Lets see some details and fabrication on your bike..... - Page 5 - The Jockey Journal Board
Old 01-07-2008, 08:55 AM   #81
HOT40ROD
HOT40ROD's Avatar
Default Re: Lets see some details and fabrication on your bike.....
Not a very good picture of the sportster but it has a 40 degree on the neck and the swing arm is 4 inches longer.
The plate is on my 2004 Harley. The eyes in the skull light up with the brakes.
and the picture to the left is the air cleaner on the same Harley
Name:	84 sportster4.jpg
ID:	24024   Click image for larger version
HOT40ROD is offline   Reply With Quote
Old 01-07-2008, 09:01 AM   #82
Ed
TI_Tuesday
Ed's Avatar
was farting around with the crappy stock sporty brake pedal last night:
done:
Ed is offline   Reply With Quote
Old 01-07-2008, 09:05 AM   #83
Kuda
Kuda's Avatar
done:
That's bad-ass low buck cool, the best kind: making way cool stuff on the cheap. But a quick suggestion: if you want to clean it up even more, counter sink the peg bolt and drill and press in a pin to stop it from rotating, so you can lose the star washer. Wait. This is you. You probably already had your own plan, didn't you? Never mind... :-)
-Kuda
'49 panchop (finally starting reassembly this w/e)
Kuda is offline   Reply With Quote
Old 01-09-2008, 12:12 PM   #84
front st cycle
front st cycle's Avatar
I going to run a rear disk brake on my '70 right side shift Sportster. This is the beginning...
Stock EVO pedal(rt side brake)
cut up pedal
left one is the "new" one right is the stock EVO
weld on the "new" left side brake pedal.
ID:	24108   Click image for larger version
ID:	24109   Click image for larger version
front st cycle is offline   Reply With Quote
Old 01-09-2008, 02:30 PM   #85
hellsheros
hellsheros's Avatar
my first try at this burned a huge hole in the front of the tank so i had to cut it out and make a patch panel for the front will post more pic when done.
hellsheros is offline   Reply With Quote
Old 01-09-2008, 03:01 PM   #86
Ea$y
Originally Posted by Glen View Post
Trying to keep this post live,
ya....the center bolt sucks, the cool industrial hardware store was closed today
where are the rockershafts on this motor?Is it an S&S thing?
"Support America shoot a politician."
Ea$y is offline   Reply With Quote
Old 02-13-2008, 10:30 PM   #87
crebo
crebo's Avatar
that seat is sweet, attached is my evo build so far... your seat makes mine look like humpty dumpy's... But, i did cut it out of 10 guage steel with an angle grinder and pounded out the shape myself....
crebo is offline   Reply With Quote
Old 02-18-2008, 07:57 PM   #88
crebo
crebo's Avatar
This is an oil tank bracket I made with an angle grinder and 1/4" thick 6061 aluminum square tube. just need to finish sand them... Took forever to hack em out and get them to fit!
Old 02-18-2008, 08:02 PM   #89
crebo
crebo's Avatar
fender strut with a snake climbing up the inside. I made the struts out of 1/8" steel. but they needed some support, so I welded in some round bar. Got to playing around with the grinder and it turned out looking like a small snake, will be pretty cool when its finished up...
Old 02-24-2008, 02:23 AM   #90
hellsheros
hellsheros's Avatar
almost done with my narrow sporty tank...
Old 04-19-2008, 12:59 AM   #91
chopaweeza
chopaweeza's Avatar
Send a message via Yahoo to chopaweeza Send a message via Skype™ to chopaweeza
Here's a few off a GSXR rigid i did last year. The tank started out as a smashed Kawasaki Mean Streak item. I cut out the bottom , cut 8" out of the center , beat the sides back out(5" on one side and 3" on the other) , welded it back together with an 04' GSXR750 filler , added a Z650 tap mount , made a new base & tunnel and got Neo Dutch to paint it. All out of 1.0 or 1.2mm steel. Fiddly to work with but a unique tank. I also made the bars as 1.25" that reduced to 7/8ths , modified the 02' Indian Rear Guard , made the frame and modified everything else .
chopaweeza is offline   Reply With Quote
Old 04-19-2008, 01:03 AM   #92
scottychop
Just a kickstand, but really satisfying.
scottychop is offline   Reply With Quote
Old 04-19-2008, 09:22 AM   #93
bostonmike
bostonmike's Avatar
couple of pictures from the sportster i'm building
Name:	forward control.jpg
ID:	28525   Click image for larger version
bostonmike is offline   Reply With Quote
Old 04-19-2008, 09:29 AM   #94
bostonmike
bostonmike's Avatar
i also have some shots of my brakes in progress and battery box
Name:	batterybox and master cly.JPG
ID:	28527   Click image for larger version
Old 04-19-2008, 10:16 AM   #95
Special'79
Special'79's Avatar
Some detail i'm adding to one of Craig's fenders.
My first attempt at rounding the edges of the recessed mounts on a tank.
http://www.jasonmroche.com
www.specialseventynine.blogspot.com
"You ever fire 2 guns whilst flying through the air?"
Special'79 is offline   Reply With Quote
Old 04-19-2008, 10:18 AM   #96
rodburner
Some fantastic pieces here.Very thought provoking. I made 2into1 pipes and a seat for fun and a friend with a lathe,spun out this 2-1/4" billet oil cooler on his lunch break.Works good too.
rodburner is offline   Reply With Quote
Old 04-19-2008, 12:16 PM   #97
itusedtobeaboutchoppers
itusedtobeaboutchoppers's Avatar
Nice!! Always hated giant, ugly-ass ones.. thats pretty cool. Could mount it anywhere.. good work.
"Metal damage, brain damage, you should see the damage, Bronze...." - Nightrider
Facebook: http://www.facebook.com/pages/Rigid-...90?ref=tn_tnmn
itusedtobeaboutchoppers is offline   Reply With Quote
Old 04-20-2008, 12:49 PM   #98
Rover
Tailight made form 5 horse briggs piston and con-rod I got from the dump.
Rover is offline   Reply With Quote
Old 04-21-2008, 12:55 PM   #99
Special'79
Special'79's Avatar
A couple more shots of the ongoing project. Not the actual tank that's going on it, my tank is being molded & primed.
Old 04-21-2008, 02:56 PM   #100
Adams77
Adams77's Avatar
Copper
Neat metal to work with
Here are some velocity stacks I have made.
Adams77 is offline   Reply With Quote
