#1 |
I searched the threads and came up with no result, question is I have a 50 fl with a hand clutch foot shift, however the clutch arm I have looks to be a later one, and it interferes with the oil bag plate, somebody cut out the centre of the plate in order for it to work. I also have the bracket that is angled inward to adjust the clutch cable. I just ordered a re-pop pan oil bag and plan to correct this issue. I realize I probably need the long clutch arm that clears the underside of the bag, but what bracket do I use? I found a mousetrap eliminator (long) bracket but it looks odd. first 2 pics are what I currently have.
3rd and 4th pic are what I found |
Sponsored Links | |||
#2 | |
![]() Quote:
one thing, is that you'll lose some cable pull because of the ratio. so, setting up the clutch may be a little trickier than it would be with the later clutch arm or the mousetrap. ![]() |
#3 |
Can I use a mousetrap eliminator kit with the shorter arm?
With the 1950 oil tank that is? |
#4 |
There is one more clutch arm out there that is not pictured ( short arm ) that might work under the harley oil tank with the short bracket, can someone else please confirm this?
#5 |
cowpie aluminum.
https://www.deadbeatcustoms.com/bike...hoCpvwQAvD_BwE |
#6 |
This one from deadbeat will clear the oil tank plate underneath?
#7 |
That I do not know. Link is to show the 3rd version.
#8 |
Think this mousetrap eliminator kit would work?
#9 |
I believe any short steel one will work. May or may not need a little torch heat and bending.
Display Modes | |
