Enclosed rear chain drive help needed - The Jockey Journal Board
Old 03-13-2012, 11:22 AM   #1
juspassinthru
Exclamation Enclosed rear chain drive help needed
got an 84 flht and she leaks where the chain cover bolts to the back of the motor.I want to drain the chain lube system and remove the cover and just lube it myself. has anyone done this? what is the easiest way to do this? The bike is running a 2004 evo reman. instead of the 84 evo bottom breather it came with thanks.
juspassinthru is offline   Reply With Quote
Old 03-13-2012, 06:15 PM   #2
DarkGoat
Default Re: Enclosed rear chain drive help needed
The wheel bearing is lubed with the same oil. If you drain it then the bearing must be packed with grease and sealed somehow. I haven't done that, but the chain boots are not terribly hard to get to seal up. It's the wheel seal that is hard. The trick to the boots is to not tighten the bolts until the rubber spooges out.
DarkGoat is offline   Reply With Quote
Old 03-13-2012, 10:19 PM   #3
juspassinthru
mine is leakin from what looks to be s front boot up by the motor?any ideas?
Old 03-14-2012, 07:21 AM   #4
pan620
I took one off of a 83 FXRT and a 83 FLT no problems with the wheel bearings as they had seals on them already.
pan620 is offline   Reply With Quote
Old 03-14-2012, 07:32 AM   #5
kickstart257
kickstart257's Avatar
I took mine off when it leaked, it was torn so I just ditched it.
Ran it as a open chain drive
that was around 90
If I remember the rear wheel had packed bearings anyway,
If you are just wondering if you can run it open, glad to help
If not, sorry, no help here
Carry a gun and exercise your second amendment rights, it's not just a good Idea , It's the law
kickstart257 is offline   Reply With Quote
