Thread Tools | Search this Thread | Display Modes |
#61 |
now you see it, now you dont...
Sponsored Links | |||
#62 |
"build'em light and wind'em tight" Last edited by Blacksmithbilly; 12-25-2009 at 03:21 PM. Reason: repaired moved file |
#63 |
Dam how could i forget about your Girder. That is bad ass. If I get this XS rolling by spring i may have to make a roadtrip and see that in person. Nice!
#64 |
I used several thicknesses of steel wool w/water and just kept going round and round. thicker wool to take off the big stufff, thinner to get rid of the scratches. 1000 grit sand paper with water to finish. trick was to keep going round and round otherwise youll see the scratches and it wont flow well
#65 |
I ended replacing my 550lb springs on my cheap chinese shocks with the following springs from http://www.mcmaster.com/
1 96485K138 SPRING-TEMPERED STL JUMBO COMPRESSION SPRING, 3" LENGTH, 1.937" OD, .25" WIRE DIAMETER 2 EA 2 0 11.77 They are a little longer and slightly wider inside diameter, but they hooked up just fine. Still a little harsh, but way better than the 550lb springs. I wont be able to tell how good the setup works until I get the bike together and can ride it. |
#66 |
hand made seat mount bracket
#67 |
rebar fender strut
#68 |
I made my upper mount up to look like two small hammers..... sorry for the ugly center bolt, this is an older pic.
#69 |
Points cover....
#70 |
Speedball tank emblem and homemade matching point cover..
#71 |
HERE'S MY OIL BAG MADE OUT OF A FIRE EXTINGUISHER WITH A BATTERY BOX.
![]() ![]() CONTROLS I MADE WITH A MAIN SHAFT TRANNY BEARING IN IT. ![]() ![]() |
#72 |
The bee hive that started the aluminum tank line and the mustang ax job.
I have an idea, someone bring me a midget. |
#73 |
Narrowed "fat bob" tank. Pie cut down the middle and added the peak.
Step-by-step tech here: http://www.crimescenechoppers.com/blog/uglytankfix/ ![]() |
#74 |
Someone asked about splitting rockers, these are some I did for my ironhead. I think I posted the tech here once before, but I have it on my site now too:
http://www.crimescenechoppers.com/bl...nhead_rockers/ ![]() |
#75 |
91 sporster exhaust mock up, biltwell pipe kit and some leftovers
#76 |
71-72 Triumph front end, 74-76 Sporty hub with 21" wheel. Took almost two inches off the rotor diameter. Machined the Triumph axle to have a nut on both sides. Stainless bracket for Honda caliper
#77 | ||
So the frontend that I'm usin on the Ironhead I'm buildin has had the riser holes bored out so the regular bushing kit won't work. Today at work I made these with a file, lathe, a drill bit and some urethane roundstock that was kicking around the shop. Not too bad for a one armed machinist.
YOU NEED TO CHECK THIS OUT! I'M STRONGLY SUGGESTING IT! YOU'LL BE GLAD YOU DID.... http://lowsidemag.blogspot.com/ Last edited by noodelz; 11-30-2007 at 09:21 PM. |
#78 |
shock mounts made from 1 1/4" x 1 1/4" x 1/8" square tube.
I made some earlier from flat stock, but could never get the bends just right. square tube is the way to go! |
#79 |
here is a pic of my upper motor mount i made from 1" solid round s.s. and my axle spacers/ fender strut mounts
#80 |
Display Modes | |
