville record 500 SC/PF 117.186 mph Bonneville record 500 SC/PBG 111.494 mph Bonneville record 500 SC/PBF 112.717 mph Bonneville record 650 SC/PF 128.703 mph Bonneville record 650 SC/PG 121.553 mph El Mirage record 650 SC/PG 130.224 mph Last edited by Hoofhearted; 04-21-2009 at 10:04 PM. |
#180 |
Axle plates with 'trick' chain adjusters.
From this: ![]() ![]() ![]() To this: ![]() About ten months between the two versions. |
Display Modes | |
