#1 |
So I need some educating in cam history. I found a set of Ironhead cams on feebay. They are stamped with SL, the dude says they are Sifton/Lienweber. Any truth to those two producing parts together? Thanks in advance and I apologize if this somewhere on this forum already.
#2 |
No truth.Lienweber is one company(a good one) and Sifton was another.Please note that the stuff being sold under the Sifton name now is chink scrap metal from V-twin.That buzzing noise you hear is Tom Sifton spinning in his grave.
#3 |
+1. siftons have the timing stamped on em too, which ,in retrospect, was a badass idea. if want maximum fury when you twist it, lienwebers are the shit.betterhave the restof the motor setup right though.
#4 |
Agreed, Lienwebber cams are stumpy and proper headwork is advised. Great bang though....in a positive way.
#5 |
Thanks again for the info guys. I wish people were more knowledgable about what they are selling. Guess I'll keep searching for the good stuff for my Ironhead.
#6 |
the Sifton SL cam sorry to say is at the bottom of the Performance Chain, they are also known as Sportsman, if you can locate HH or +HH with thier .475 lift, now we are talking turkey... XLR Valves bring out the best when used with these cams..
#7 |
Andrews still offers nice cams for Ironheads. I just put a brand new set of V 9's in mine. I had to have my case machined to fit them so if you are gonna go with big cams just know they aren't bolt in. Mine also has XLR valves in it which required some machining to make fit too. Good luck
#8 |
Dont buy the "new" sifton stuff, the old original cams and components are top notch. I have a original sifton 468 in my pan.....
I BELIEVE IN JOHN 3:16 |
#9 |
^ Yeah I hear you on the new stuff. Just waiting to find some good ol' speed parts!
#10 |
How do you know you have a Sifton 468 in your Knuckle?? you get this!! You have to clearance the underside with a bit of grinding, maybe welding in order to not crack here...I'll be fixing this early next year
#11 | |
Robbie |
#12 |
Moderator
I will throw in TWO CENTS here..
The OG Poster was asking about after-market cams for an Ironhead.. Most all manufacturers makes them with the gears made on as a one piece cam... This is where the Two Cents come in at. These gears are cut/honed to a red color code...Red is pretty much the Standard size used...It is in the middle of the seven codes made. Harley (In the later years of Sporty's) was trying there best to get the valve train to run with-out big time noise (Rattle or Whine)...They would mis-match those codes in order to get .000 to .0005 backlash on all 5 fitments. There are some company's that make only the lobes for the OG gears.. This is a bit of work to make happen being the OG lobes would need to be ground off and the new lobes degreed in and welded on. To name a few of them is Leineweber, Red Shift.. Andrews will take back a new cam that is theirs as long as it has NOT been run for honing the gear smaller or replacement with a larger gear as the need requires... Just food for thought here on Performance Sportster Cams...
#13 |
#14 |
Moderator
You don't have to listen to many years of "Been there, Done That"
For others, Just may come in handy.. |
#15 |
Care to elaborate, or just trolling?
#16 |
Yeah, I seen that movie…. you were lucky, I put a cheap $25 Chet Herbert regrind in the knuckle I had in college….broke the mounting ears for the boxes on the head. We all learn the hard way.
#17 |
#18 |
#19 |
Why do people post off topic BULLSHIT? I am here to learn from the guys that have made most of the mistakes before so that I don't. Keep the snatch whining to yourself.
#20 |
Jtw79,
More Cam Stuff, and you are correct in that you can learn a ton of useful info from experieced guys, Jesse 'DragStews' is One of them as he Builds Motors, Me- I'm an Ironhead enthusiast and dig hot rod Sportsters.. Jim Leineweber is still in the hi perf business, his cams are known to be kick ass all effort drag cams designed to get as much HP out of a motor, the other side to this that they are a bit hard on the valve train, lifters, etc.. Tom Sifton past away in the 90s, he was Old School and made Hi Quality cams for all types of bikes, back in the Day his KR flathead Racers beat out the Harley Factory bikes so people took notice, in the 60s the Sifton Minus Minus .436 cam was the cam to have, 'long duration' stroker cam - (intake stays open longer) guys still run them but today there are many other choices.. Andrews, Redshift, etc.. in the early 70s Tom Sifton partnered up with a Machinist-Racer Dick Hilferty that carried the thrown and continued to produce quality Sportster Ironhead Cams ( I had HH .475s in my 900 and loved them), Dick Hilferty went on to Design and grind Redshift Cams, from the 1981 Sifton Catolog the Ironhead cams are listed from bottom to top in steps of performance as: Performance (Street) SL Sportsman +H-- Hustler B Stinger HH Scorpion .475 Lift (*Sweet in a 900cc with XLR Valves, 1970 piston) LL Challenger Hi Performance (Street and Drag- *Not Drop In Cams) Minus Minus .436 'Titan Cams' +HH Boss .475 Lift 'C' Barracuda .480 Lift 510M Big Mama (510 thru 555 more for all effort drag racing) 510A Smoker 555 Eliminator 555 Super Eliminator Unfortunately the Sifton Name and Patterns were sold and the current cams sold as NEW that carry the Sifton name are suspect as far as Quality so beware.. Keep Learnin and Askin...... Last edited by Monte03; 12-22-2011 at 10:05 PM. Reason: info |
| Display Modes | |
