Thread Tools | Search this Thread | Display Modes |
#221 |
Mod Squad
FL brake pedal madness I made in stainless.
Sponsored Links | |||
#222 |
that's tastey right there
#223 |
Started learning how to weld earlier this year, but have made good use of my little Hobart 135...
#224 |
machined a pair of these last week. about as simple as it gets
#225 |
Picked up a sissy bar at a swap meet for $15. After cutting off all scabed on brackets I had a good starting point.
Inspired by the frame forgings I made these up after-hours at work to mount the sissy to the axle forgings. ![]() Then cut and drilled some slugs to bolt the sissy to the threaded bungs that were already welded to my fender. I used some 1/2" round stock to connect the sissy to the slugs - note the awesome flux core welds. ![]() ![]() ...and the final product. ![]() ![]() |
#226 |
License plate/ tail light braket/ motor mount.
And repurposed stock foot pegs on a Triumph. I bent up a shifter out of round rod, but don't have a pic. ![]() |
#228 |
here are a couple things cast the tail light and the kick pedal.. Fucked the kick pedal up so have to make another one
#229 |
Floor boards I made....
![]() ![]() ...and a dbl barrel shotgun foot peg ![]() |
#230 |
One of my foot pegs broke on us the other day ,,so i thought id have a crack at making a set ,,,,
Didnt come out to bad ,,,kinda look like a pair of slippers!! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#231 |
I didn't like the feel of forward controls, and the stock controls were too far back for me... so I made my own controls, so that the pegs are about 6 inches forward and 2 inches up from the stock location. I also made the brass pegs on my lathe. I made the brake lever and shifter out of stainless and parts of stock harley stuff. I also tig welded fins onto the stock clutch cover with 1/4 inch round stock aluminum, and sanded them smooth.
#232 |
$ 4.00 Shitty dented up swap meet light, meets WD40, green pads, powder coat, and stainless allen hardware....Total investment $ 12.00...
Diggin around a box at a yard sale and found an aluminum curvy bracket for 25 cents, cut off the end, remove the gold paint, drill out some holes and a pretty cool headlight mount.
Mel Flootie-East Bay Some people are like Slinky's, not really good for anything, but you can't help but smile when you shove them down the stairs! |
#233 |
As posted in the rather erratic OHV X thread of mine..
Gas cap casting in alu and bronze. testing.. testing.. for the right material and feel.. |
#234 |
I built this Iron Head XR750 along with a former emplyer when we diced to try an XR motor in the sidehack I was racing. Since the cut off year was 1972, and we could afford to pry away an Alloy XR750 from any of the collectors, we built this. It started as a set of 1968 XR flywheels and a set of '65 cases and two rear 900cc heads with the original small valves. Everything else was made by Dave and I.
Machining the cases for through studs. I also machined them for superblend bearings and filled the speedo drive and reinforced the tranny case. ![]() This is the front head. Push rod cutouts were filled, new ones cut. Intake and exhaust spiggoted. ![]() New cylinders were make from scratch. ![]() The sump with flywheel oil scrapers. This worked very well to prevent windage inside the cases. ![]() The assembled engine with the sump and new oil pump that had taller FL scavenger gears. ![]() In the frame with megaphones. ![]() |
#235 |
![]() My Fin....... It makes me special :-)
Bikes- Saint Motor Company Blog- um....bike stuff & more Present Build, Tesla on JJ BSA441 Board Tracker on JJ |
#236 |
the PO hacked up the motor mount. so i needed to replace it with something a bit better looking.
Compton and Long Beach, now you know your in trouble.... |
#237 |
Very lowtech but this is the brakepedal for one of my bikes:
![]() ![]() Was too lazy to make some linkage to get it on the right side so I figured why not brake with the heel and shift with the toes? Last edited by SwedeBobb; 08-29-2010 at 06:55 PM. Reason: Bad pic |
#238 |
wow.. there is some good stuff here
![]() here is a sprocket cover i made for my 2006 Triumph "bobber" project... started with a 2.5 mm aluminium sheet... drilling.... filing... filing.... filing.... and almost finished on the bike (stainless steel bolts) ........... its a long winter ahead...........
"Good judgment comes from experience. Unfortunately, the experience usually comes from bad judgment." My build thread... Shovelhead -79 |
#239 |
Some pics from my NorField build.
A tank strap I made from a sheet of alum. Used 2.00 brass clasps from Ace hardware. ![]() Slimline frame I made from chromoly. Not sure if I'll ever make one of these again as it was the biggest pain in the fucking ass to do. ![]() Transmission mounts. ![]() ![]() Finding a 530 rear sprocket for a Royal Enfield got me no where. I didn't want steel as they are heavy so I bought an aluminum sprocket for a CB750 off eBay for $11 and machined a lip to fit over the hub. ![]() Battery tray. I was obsessed with saving weight during the build. Wish I made that out of aluminum.... ![]() |
#240 |
Here's some bars and raiser i did for a friends panhead.
Display Modes | |
