#1 |
I have a 4 speed sportster that revs high on the highway. Any recommendations on how to increase top end?
#2 |
Moderator
Aaaaaa...Stroke it....
![]() Tall gearing needs to have the power to pull... The counter shaft gear would be the easy way to get more.. Don't go to high with the tooth count, will cause the chain to get into the sprocket cover and perhaps the dowel pin on the case.. ================================================== ==== First post here I see.... May want to say Howdy in the intro.... Helps on keeping the Peace.... Last edited by Dragstews; 05-25-2012 at 09:32 AM. |
#3 |
Just add a sprocket with one more tooth to your countershaft. It'll drop your rpms.
You should have plenty of power. Depending on the year your bike was made it may have been geared for the lower speed limits back then. I've done it on pretty much every sportster and shovelhead I've had. Even my chief. |
#4 |
They make 23 and 24 tooth sprockets for the transmission sprocket.
However.....I have a 22 tooth on my Ironhead and I had to clearance the sprocket cover with a 520 chain. The 22 is fine, to me. Some of the earlier bikes had sprockets as few as 18 or 19 teeth I think. Yowzers! How many teeth you got on there now???
Endevour to persevere. |
#5 |
I had a 21 tooth on the front and opted to buy a 23 tooth. I'll let you know how it works out. Thank for the tip
#6 |
Any change is good
#7 |
23 should get you there. And just in case, make sure you run a non o ring chain on there. The o ring chains are to wide and eat into the motor/trans case.
Keep the Old Iron on the road. 72 Chevy C30 truck 73 Custom Shovel 70 XLH 69 XLH 69 XLH *project* 68 XLCH *project* 68 XLCH *project* 66 FLH *Daily Rider* 66 Shovel/Pan/Pan*project* 65 XLCH *project* 60 XLCH*project* 51 FL *project* |
#8 |
I run a 22/49 on my '80 with the disc brake. Stock is 21/51 I think?
#9 |
Go up one on the trans if there's room or drop 3 on the wheel. Anything more might be too much of a change.
El Mirage record 500 APS/PG 129.817 mph El Mirage record 500 SC/PG 122.240 mph El Mirage record 500 SC/PF 120.157 mph Bonneville record 500 SC/PG 119.667 mph Bonneville record 500 SC/PF 117.186 mph Bonneville record 500 SC/PBG 111.494 mph Bonneville record 500 SC/PBF 112.717 mph Bonneville record 650 SC/PG 128.703 mph El Mirage record 650 SC/PG 130.224 mph |
#10 |
If it is a drum rear, his only option is the front sprocket.
#11 |
What year is it? 4 speed could mean anywhere from 57-90.
A pity party is a shitty party - Tijuana Jackson |
#12 |
#13 |
Put a rear disc on it, thats what I did, I run a 48/21. And have a real rear brake too.
Sportster Choppin Bastard CTFS "dentists and bueracrats and pussyboy software designers gettin up on a Harley cuz they think it makes them cool. Well you aint cool skeeziks, your fuckin chilly. And chilly aint never been cool." GC |
#14 | |
Good luck with that one. Yeah, they make em, but they are junk and eat the drum up, and with little wear, they eat the drum. As far as going to a disc, they don't stop the bike any faster than a drum, and much more expensive, to get down another tooth or two. Sportsters ran drums on the rear, from the beginning, and front sprockets have always been the cure. If you are trying to get the "perfect" setup, you may have to spend a lot more money and get something that has a disc and sprocket, seperately. I am willing to bet that the 23 will get him where he needs to be, unless he is drag racing.
#15 |
I'm gonna have to disagree with the statement that discs dont stop the bike any faster then drums. Of course on the rear both will lock up the wheel, but on the front the Brembo caliper I have on my 74 stops WAY better then any front drum.
#16 | |
I'll have to agree with both of you. The drum on the back of a Sportster, if set up correctly, I've found to be vastly superior to a factory rear disc brake. As far as a front brake goes, a disc wins hands down in my opinion.
#17 |
You want to make changes real slow with sprockets as you will be surprised how much difference 1 tooth will make.
Either go 1 tooth up on the front or 1 tooth down on the rear and feel the difference. When I used to race I had an array of front and rear sprockets that I would tailor for whatever track we were racing at. Cheers Dan.
My completed Triumph build: http://www.jockeyjournal.com/forum/s...ad.php?t=62358 My Website |
#18 | |
| Tags |
| harley, speed, sportster, sprocket |
| Display Modes | |
