Lets see some details and fabrication on your bike..... - Page 3 - The Jockey Journal Board
Old 07-25-2007, 10:05 PM   #41
concrete guy
Default Re: Lets see some details and fabrication on your bike.....
Some things I have got done lately. Fender strut, kickstand, SS pipes, hidden M/C for clutch under tank and new flat bottom on a King Sporty tank
ID:	18851   Click image for larger version
Name:	DSC00001 (Custom).JPG
ID:	18852   Click image for larger version
Name:	DSC00007 (Custom).JPG
Name:	DSC00003 (Custom).JPG
ID:	18854   Click image for larger version
Name:	DSC00005 (Custom).JPG
ID:	18855   Click image for larger version
Name:	DSC00006 (Custom).JPG
concrete guy is offline   Reply With Quote
Old 07-25-2007, 10:36 PM   #42
Oilburner
Here's a simple thing. Guy brought me this Unity light, wanted me to somehow fill in the switch hole...
So after some thought, got out the aircraft tools, made a little stainless filler panel, and riveted it in place. Looks like it's supposed to be there, nuff said I think.
Oilburner is offline   Reply With Quote
Old 07-25-2007, 10:56 PM   #43
Built2Last
Built2Last's Avatar
Send a message via AIM to Built2Last
Seat - Pipes - Oil Tank
Name:	69shovel 021JJ.jpg
ID:	18859   Click image for larger version
Name:	69shovel 022JJ.jpg
Give me the machines and I'll build you an Empire.
Authorized AMSOIL Dealer - http://lubedealer.com/topsynthetics/home.aspx
Built2Last is offline   Reply With Quote
Old 08-05-2007, 04:03 AM   #44
Glen
Trying to keep this post live,
ya....the center bolt sucks, the cool industrial hardware store was closed today
Glen is offline   Reply With Quote
Old 08-05-2007, 06:19 AM   #45
concrete guy
Nice job there on the motor mount Glen. Did you make a jig to build it, or tack it up on the bike?
Old 08-05-2007, 12:21 PM   #46
Glen
tacked it on the bike.
Old 08-05-2007, 05:54 PM   #47
concrete guy
Same here, just curious. I put a brass spacer on mine. Got Time today to finish the battery tray. Used some #10 all thread that was lying around to mock it up. Will change it out for some smooth rod and nice fastners.
Name:	DSC00009 (Custom) (Custom).JPG
ID:	19174   Click image for larger version
Name:	DSC00007 (Custom) (Custom).JPG
ID:	19175   Click image for larger version
Name:	DSC00011 (Custom) (Custom).JPG
Name:	dsc00011_small_132[1] (Custom).jpg
Old 11-16-2007, 04:34 PM   #48
crebo
crebo's Avatar
custom made seat pan
ID:	22485   Click image for larger version
ID:	22486   Click image for larger version
crebo is offline   Reply With Quote
Old 11-16-2007, 07:39 PM   #49
jon volk
Cant chrome bondo
jon volk is offline   Reply With Quote
Old 11-16-2007, 07:40 PM   #50
jon volk
Old 11-16-2007, 09:03 PM   #51
crebo
crebo's Avatar
dont you just love duct tape! more to come as i continue on with my evo build.
Old 11-16-2007, 10:05 PM   #52
SamIyam
SamIyam's Avatar
To me... details are those SMALL things that you do yourself...
I took a bolt and made a screw out of it.
Then made a washer for it to fit in.
Then some little stands... and welded them in the frame.
Here it is bolted together.
I mean, it would be a pretty boring world if everybody built cool shit.
SamIyam is offline   Reply With Quote
Old 11-16-2007, 10:57 PM   #53
billyd
billyd's Avatar
Originally Posted by Nappy View Post
This is probably about as basic as you can get for fabbing stuff, but I'm pretty happy with the results given my lack of experience.
Took a $10 peanut from the swap and cut a piece of the 35 Ford fender that I used as the fender. I wanted to carry the ridge up over the tank, so I cut a piece about 1/2" wider than the ridge and at the bottom left enough so I could fold the fender into a point to stretch the tank (which is really dead space as I didn't cut the tank at all).
Welded the piece onto the tank. Hammer hammer, little bit of filler, and voila...
Tank is stretched into a point and has the ridge to match the fenders.
Watch out, I'm almost a Salinas Boy now.
Nice work, Nappy! Looks great.
BillyD
billyd is offline   Reply With Quote
Old 11-17-2007, 01:32 AM   #54
halwade
halwade's Avatar
Send a message via Yahoo to halwade
Oil bag brackets out of two $1 gussets and two rusty combo wrenches.
nothing earth shattering, buth they've never broken.
HalWade
Lobo Solamente
www.ChopCult.com
halwade is offline   Reply With Quote
Old 11-18-2007, 10:07 PM   #55
itusedtobeaboutchoppers
itusedtobeaboutchoppers's Avatar
Here's some stuff on the knuck I'm trying to finish.. (engine almost there!)
Cut off outer primary ear and drilled it for my elec. start, powdercoated it along w/ my r. fender (Reflecta-Chrome PC)Also cut, drilled and shaped the "scallops" on the ends of the oil tank my friend made. (It was a little too plain..)
Plasma cut and ground out this plate- taillight / remote filter mount and had it chromed.. made the frame mounts out of 3/8" rod.
Wanted to use some of Kutty's Hippy Killer shift pegs I had because the color and style matched the bike so well, but they were kinda short, so I cut some aluminum tubing down and drilled it to make some cool extensions.. they will be polished..
These are my cheapo wide glide stubbie risers to springer studs/and aluminum spacers, for the cheap "boardtracker" look, with some 19.00 drag bars I cut down..
Heres a pic from the rear... engine's supposed to be done in a week
"Metal damage, brain damage, you should see the damage, Bronze...." - Nightrider
Facebook: http://www.facebook.com/pages/Rigid-...90?ref=tn_tnmn
itusedtobeaboutchoppers is offline   Reply With Quote
Old 11-18-2007, 10:38 PM   #56
SamIyam
SamIyam's Avatar
What are those extensions for? Gonna put a P-Pad on it? With a lanky ol' lady on the back fender... those would put her knees up behind her ears! I like it!
Sam.
Old 11-18-2007, 11:04 PM   #57
LUKESTER
narrow-bob tank on my '55... finally going to get painted soon.....Luke
LUKESTER is offline   Reply With Quote
Old 11-18-2007, 11:17 PM   #58
1fastfx
1fastfx's Avatar
Those came out real cool!!!! Saved a set of 60 tanks to cut up and axe but someone came and made me an offer i couldent refuse,looking at yours i should have kept them
1fastfx is offline   Reply With Quote
Old 11-21-2007, 04:08 PM   #59
crebo
crebo's Avatar
hand made shock mount bar
ID:	22615   Click image for larger version
Old 11-21-2007, 05:29 PM   #60
Sam.
Extensions and NO P-pad are for "P-ssy emergency"... when you show them how they have to ride to your house; and they still do it; you know it's on... and the "knees up behind the ears" thing... EXACTLY.
It's the only place I put them..
