SU's - Page 2 - The Jockey Journal Board
Old 03-13-2012, 10:57 AM   #21
sixball
sixball's Avatar
Default Re: SU's
The elbow on the main jet is how they come stock. The straight one has been cut to be run with a float bowl extension. You cut the elbow off, and add a small piece of tube that slips over the end of the main jet, and add an extended fuel bowl. They are made for "strokers" but I run the extension on about every SU I run. It ensures you don't starve the carb from fuel.
If you have enough room with your tanks, you can run the downswept intake either way, up or down. For a kick only bike, I would run the straight manifold, or run the intake upswept. Fuel flows downhill better for intial startup.
Sixball
sixball is offline   Reply With Quote
Old 03-13-2012, 10:57 AM   #22
Dragstews
Moderator
Dragstews's Avatar
Default Re: SU's
Think that I may have a few intakes that are not offset...
If in need let me know and I will go a digging..??
www.dragstews.com
On to the next "WOW" experience !
Old 03-13-2012, 11:00 AM   #23
sixball
sixball's Avatar
Default Re: SU's
And I forgot to add........ You have an SU that has been gone thru by Riverria Engineering. It has the tickler on it. They bought up SU's and converted them for use on bikes. The tickler is the proof.
Sixball
Old 03-13-2012, 07:25 PM   #24
ChopperArn
ChopperArn's Avatar
Default Re: SU's
plenty of room under the tanks... Stews if you have a straight one I'd barter with ya, PM me if you run across it
-STAY FREE-
ChopperArn is offline   Reply With Quote
