#1 |
spart
#2 |
Location: Just past the corner of Hell and The Twilight Zone.
The problem is oil is getting in the cylinder.
Either past the rings, or valve guides. |
#3 |
how is that fixed?
#4 |
Items needed for project: 1. my heads back from the machinist. 2. Oil return lines for cast FHP rocker tins (S&S #106-4446) . |
#5 |
ChopperTony!
If you set the plug out in the warm sunlight for a while, you can tell if it is really oil that stays greasy, or gas-fouled if it dries to soot. Oil would mean a hardware problem, like a breached headgasket, worn rings, or damage around an intake valve guide, etc., as Unkl Ian mentioned. But the far more common cause of fouling is fuel when there is a vacuum leak: The carb must be over-enrichened to make the lean cylinder run. Please bubble-test your manifold assembly as discussed at http://virtualindian.org/11techleaktest.html. (A #9 rubber stopper works as well as a testplate, but takes three hands.) I would wager that you have a leak to your rear cylinder. ....Cotten PS: With a Pan, it is also adviseable to bubble-test the pan cover screw over each intake port, as occasionally they have breached from too long of screws in the past. |
| Display Modes | |
