The Jockey Journal Board
The Jockey Journal Board (https://www.jockeyjournal.com/forum/index.php)
-   The Board (https://www.jockeyjournal.com/forum/forumdisplay.php?f=2)
-   -   unequal exhaust pressure (https://www.jockeyjournal.com/forum/showthread.php?t=213944)
Fetch 05-19-2020 07:57 PM
Got a question about an 80" shovelhead exhaust pressure at the end of the pipe. The front cylinder seems to have slightly more 20-30% more pressure at idle then the rear cylinder. (Not an actual measurement, just a hand behind the pipe.)
I've got:
120psi both cylinders cold
Andrews J cam
Solid Lifters
Paughco 735D exhaust
Plugs look equal and toasty brown
https://img.jpcycles.com/zoom/440-723_A.jpg
The push rods are adjusted so that I can turn them with dry fingers. During the set up , I had to adjust them several times since I'd get a tap once the engine warmed up ( usually exhaust side) . Got that sorted, except for the uneven exhaust pressure. Any help?
joe49 05-19-2020 08:58 PM
Re: unequal exhaust pressure
To be expected with the rear having more bends, aka more restriction. Does it matter, not really for a street cruiser.
Fetch 05-20-2020 08:32 AM
Thanks
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
