Shop Built Work Tables? - Page 3 - The Jockey Journal Board
Old 11-26-2013, 12:39 PM   #41
Richard D
Richard D's Avatar
Send a message via Yahoo to Richard D
Default Re: Shop Built Work Tables?
Originally Posted by Goldy View Post
Seven months later, I may get around to building this over the holidays. I am still not clear on how the lifting part of the jack connects to the table top(second photo).
Richard D is offline   Reply With Quote
Old 11-26-2013, 01:20 PM   #42
Richard,
I haven't built this particular table (I did build one of my own design using steel), but here is what I see in the pictures:
It looks like the lifting pad on top of the jack doesn't connect to the table. The lifting pad makes contact with the metal plate that's secured to the underside of the table and actually slides on the plate as the table is raised or lowered.
That's a pretty nice table design, especially for someone who doesn't have a welding machine. The only power tools you need to build it are a saw and a drill motor (or a good, sharp hand saw and a brace and bit ). Thanks for posting that up Goldy.
Old 11-26-2013, 01:21 PM   #43
Loffer
Loffer's Avatar
I built a wood table like the ones above ive found about 30" maybe a couple less to be a great height you can work on everything and see the top of the bike . Kept it 24" wide and like 8' long. Wheel chock and eye bolts for strapping down. Easy to attach stuff , and remove like a jig. I'm 5'11. I had it at standard counter height it was wayy to high. 34-36". Aluminum ramps make it easy to bring down with 2 people at this height . If it isn't going to adjust figure a good height for you.
I love that adjustable wood table I might have to build one I have an extra 3 ton jack .
On second look bet that thing is wobbly . Wood doesn't do well for moving parts and pine is pretty soft these days .
Loffer is offline   Reply With Quote
Old 11-26-2013, 03:14 PM   #44
Johnny2Bad
Years ago I had a buddy who rebuilt props (TIG welding AL and SS). He was a bit of a non-conformist … sleep till noon, work till 2 AM … and he had a gig with a Bike / Snowmobile / ATV Yamaha dealership. He had keys to the shop and would work "his" hours, starting when the shop closed at 5 or 6 … whatever it was.
I would help him sometimes and he would teach me how to TIG. I did OK, the props I welded had no voids and were better than most rebuilt props out there.
Anyway, what this shop had for lifts they fabled themselves. They used an expired Acetylene bottle, a steel shaft + fabled mount placed in the bottle, then air / hydraulic fittings were fitted, and the whole thing sunk into the concrete of the shop floor.
The fabled mount was then attached to a steel ramp / stand setup. I don't remember the details exactly but it seems to me they just poured concrete around the bottle and sunk bolts into the concrete, then used about a 12x12" steel plate to fix and locate the top of the bottle / shaft.
They worked very slick, gave you zero to about 3 foot capacity, and it seems to me the cost wasn't too high.
Johnny2Bad is offline   Reply With Quote
Old 11-26-2013, 04:46 PM   #45
Richard D
Richard D's Avatar
I think you are right. Maybe a caster in place of the lifting pad would work as well...
I am tempted to make one out of steel, but my budget is tight, since I just built a 4'x6' steel welding table.
I'd like to knock something together out of wood and use it a while to see what I like/don't like. A prototype, if you will.
Old 11-26-2013, 05:39 PM   #46
Jeff L
Jeff L's Avatar
Can't find a better Pic, but you can see it's pretty simple to put together.It is sturdy.
Jeff L is offline   Reply With Quote
Old 11-26-2013, 06:32 PM   #47
Richard,
The fab table looks good. I like the slats instead of a solid top, it allows you to get a clamp just about anywhere you'd need one.
Thinking about that wooden lift table . . . . 3/4" plywood for the deck and the addition of a gusset plate on what the designer calls the rear legs would help to stiffen it up.
Old 11-26-2013, 10:19 PM   #48
FRISCO67
FRISCO67's Avatar
Not mine but here are a couple from the web, maybe even from here.
