Lets see some details and fabrication on your bike..... - Page 34 - The Jockey Journal Board
Old 11-01-2017, 04:07 AM   #661
richbob
richbob's Avatar
Default Re: Lets see some details and fabrication on your bike.....
yes nice solution Mojomick.
Top Job.
im in the process of doing something similar but with bottom of a steel milk jug.
Old 11-01-2017, 05:21 PM   #662
Lester
Lester's Avatar
Well done Mo!
'62 DuoGlide Mine for 25yrs
'62 Triumph T-Bird in boxes
'83 BMW R100 commuter
'52 Triumph Speed Twin Bastard
70's'80's couple of Jap chops too
Old 11-01-2017, 05:46 PM   #663
Phlogisticated
Phlogisticated's Avatar
That turned out terrific! Nice work. Beautiful result.
I especially like the "manual CNC" work in pic #4. (nibble to the line - I've done that many times myself)
Phlogisticated is offline   Reply With Quote
Old 11-02-2017, 05:37 AM   #664
Goldy
Goldy's Avatar
That's a very nice looking bit of work!
This too shall pass.
Old 03-06-2018, 07:56 PM   #665
Tim The Grim
Tim The Grim's Avatar
I want to be able to run either a tube fork or Fury Girder on my KHK chopper and I wanted internal fork stops that would work with both front ends. I turned some neck stems and then ball milled grooves that line up with two threaded holes I drilled in the steering head of the frame I put together back in ‘80. The ball radius on the screw tips rides in the grooves and gives me 32 deg. swing either side.
'54 KHK (Current Build), '13 XL72 Hard Candy, '96 Valkyrie. Retired
Tim The Grim is offline   Reply With Quote
Old 12-02-2020, 03:44 AM   #666
ditchpump
Home made gas tank, proprietary technique using fibreglass, vinylester resin and a 3D printer.
ID:	258912   Click image for larger version
ditchpump is offline   Reply With Quote
Old 12-02-2020, 05:10 AM   #667
Ducbsa
Looks good, do you have a liner in it to protect from the ethanol in the gasoline?
Old 12-02-2020, 11:07 AM   #668
ditchpump
The vinylester is supposed to be resistant to most solvents, acetone will not touch it once it's set, I know because I tried to clean up using it.
The UK only has 5% ethanol, which helps a bit too.
Old 12-02-2020, 02:54 PM   #669
Ratso
Ratso's Avatar
Ditchpump, I looked back a couple of pages but if you've posted about that frame, I missed it. Please say a little about it, or direct me to where you've already done so, if you don't mind. What engine is it meant to accommodate (just for starters)?
Thanks. The tank is swell work.
"Bite the parts like a monkey." --Dutch Dennoz
Old 12-03-2020, 06:13 AM   #670
richbob
richbob's Avatar
ratso look at his post in flat track and desert racers
Old 12-03-2020, 11:54 AM   #671
ditchpump
First time I've posted in 5 years! The frame is a Ducati Pantah, I'm building a 750 flat tracker and this one is a 900 racer.
Old 12-03-2020, 12:31 PM   #672
Ratso
Ratso's Avatar
I'd a never guessed. Thanks.
+ thanks Richbob.
Old 12-14-2020, 11:10 AM   #673
Motocrash
Motocrash's Avatar
The list of hand made/modified parts on my current ride is too long to list here but...
Here's a little sample:
My Build: Bottom Feeder
Motocrash is offline   Reply With Quote
Old 12-14-2020, 04:00 PM   #674
VonWegener
VonWegener's Avatar
Very nice!
Old 12-15-2020, 06:20 AM   #675
Ducbsa
I like your solder pot, here's mine:
Old 12-15-2020, 07:43 AM   #676
govmule84
Forum Dipshit
What are you boys using for your molds for the ends?
Old 12-15-2020, 09:10 AM   #677
Nanonevol
Originally Posted by Mojomick View Post
Here's a few shots of the front pulley cover that I made to protect my BNR primary. About 16 hours machining on the lathe and mill.
How about a photo of the whole bike? I like the reversed head.
Nanonevol is offline   Reply With Quote
Old 12-15-2020, 05:47 PM   #678
Motocrash
Motocrash's Avatar
Works just dandy!
I make mine out of appropriately sized bolts. Look closely at the pic, two drills, one through the size of the cable, next part way for flare. Dip in flux, then COB solder pot. Works like it cost $$$!
Old 12-16-2020, 10:17 AM   #679
govmule84
Forum Dipshit
OK, I follow... and then a quick dunk?
How bad is the cleanup after the dip in lead?
Old 12-16-2020, 10:23 AM   #680
richbob
richbob's Avatar
yea I've always done mine without the pot (just flux and heat direct)
