Thread Tools | Search this Thread | Display Modes |
#241 |
Here's the control mounts i made to replace the stock ones
Sponsored Links | |||
#242 |
some simple seat spring mounts on the same pan.
#243 |
it's not too late...
atch (mike atchley) <>< |
#244 |
I've been getting lots of e-mails about the Whip style jockey shift. Here is one that i recently fabricated.
First I do a drawing, a simple diagram just to get a printout to position the holes more precisely, ![]() (i used hole saws for the larger holes) ![]() then cut the end and position a threaded rod for the shift knob, ![]() weld it on... ![]() and after some filing, the upper shift arm looks like this. (I used a hand file to achieve the beveled edge) ![]() This little piece will be the holding bracket for the lever housing. ![]() cutting... ![]() then filing/cleaning. ![]() The lower arm's bearing housing is machined in the lathe for a perfect fit and welded to the upper arm at a specific angle. ![]() . . ![]() ![]() ![]() There are more pictures here on the jj with the shifter on the bike. https://www.jockeyjournal.com/forum/s...3365&showall=1
www.alpracingdesign.com |
#245 |
made this coil housing out of a drive in speaker box i had it laying around for like ten years waiting to pair it up with another one and put them in the back seat of a car and hook them up to the stereo.
but it was to good to pass up to use on the bike ![]() ![]() ![]() |
#246 |
Here is the rear pod i built out of aluminum
www.saltflatsspeedshop.com |
#247 |
Forward controls, forged and fabricated aluminum.
#248 |
39mm NG headlight mount, baffle/endcap
http://jpriderdesigns.blogspot.com |
#249 |
Footpegs & forward controls
#250 |
#251 |
#252 |
Here is my oil tank.
![]() Air cleaner ![]() Frame ![]() |
#253 |
Here are a set of solid mount riser bushings for my '71 ironhead that a buddy of mine machined out of stainless for me.
![]() New Riser Bushings by fiftydollabill, on Flickr ![]() Again by fiftydollabill, on Flickr |
#254 |
Homemade stainless pipes+mini cocktailshakers+homemade taillight housing
#255 |
Here's a frame I built out of 1.5" / 1.25" 1020 DOM tubing. 2up/2 out/34 rake. The tank was a butchered up ebay special that I put a flat bottom in, moved the filler up. Still need to relocate the petcock to the right rear. Pipes are 1.75" u bends and straight tubing tig welded and smoothed out. I need to get to work and finish this thing!
#256 |
here's the air cleaners I made out of auto exhaust reducers(not quite finished yet need to trim the caps a little)
#257 |
Heres a few neat things I did on one Im wrapping up.
Made a removable tail cone, comes off with one movement, no tools. Cafe style seat for one, to 2 seater in 5 seconds :-) Made the muffler under the seat from scratch & exhaust, and....some other stuffs. ![]() ![]() ![]() ![]()
Bikes- Saint Motor Company Blog- um....bike stuff & more Present Build, Tesla on JJ BSA441 Board Tracker on JJ |
#258 |
Hear is something quick and simple. Wanted to make a rear brake stay for my Triumph. Looked around the shop for some scrap, I have been hanging on to this, "THE CLUB" anti-theft steering wheel lock for years.1.Measured the length needed.2. Cut to length 3. used 2- 3/4" nuts.drilled out center to fit hardware on brake stay ends.3. ground each end to fit tab that hardware would be mounted to 4.tig nuts to ends. Done..
WWILD.. "If you can't afford to do it right, the first time,..what makes you think you can afford to do it twice".shovithead Last edited by littlebike; 05-27-2011 at 02:06 PM. |
#259 |
This is a set of mids I built about 10 years ago. They use GSXR masters under the tranny, one for the rear brake, and one for the hydraulic side cover on the 4-in-a 5 case trans. I plan on reworking them a bit and freshening up the finish.
#260 |
Display Modes | |