They had to replace my metal plate with a plastic one. Every time Catherine would rev up the microwave, I'd piss my pants and forget who I was for about half an hour.
FRISCO67 is offline   Reply With Quote
Old 11-27-2013, 12:53 PM   #49
Frisco67,
The plans for the wooden tilt table that you posted are out of the old Motorcycle Mechanics book. That table works on a simple principle - gravity. There is no jack or lifting mechanism involved. It's a little funny, but every time I see the plan for that table I envision a Evel Knevel type move for getting your bike up on it. You start off by taking a practice run at it and stop at the base of the ramp while you rev your motor a little bit and give the table a hard stare . . . then turn around and get lined up with the ramp. . . . let the suspense build a little bit as you blip the throttle . . . start off with a little wheelie maybe . . . your cape flares out behind you as you accelerate . . . then hit the ramp and as you pass the pivot point and gravity takes over, you lock your brakes and slide up to the front wheel stop and the rear support leg of the lift drops down and locks the table in the horizontal position! ! !
Kinda like loading a bike in a pick-up truck using a short plank !
Old 11-27-2013, 03:12 PM   #50
MARIO MEDEIROS
Table was a old machine mover table with a nice size cylinder that was a hand pump which is now a foot pump.table was 3ft by 4ft but at work i made up a 8ft top and welded it on.This thing works great,also a must is the casters to be able to move it around.
ID:	119194   Click image for larger version
MARIO MEDEIROS is offline   Reply With Quote
Old 11-27-2013, 05:05 PM   #51
M.O.Ther
M.O.Ther's Avatar
This was a heavy duty work table from the place I used to work. They were throwing it out, so I brought it home, narrowed and lowered it. It's 75" long, 25" high, and 24" wide. I have a Handy Industries lift I do most of my work on, but this one will support a second bike if I need it. Mostly it's a horizontal surface that collects stuff.
In theory there is no difference between theory and practice. In practice there is. Yogi Berra
M.O.Ther is offline   Reply With Quote
Old 11-27-2013, 05:34 PM   #52
knuckleworks
knuckleworks's Avatar
well the only thing done by me to this table was adjusting the valves on the pistons for slower lowering and fitting the vise and english wheel to it,takes 1500kg easy and is big enough to have a car on (all though with one set of wheels dangling) used to sit as a loading area at my local booze store hahaha
love it even though it collects alot of stuff
didn't have any pics without the CZ,sorry
Lex Talionis
Old 11-27-2013, 06:58 PM   #53
drainsurgeon
drainsurgeon's Avatar
You can find bowling alley lane on Craigslist. Some guys want a lot, some guys don't... You can also check this website. http://www.homemadetools.net/site/se...kbench&Search= There's quite of bit of good info on this website and it's updated every week. I'm going to get some bowling alley lane for my lathe to sit on. It's a 6" x 18" Atlas. The lane is 42" wide and that's plenty for what I need it for. Good luck and keep us posted.
drainsurgeon is offline   Reply With Quote
Old 11-28-2013, 12:38 PM   #54
dhallilama
dhallilama's Avatar
keep in mind that bowling alley is side-nailed (with hardened nails)... not glued. the pieces can separate relatively easily.
it usually has some steel horizontal ties on the bottom end, ("T" bar on every one i've seen so far), that are held in with a few screws. take those out and the bowling alley starts loosening up. it really needs a frame to sit in...
dhallilama is offline   Reply With Quote
Old 11-28-2013, 04:10 PM   #55
Loffer
Loffer's Avatar
That's the old ones. Newer ones are composit one piece.
Old 12-01-2013, 11:51 PM   #56
skinny
skinny's Avatar
Originally Posted by [email protected] View Post
Attachment 84202
this was a why didn't i think of that moment for me - knallert posted it on here somewhere -so now my jack is in 2 pieces waiting for my buddy to do some welding for me
I've got an xtra jack that just may get converted to a table/lift like that.
Brilliant!!
skinny
"Late night, freeway flyin' always makes me sing...yeah, it always makes me sing"... Tom Waits
skinny is offline   Reply With Quote
