Home made workshop tools - Page 10 - The Jockey Journal Board
Old 12-25-2011, 04:08 PM   #181
DANGER
DANGER's Avatar
A new pair of tongs.
http://dillonsculpture.tumblr.com/
Instagram - DillonSculpture
DANGER is offline   Reply With Quote
Old 12-27-2011, 03:31 AM   #182
popelli
bar to lock clutch hub to assist doing up clutch hub nut
popelli is offline   Reply With Quote
Old 01-03-2012, 08:01 PM   #183
Richharr
Richharr's Avatar
sorry for the crumby pics, theyre from my phone
a base with the nuts welded on for the benchtop drill press clamp
headwork vise
tool post screw
tubing clamp for straight welds
https://lh6.googleusercontent.com/-S...-559567883.jpg
http://fucdatbirth.blogspot.com/
"semper fi" yeah I was miserable and tired for a few years too.
Richharr is offline   Reply With Quote
Old 02-25-2012, 09:57 PM   #184
Cotten
I got in a hurry and used rosewood.
...Cotten
Cotten is offline   Reply With Quote
Old 02-26-2012, 02:00 PM   #185
popelli
centre drilled and tapped crankshaft nut, made up fitting to mount degree wheel and made up pointer so I can staticly set the timing for the twin points set up I have
ID:	74282   Click image for larger version
ID:	74283   Click image for larger version
Old 03-03-2012, 09:36 AM   #186
Cotten
Sometimes ya gotta do what ya gotta do,
and I used Shoe Goo.
(Foot control not shown.)
...Cotten
Old 03-25-2012, 02:14 PM   #187
M.O.Ther
M.O.Ther's Avatar
I was reminded of this when reading Fab Kevin's article in "The Horse" about turning front Fatboy wheels into rears. He was starting his tapped holes in the drill press.
This is a tap wrench that fits on to the drill chuck. The allen screw snugs into one of the chuck key's holes. It works pretty good, and insures that the threaded holes are straight and perpendicular to whatever is resting on the drill press table.
I can't take credit for the idea. This was in a book of projects we had to choose from when I took a junior college machine shop course 20+ years ago. We had to complete a project from the book before we could do anything with our own stuff. I figured I'd make something that I could actually use.
In theory there is no difference between theory and practice. In practice there is. Yogi Berra
M.O.Ther is offline   Reply With Quote
Old 03-25-2012, 03:52 PM   #188
Stinky Pete
Stinky Pete's Avatar
That's pretty great
Railing against the darkness.
My blog - http://garagebuilt.wordpress.com/
Stinky Pete is offline   Reply With Quote
Old 03-28-2012, 09:19 AM   #189
MeanMike
MeanMike's Avatar
I had some time to kill at work and decided to make a tunnel roller for an upcoming gas tank build. I can take my tunnel, throw it in the brake for my 90's and everything will be nice and professional looking, not caveman style.
It breaks down and assembles easily. Slide it together and C-clamp it to the bench. I machined some slugs for the rollers, everything else was done with a grinder and a little tig'n. Makes a nice bend. It's pretty self explanatory, just look at the pictures.
I got this idea from Special '79's YouTube channel. Look him up, he's got some great videos posted.
IG righteous_machine_corp
Mayhem 'til the a.m.
MeanMike is offline   Reply With Quote
Old 04-25-2012, 02:01 AM   #190
popelli
easy method to strip down master cylinder
use the tail stock to depress the spring
saves having parts fly all around the workshop
Old 06-10-2012, 11:44 PM   #191
weaverscycles
weaverscycles's Avatar
this is my re- bodied harbor freight tube roller. i run a water jet machine at work so it isn't too hard to bring ideas to life quickly.
ID:	77124   Click image for larger version
weaverscycles is offline   Reply With Quote
Old 07-08-2012, 11:38 AM   #192
billy3986
Well done! I first thought you got the inspiration from "The Flintstones"
billy3986 is offline   Reply With Quote
Old 04-18-2013, 08:03 PM   #193
Richard D
Richard D's Avatar
Send a message via Yahoo to Richard D
I keep meaning to make one of these. I always forget until I need to tap a hole.
Richard D is offline   Reply With Quote
Old 04-19-2013, 05:57 PM   #194
mt666tm
mt666tm's Avatar
I've made up a puller, case splitter, and a valve spring compressor. That's about it for now
mt666tm is offline   Reply With Quote
Old 04-21-2013, 11:05 AM   #195
wrenchbender54
wrenchbender54's Avatar
This is the socket that I made to hold the top of my dampening rod for rebuilding my Kayaba forks.
wrenchbender54 is offline   Reply With Quote
Old 05-23-2013, 11:33 PM   #196
Bearston
Bearston's Avatar
Here's a fun lathe for you guys, 150 HP...Enjoy!!
http://www.youtube.com/watch?NR=1&fe...&v=P4qB6n1cm04
Bearston is offline   Reply With Quote
Old 05-24-2013, 01:24 AM   #197
Cks-Designs
Cks-Designs's Avatar
Ghetto valve spring compressor/ drumstick valve lapper lol...
Cks-Designs is offline   Reply With Quote
Old 05-24-2013, 10:20 AM   #198
supercrouton
supercrouton's Avatar
Here is a tool that I made to get these vintage starburst caps off, since they always seem to be too close to the gas tank to use a typical large allen wrench.
It is just a 5/16" bolt cut off and welded to a piece steel tubing at a slight offset.
If you were to take out someone's small intestines, and stretch it all the way out end to end, you'd go to jail.
Angry Monkey Motorcycles official website
supercrouton is offline   Reply With Quote
Old 05-24-2013, 12:38 PM   #199
lackluster
lackluster's Avatar
There's some great ideas in this thread for sure. Here's a few things I made a couple years back when I was trying to get my shop a little more put together. Nothing special, but they make working in my shop more enjoyable and they get used everyday.
Good sized fabrication table. Perfectly square, 2x2" with 1/8" wall square tubing frame with 1/4" shelves. My welder fits perfectly in the little nook underneath on the cart that I made for it (and no, the little red stool isn't my welding cart!).
lackluster is offline   Reply With Quote
Old 05-24-2013, 12:39 PM   #200
lackluster
lackluster's Avatar
New cart for my gas welding/torch set up. It's done and painted and being used almost daily now, but I haven't got a picture of it on my photobucket just yet.
