Thread Tools | Search this Thread | Display Modes |
#101 |
How about in-process fabrication?
Sponsored Links | |||
#102 |
i built my swingarm to house a 17x6.00 wheel with a 200mm tire,and was dead set against making an frame mods.i pulled it off like this.
milled these axle plates out of a chunk of steel i have been using as a press plate in my press.took about 23 hours on my little mill. ![]() workin on shock placement. ![]() done and painted,for now. ![]() leon |
#103 |
I made this tray on an Armstrong metal brake - you know, my welding table, a big piece of angle iron, two clamps, and two strong arms.
#104 |
Figured I'd post some pictures of the hidden axle blocks I made.
Here's what the real thing looks like, usually CNC machined out of steel. ![]() Basically they are axle blocks that have a plate covering the axle, so they're called hidden axle blocks. My version: ![]() cut the 1.5" inner diameter piping in half ![]() space the two sections apart using 1.5" pieces ![]() Bevel all the edges and weld it up then grind them smooth ![]() now do the other side ![]() I had some spare aluminum from building my last intake manifold, so i used that for the covers ![]() to attach them I made some little tabs to go on the inside, welded a nut to the backside. and countersunk the holes in the cover for the screws ![]() ![]() ![]() |
#105 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks for looking Sky |
#106 |
Gawd almighty, there some mindblowing'ly
formidable stuff here ! Unfortunately my own welding capabilities are slightly less than those of a piss-drunk child, so I leave that to others. Generally I enjoy doing the things that most people dislike and find tedious. Like doing multi-carbs : ![]() and the VERY small details: ![]() Vargas girl printed , cut out and covered with several layers of clear-coat, used as Volt-meter needle. ![]() Micro-fabrication one might call it...ha ha. That all pales compared to what I see here in this thread. RESPECT ! Last edited by octane98; 06-15-2008 at 07:32 AM. |
#107 |
#108 |
Thread whore Bump
#109 |
The jockey shift I toiled over to get it right. Works awesome and I think it looks sharp.
#110 |
Some things from my bike; SS shifter bracket w/sealed bearing, aluminum mounts for oil tank and sissy bar from 1/2" SS round stock. Have to size a few more pics , post them later.
The 9 most terrifying words in the English language are, I'm from the government and I'm here to help. Reagan |
#111 |
#112 |
My new oil tank/mount.
Give me the machines and I'll build you an Empire. Authorized AMSOIL Dealer - http://lubedealer.com/topsynthetics/home.aspx |
#113 |
...and my pinned kicker.... So I can spin it around so its not in the way of my leg on my mids.
#114 |
Well it's not my bike but here is the seat I made for my brothers 1970 Triumph.
#115 |
Here are some pics on my tank attempt.
#116 |
Here is a couple things I did to adapt a pre70 rear wheel to a 5 speed left hand shift motor... also a custom top motor mount, the frame was a GME or so I was told...
#117 |
my head light mount and shaved trees
![]() ![]() ![]() Last edited by big_b; 10-23-2008 at 10:55 PM. Reason: learned how to post pics properly,, thanks dragon |
#118 |
Here is some rod brackets that I made for me bike.
![]() They're 1/4" S.S. kinda a pain to get them to come out the same. |
#119 |
Here is another
![]() There are more here. https://www.jockeyjournal.com/forum/s...ighlight=nigel And yes, it starts on the second kick everytime, and pulls hard all the way through the throttle |
#120 |
Here's what ive got to add to this post. Nothing as cool as what ive seen so far.
My bars and headlight hole fillers ![]() Foot rest and key mount ![]() Tail light ![]() My im to lazy to weld it to the frame tag bracket/mount ![]() |
Display Modes | |
