#41 |
Put a CV on it and go!!
actually, my knucklhead with the Linkert on it was so frikken reliable that I could make bar bets on it! Extremely consistent, 2 kick starts. warm, cold, day or night...did not matter. b'sides....get a Linkert and polish that sucker up!!!
"Good Times & Good Friends Make Life Better!!!" You don't quit riding because you get old...you get old because you quit riding!! my graphics shop's site is...www.artworks-unlimited.com |
#42 |
Lets face it, most of the gazillion S&S carbs out there have been bought because of some very savvy marketing by S&S. Race winning performance right out of the box? Yeah, give me some of that! The reality is that most conversions to S&S carbs from stock carbs is a waste of time and money with very little or no increase in performance solely as the result of the carburetor. I'm not trashing S&S, they're a fine American company with good products. But. . . I can tune a Triumph to run great with a Amal, a Twin Cam to run great with a Keihin, and a Pan to start and run great with a Linkert. I've got a perfectly functioning Linkert on my Pan. It's damn near 60 years old, simple to rebuild and tune, and I like it.
Regards, Geo. |
#43 |
Slap,..Slap.........Slap.
....Cotten |
#44 |
^ this
Just don't forget to inspect the membrane from time to time. A pinhole means it will run like trash. Those linkerts are pretty sweet looking, granted... And less moving parts is almost always a plus. Last edited by rockett; 05-03-2012 at 01:05 PM. |
#45 |
Im no expert on Linkert history, but a very arrogant POS restoration expert, informed me that the reason they stopped making linkerts, is the Linkert factory burned to the ground.
#46 | |
All we have are anecdotes. Tillotson bought L&L, so that's what went on '67 H-Ds. .....Cotten |
#47 | ||
I just happen to believe the the Linkert is a high quality instrument worth keeping on the bike for reasons other than "it's original". Good materials and construction. Holds adjustments and setup almost forever. Easy starting. Easy tuning. Good mileage. I think their bad reputation comes from the fact that most have been ham-fisted at some point in their lives by now -OR- people have mixed them up with incompatible internal parts thinking they were interchangeable when they weren't. The float can be a little tricky to setup correctly, but it isn't brain surgery. A little care and testing is all that's needed. At least this has been my experience with them. Quote:
Jason |
#48 | |
My shop charges twenty minutes flat-rate to set up a fully pre-prepped bowl. Sometimes we make our time. Sometimes we don't. Modern technological advances have nearly eliminated the need for care and attention, much less eye-hand coordination skills, when servicing non-antique designs. ....Cotten |
#49 |
Linkerts on both my pans, a 59 and a 61, going on 40+ years now, no problems. Have an S&S on the shelf, never used it.
#50 | |
Atomic Custom
Linkert.. yes. Run it.
Atomic Trent 505-281-2520 Atomic Custom Blog! Atomic Custom Website http://instagram.com/atomictrent/ "Custom parts are good only when they're cooler than factory parts. By cooler I mean have better lines, work better, etc." |
#51 |
Cotten- that's today's 'black box' thinking. Rather than diagnose and fix, it's reaplce until it works again. (But you already know this) Jason demonstrated his one kick Linkert last winter to me and had me sold. I currently have two M74's sitting on the shelf ready to go and an S&S E that'll probably stay there a lot longer.
#52 |
Just for clarity, Folks.
Modern reproductions of common Linkert models have been recently produced out of California, Holland, and points eastward. Just look in Tedd's. Far beyond that, there have been exquisite reproductions of L-L barrel carbs as well. That's too serious for even me. ....Cotten And Eman! Aren't you going to redeem yourself by pointing out that the Lake injector was a performance option for early '80s H-D's? .....Cotten |
#53 |
WTF!!!
Linky's look GREAT all polished up! Make that brass shine!! ![]()
#54 |
I did not say "Flat spot" I said roll on throttle. you know as well as I do that a non accelerator pump carb doesn't like a cracked throttle, it' more of a smooth action. as for the reason for that same response I just was mentioning to the OP that he needs to decide what his riding history and style will go with witch carb.. his bike his ride, his style.
#55 | |
Also, I misspoke when I said lake injectors in the first place, I was referring instead to the early 'Lake' carburetors that just relied on fumes being sucked off the top of the gas 'puddle'. |
#56 | ||
I used to think that, but now I know better. ....Cotten Last edited by Cotten; 05-04-2012 at 06:59 AM. |
#57 |
Cotton: I may have failed to read behind the lines, but can you elaborate on reproduction Linkerts.
What's wrong with polishing the bowl. I know S&S says not to polish their carbs because of polishing scuzz being created and and clogging stuff. Is this is the reason on a Linkert? I still don't understand why one shouldn't polish the bowl itself, and then rinse all the residue inside very thoroughly. |
#58 |
This thread is completely subjective. Run what you're comfortable running. If you know and can fix S&S on the side of the road, run S&S. If you know Linkert, or any other carb for that matter, run that.
Pick whatever you're comfortable with. Other than that you're just going to listen to a bunch of grown men pushing their opinions. If you asked what carb originally came on my bike, you'd get an objective answer, not on this subject however. Me, I'd probably run a Bendix. No reason, I just like Bendix, no better or worse than any other carb. They work well(like any other carb), they're economical and they're infinately rebuildable and you can get parts for them almost anywhere which is nice when you're 500 miles from the parts boxes in your garage.
A pity party is a shitty party - Tijuana Jackson Last edited by kickstarts; 05-04-2012 at 07:34 AM. |
#59 | |
Mas Classics of California produced the first reproductions nearly a decade ago, followed by 45PartsDepot of Holland. The Tedd offerings are probably from further east. I have only inspected Mr. Mas's prototype; None of the others have crossed my benches. Its worth too damn much. Polishing ruins it for the savvy market. You must decide if either you are 'into' the History of a vintage machine, or you are into screwing it up. ....Cotten |
#60 |
Atomic Custom
Cotten, Ive run the Tedds Linkert carbs.. Never had a problem, worked great right out of the box!
| Display Modes | |
