#121 |
^^^^ that is all "greek " to me^^^^
"A bike should look good on it's own, but it's incomplete until a person rides it"- Shinya Kimura |
#122 |
#123 | |
let me now if you want some coffe...
"Good judgment comes from experience. Unfortunately, the experience usually comes from bad judgment." My build thread... Shovelhead -79 |
#124 |
#125 |
I must have had a mild stroke when i posted the piston to wall clearence!!
NOT 1.4mm (0.055") It is Front Jug # 0.14mm (0.0055") Rear jug # 0.11mm (0.0045) still its out of spec.. (0.001" - 0.002") I have decided to buy new jugs anyway.. dont want to deal with the powder coat / chrome stuff.. start with new fresh looking stuff! Here is a pic of the oil return on the front cylinder... Dont know if its a big deal? (could this have been an issue burning oil?) this i DONT like.. look at the exhaust port (front head) Cant be good for flow... and the rear head looks better... if compared.. shall we "port" the rear head or just put it back and forget about it? what should you guys do? Cheers
#126 |
Got bored, went inside the garage and found this 5 gallon tank...
I thinks its ugly! (to each their own) dry fit... tunnel cut out... dont know the clearence yet... crap... havent decided yet on the final position... whats your opinion?? cheers // Kenneth
#127 |
I think it looks great,following with genuine interest.
#128 |
That split tank is looking good!
Homines Vetere Sordida |
#129 |
Thanks guys...
talked to my engine guy and he had some good news for me.. he now have all the parts in house and are almost done with the rebuild.. i went for Rowe black melonite valves and he had some problems to get hold of them.. he heared something that Rowe has quit making them?!? can that be right? well I cant wait to get the motor back in the frame and kick her to life!! ![]() thought i should take my shovel build into the 2012... and mounted a Sigma 1609 on her.. it got all the info i need.. and more!! (maybe not for all, but it works for me) Km/h.. temp.. trip 1.. total odo.. clock.. etc etc.. wireless and its backlit to.. i tried to spinn the wheel by hand.. 7.2km/h is not to bad ![]() well cheers guys..
#130 |
got my GMA rear brake working... one more thing off the list!
thought i should check the bearbox oil.. glad i did.. didnt know you could use milk in it!!! ![]() closer... hahaha... funny stuff.. or not getting closer... cheers
#131 |
drain...
kinda looks like vanilla ice cream... Magnets working i guess.... I hope it looks like this next year.... im sorry if im boring you guys with stuff like this... its kinda basic stuff.. but i like posting pics and keaping things so i can go back and look at wtf i been doing on the bike ![]() Cheers
#132 |
Your frame looks terrific for being painted with a brush. Maybe I'll just throw my spray guns away.
A pity party is a shitty party - Tijuana Jackson |
#133 | |
dont do that ![]() i think i got lucky this time... hehe.. we will se how good it hold up this summer. actually im planning on buying a spray gun.. kinda tired of rattle can matt black
#134 |
After i was done with the gearbox oil change i couldnt help looking at my clutch arm.. it doesnt look right!
and it wasnt bolted in good and snug.. it just pop loose in my hand when i pulled straight up (bolt not in the pic) so i found a kick pedal from a China mini chopper engine.. think it was a 110cc. this might work... cut off all the junk and welded a longer piece on it... spot welded it to the "square" bottom piece and drilled a 4mm hole all the way through and a bigger 6.5mm half way...fits my Hinckley Triumph clutch cable... slizing it open in the end so i could put the cable into place. I drilled it in an angle so it wouldt "bend".. here its just spot welded to the "square" ring and the spacer for the bolt... and from another angle.. gonna finnish welding it tomorrow and grinding it into the shape i want it.. im pretty pleased with it so far.. and i made it myselfe! ![]() cheers.
"Good judgment comes from experience. Unfortunately, the experience usually comes from bad judgment." My build thread... Shovelhead -79 Last edited by knallert; 03-26-2012 at 02:37 PM. Reason: spell check... |
#135 |
Keep posting knallert makes me see how lazy i am not doing shit on my build,4 years and counting..lol
#136 | |
Now get off your ass and go make some parts! ![]() Done! or atleast the metal part. paint it black or silver? cheers. ...
#137 |
Ok... I want a clean kick pedal.
I had a popsickle but i didnt like the look of that! a long time ago i shortened a fork tube on my -74 Honda Monkey bike and the cut off part was a perfect fit! (never ever throw away parts! you never know when you need them!) the end cap is from my wrecked Scrambler handlebar, its stainless and welded up nicely through the hole on the end! result... finally started on my rear fender. its a 21" harley front fender. I have to widen it atleast 45mm to fit the tire and the fender strut. the strut are from my 2001 bonneville that i sold last summer... fits like a glove!! gonna make my own 2 into 1 so i mocked them up on the floor. need the motor in the frame before i can start that project.. cheers..
#138 |
got some work done today...
split the fender... Fuck.. i didnt have any sheet metal at home.. (remember to buy more!) had to cut some from this 2" x 1".. spotwelded into place.. its a little thicker than the fender so i had to aim the weld to the thicker piece.. welded it in short beeds and moved around alot so it wouldnt twist. How close is safe to mout a fender? i know that the tire gets larger at speed... i didnt use the first strut i had on.. it was hollow and to fragile so i made some out of 10mm solid round bar. welded on the other side.. trying to keap it as clean as i can. test fit... i havent solved how i will mount it to the fender yet.. cant decide if i want a "sissy" on just snug around the fender.. decissions decissions well thats al folks.. cheers!
#139 |
Yesterday i got a phone call from Anders, My engine was ready to pick up!
fuck i couldnt sleep last night!! I had some time to kill before the pick up so I started to fab a new belt cover. its 2 mm steel.. still have a lot to do on it but its a start. well 06:01 PM i was at Anders workshop.. and there she was.. My god I missed her! talked for a good 3 hours and home we went.. She is back were she belongs.. mocked up my "new" exhaust just to get an idea of how it will look.. I think she is stunning... its a fucking beautiful engine! oh my oh my.. cheers guys...
#140 |
I don't know how I missed your thread. Your shovel is looking awesome! Great work, as always!
Cheers, Dan. |
| Display Modes | |
