Lets see some details and fabrication on your bike..... - Page 11 - The Jockey Journal Board
Old 12-25-2009, 12:13 PM   #201
drflex
Default Re: Lets see some details and fabrication on your bike.....
some of my stuff
intake
x
homemade velocity stack
wheel spinner/spacer also brass ex. tips/ flame throwers
drflex is offline   Reply With Quote
Old 12-25-2009, 12:19 PM   #202
drflex
belt drive cover
Old 12-25-2009, 12:23 PM   #203
shawnspeed
Well the first pick is a project I am just starting ..'65 bsa I am converting to a street tracker , will build a new swingarm for a mono shock, convert the frame to OIF , fab a gas tank baised on templates from a XR750, & an aluminum dirttrack tail section/seat. I am also going to have to spin up some bearing pocket adapters fror the stem..I will possiblt be fabbing a removable tail section as well.The other picks are some dirttrack chassis I fabbed a few years ago..
ID:	47035   Click image for larger version
ID:	47036   Click image for larger version
Name:	RTX swingarmt.jpg
ID:	47038   Click image for larger version
shawnspeed is offline   Reply With Quote
Old 12-25-2009, 09:56 PM   #204
boatwrench1
Great thread!!!
Some....
Fender/seat brackets...
Headlight bracket...
Oil bag...
Done.
boatwrench1 is offline   Reply With Quote
Old 12-26-2009, 09:09 PM   #205
super rat
super rat's Avatar
super rat is offline   Reply With Quote
Old 12-26-2009, 09:10 PM   #206
super rat
super rat's Avatar
Old 12-27-2009, 07:45 PM   #207
lairdog
lairdog's Avatar
lairdog is offline   Reply With Quote
Old 12-27-2009, 07:47 PM   #208
lairdog
lairdog's Avatar
Old 12-27-2009, 09:22 PM   #209
twowheeledhell
twowheeledhell's Avatar
Cleaned up a slice here and there....
Name:	cut throat 2.JPG
twowheeledhell is offline   Reply With Quote
Old 01-11-2010, 05:54 PM   #210
Bumpstick
Bumpstick's Avatar
Talking Re: Lets see some details and fabrication on your bike.....
Poorman's Battery Box. I looked for "how tos" in search and couldn't find any so I winged it. This is what I came up with. Not as precise as what I could buy, but I can't afford $200 battery boxes. -'b'
Drew a template in Adobe Illustrator. Cut it out, transferred to steel with dye then trimmed.
Added speed holes ('cause everything is faster with holes) Fold in crappy HF brake.
Weld, clean and add mount and drain holes
Fab mount plate.
Paint to taste. I will add a strap to hold down (that's what the slot are for) Works for me.
Bumpstick is offline   Reply With Quote
Old 01-29-2010, 02:32 PM   #211
Dan Boy
Dan Boy's Avatar
Fact: I'm a clumsy twat.
So I broke the cup off my spray gun and then found I couldn't get another one to fit. So I bought one that didn't fit
Then I got me a couple of bolts with the correct threads
Then I turned the heads off them both, drilled and counter bored one and cut a spigot on the other
Welded those two suckers together and drilled the rest of the way through
Trimmed to length and Voilá
Cheers Dan
Blown Triple Build
Old 01-29-2010, 10:43 PM   #212
Hoofhearted
Hoofhearted's Avatar
This is my new fairing (fiberglass) and platform (alloy) for my LSR sidecar.
[/IMG]
[/IMG]
Old 01-31-2010, 09:17 AM   #213
buzzurd
Surrendered my right side fatbob tank for my nitrous setup.The outer shell slides back on and is held in place with zeus fasteners.
Buzzurd
Name:	Picture 089 (Custom).jpg
buzzurd is offline   Reply With Quote
Old 01-31-2010, 11:44 AM   #214
Osprey
Osprey's Avatar
Heres my new jockey shift handle I welded up and threaded for my shovel. 1/2 round bar.
Osprey is offline   Reply With Quote
Old 01-31-2010, 11:55 AM   #215
Osprey
Osprey's Avatar
Went with the old glass door knob instead of the skull.
Old 01-31-2010, 11:56 AM   #216
Osprey
Osprey's Avatar
The bend!
Old 01-31-2010, 12:32 PM   #217
scottto93
scottto93's Avatar
not a big fan of the looks of the external oil filters, but wanted to run a filter none the less.....so....started with an old oil filter housing for a tractor...extended it a couple inches for added volume...opened box after box of oil filter at the autoparts store...machined up an extension post to fit the filter...just need to pick up some fittings and make mounts now...
scottto93 is offline   Reply With Quote
Old 02-01-2010, 12:06 AM   #218
beaverbikes
beaverbikes's Avatar
I built a rack for my B33:
beaverbikes is offline   Reply With Quote
Old 02-09-2010, 06:01 AM   #219
vampyr
Here are some of my new parts. I like the combination of polished stainless steel and polished brass.
ID:	47992   Click image for larger version
ID:	47993   Click image for larger version
vampyr is offline   Reply With Quote
Old 04-21-2010, 02:26 AM   #220
gripside80
Couple little projects.... My buddy handled the tank....
gripside80 is offline   Reply With Quote
