The Jockey Journal Board
The Jockey Journal Board (https://www.jockeyjournal.com/forum/index.php)
-   The Board (https://www.jockeyjournal.com/forum/forumdisplay.php?f=2)
-   -   cv 40 carb. (https://www.jockeyjournal.com/forum/showthread.php?t=213892)
longbow 05-06-2020 01:45 PM
cv 40 carb.
I need to rebuild my enrichener or plunger on a cv 40mm carb and cant find a plunger kit anybody know of a place to get it? Thanks Craig
johnjzjz 05-06-2020 05:03 PM
Re: cv 40 carb.
you need the choke cable - the spring or the valve
the plastic nut cracks and then the choke wont stay out - that is a cable issue
longbow 05-06-2020 06:43 PM
Re: cv 40 carb.
the valve
horshak 05-20-2020 07:04 PM
Re: cv 40 carb.
after you replace the cable be sure to fit the rubber boot on the body of the carb. The carb will run lean without the boot on as it will suck air.
longbow 05-21-2020 07:23 AM
Re: cv 40 carb.
Thanks Johnjzjz he sent me the plunger.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
