#21 |
got the bars almost finished up today
I just need to cut down the width on them once I get the tank back and I want to notch and weld a piece going horizontal across the center did them out of 1" stainless laid out of on the table after I measured and made the cuts ![]() ![]() ![]()
http://syndicatechoppers.com http://syndicatechops.blogspot.com/ http://syndicatechoppers.bigcartel.com/ authorized dealer for Biltwell Inc Lowbrow Customs Buchanans Spoke and Rim Wargasser Speed Shop Universal Vintage Tires Paughco V-Twin MFG. Fab Kevin Colony Machine Morris Magneto Baker Drivetrain Boyle Custom Moto Air Cleaners |
#22 |
Nice work on those bars! And FYI, your fork is on backwards
#23 |
Looking good Ralph keep it up man!!!
Nothing better than drinking beer and throwin lead.. Except riding my Sled. If you like me fine....If you dont Fuck You. AKA...Hemi Head |
#24 |
just about finished with the bars
I just have to get the tank back on it then I will cut them down to width took a piece of 1" solid stainless and turned it down on the lathe to fit snug inside the .120 wall 1" stainless tubing that I notched for the center piece on the bars ![]() ![]() ![]() then welding everything into place ![]() ![]()
#25 |
re did the rear fender struts
the aluminum flat stock that I used before somehow cracked so I did it over this time in 1/2" 304 stainless round tube and stainless bullets for the top and countersunk bungs for the bottom ![]() ![]()
#26 |
Man, that is sick. How do you have skills like that and are broke? That's some really sexy welding.
#27 |
Looking way better already.
#28 |
Looking Good!! any chance on getting some information on the trans / starter setup?..looks like a ratchet top, tell me about the starter
"A bike should look good on it's own, but it's incomplete until a person rides it"- Shinya Kimura |
#29 | |
the starter is a tech cycle kit for the BDL 3" open belt its a very nice piece and about the only aftermarket open belt 4spd electric start kit that I know of Im actually looking to sell the kit off as I barely use since the bike has a kicker setup also if your interested in it send me a pm
#30 |
nice work
#31 |
thanks for the compliments
getting a little closer handle bars are all done ( I might cut them a bit narrower but they are good for now) ![]() and got some mockup work done on the front brake setup its super tight but I think I have enough clearance to make it work so I plan on shaving this leg down to match the other one then welding on some caliper mounts to match this caliper and locate it in the proper position I might have to mill off a little bit on the backside of the caliper near the spokes but I should be fine to do that the caliper looks plenty thick next step is to machine the axle down to fit and make up some spacers for the proper spacing ![]() ![]() non brake side ![]() clearance between the back of caliper and the spokes
#32 |
Is the axle not the right one? Or is this like a hybrid... Just curious...
If you cry at my funeral I will never speak to you again! http://jalopyjoe.blogspot.com/ |
#33 | |
the front end is a set of old narrow glide width trees made to fit the 41mm wide glide tubes so I have to cut and re thread the standard wide glide axle to the correct width as the narrow trees are a lot skinnier than the wide glide ones you can see in the pics how much its sticking out on each end Im also gonna have to turn down the axle a little bit on the non brake side of the front end to pass through the leg without the bottom cap
#34 | |
but I just guess this hobby costs you more than it makes you little update : got the measurements for the new front axle gonna have that finished this week so I can mount the front wheel and make up some spacers then it will be back to being road worthy I needed the hub out of my mock up wheel the spokes were shot so I took the cutter to them and cleaned up and powdercoated the front hub and laced me up a fresh 21" front wheel also broke the front end down to shave down the other lower leg before I weld on the new brake caliper tabs and figured the chrome was so bad and the corner was scraped up so I welded up the corner and smoothed it back to shape with the flap disc then put some powder on those too all in all its getting there tank is ready for paint, Im hoping to have the bike completely back on the road within 2 weeks from now ![]() ![]() ![]() ![]()
#35 |
I was thinking the same thing, I really like the slim tank and going about 3inches under stock on the legs will really change up the stance of the bike, from there lose the taillight from the fender and go with something side mounted just to change it up a bit. All minor mods but freshens her up a bit! Really diggin the Shovel as always!
#36 |
Wow!!
Not enough time for windmills |
#37 |
That rim looks sweet. Did you do the powdercoating yourself? I'm seriously considering building myself an oven before I continue with my 2 builds...
#38 | |
I just have an old wall mount oven that I mounted to the wall in the garage works well I can pretty much fit anything from a bike inside of it except for a frame and a 21" wheel
#39 |
just a little update work has been slow on this lately
but Im turning the corner on here and she should be back on the road in about another week or so if I get some time to work on my own stuff instead of stuff to pay the bills haha got the new axle all made up for the front end got the new 21" wheel all finished up and tire mounted tank should be back from paint tomorrow heres how she looks on the ground with the new stuff on her ![]() ![]() ![]()
#40 |
some more
![]() ![]() and pics of the tank all finished big thanks go out to erick from jakescustoms.com for the great job on the tank and super fast turn around, and amazing price thanks for the help man it was much appreciated ![]()
| Display Modes | |
