Panhead Flywheel / Sprocket shaft question - The Jockey Journal Board
Old 10-20-2011, 05:45 AM   #1
iflybyu
Default Panhead Flywheel / Sprocket shaft question
Hi all,
Can I make '64 flywheels work with pre '54 left side case?
If I can, what is involved?
Thanks
Mike
iflybyu is offline   Reply With Quote
Old 10-20-2011, 06:09 AM   #2
Cotten
Default Re: Panhead Flywheel / Sprocket shaft question
Mike!
Yes, but you will need the earlier shaft, rollers and cage, thrustwashers, etc.
Installation is covered in the Service Manual, although worn tapers often benefit from lapping: http://virtualindian.org/10techfly.htm.
....Cotten
Cotten is offline   Reply With Quote
Old 10-20-2011, 08:28 AM   #3
iflybyu
Cotton,
SO the older shaft will work with the newer flywheels? I thought the angles at the flywheel were different between the two shafts?
I am at sea right now and don't have access to my manuals, but would like to order what is needed to make this work so I can get at it when I get home.
Mike
Old 10-20-2011, 10:09 AM   #4
Rubone
The answer is no! You cannot put an early left shaft in '55 and later flywheels. The hole in the left flywheel is physically larger and impossible to bolt together. The machined surface is also wrong for end play washers, etc.
Robbie
Rubone is offline   Reply With Quote
Old 10-20-2011, 11:03 AM   #5
jbfrmca
Originally Posted by Cotten View Post
Mike!
....Cotten
thank you for posting that link. some very usefull information.
jbfrmca is offline   Reply With Quote
Old 10-20-2011, 11:40 AM   #6
dudleysbasement
the earlier sproket shaft wont work in a later flywheel but if you had to you can use a pinion side wheel for a sproket shaft wheel . tapers are the same on both wheels in early motors but you will have to rebalance it
dudleysbasement is offline   Reply With Quote
Old 10-20-2011, 12:50 PM   #7
Cotten
Doh!
I don't know why I was thinking pinions instead of sprockets so early in the morning.
With a one-year-only taper'd '55 on the bench, I have no excuse.
I might as well go back to Peoria.
.....Cotten
Old 10-20-2011, 03:36 PM   #8
vtwinmotors
vtwinmotors's Avatar
I remember guys talking about useing 2 right flywheels back in the day for hot rod reasons. Good luck on your project.
vtwinmotors is offline   Reply With Quote
