Online tube notching calculator - The Jockey Journal Board
Old 06-28-2011, 10:34 PM   #1
Stinky Pete
Stinky Pete's Avatar
Default Online tube notching calculator
I'm sure some of you guys know about this, but I just found it so I thought I'd share.
I'm putting a new set of pipes on the shovel - the plan is to run 2 into 1, so I needed to figure out how to cope the rear pipe into the front pipe.
I started by clamping the rear pipe at the angle on my drill press and running a holesaw into it. Too much, chatter and deflection...I'm not about to screw up my drillpress for this.
Then I tried coping by hand - that was a waste of an hour and came out terrible.
I resigned myself to doing a quick google search to see how people were doing this and came across this cool little tool: http://metalgeek.com/static/cope.pcgi
Here's my process:
1) Do some calculations and plug the numbers into the website. The tool spits out the curve of the cope. (I printed a few just in case I screwed up a few)
2) After cutting out the curve out, I wrapped it around the pipe. The pipe has been marked with Dykem so the scribed line shows more easily. If you haven't heard of Dykem or aren't using it - do yourself a favor and go get some.
Then I hogged out the majority of the cut with a grinder and smoothed up to the scribe lines with a rough cut bastard file. If you don't have files...go get some.
Here's a test fit pic of my cut on a pipe. Fits like a glove, no gaps, will weld up beautifully and matches the angle of the front pipe perfectly.
That's it - about 20 minutes, minus the measurement part of the process.
If you guys need to notch pipe and don't have the money or quantity of work to justify investing in a machine, I highly recommend the website. As you can see it works well, is free and simple.
Thanks.
Railing against the darkness.
Old 06-28-2011, 10:36 PM   #2
buddha000
buddha000's Avatar
Default Re: Online tube notching calculator
Awesome.
_____________________________________________
Always a student. Sometimes an a$$hole. Never a douchebag.
buddha000 is offline   Reply With Quote
Old 06-29-2011, 06:39 AM   #3
littlebike
littlebike's Avatar
Thanks Stinky, I will be needing to do this soon,very timely.
WWILD..
"If you can't afford to do it right, the first time,..what makes you think you can afford to do it twice".shovithead
littlebike is offline   Reply With Quote
Old 06-29-2011, 09:20 AM   #4
krazykooter
krazykooter's Avatar
Found this myself a few years ago too.. Very Very helpful for all!!
Living life while experiencing several WTF's!! Daily...
krazykooter is offline   Reply With Quote
Old 06-29-2011, 09:29 AM   #5
weldinbiker
A friend of mine does this on his expensive solid works program. He had to put a lot of time into figuring out how to get these pint outs. Wait til I show him this!(he he!)
weldinbiker is offline   Reply With Quote
Old 06-29-2011, 11:19 AM   #6
knuckleworks
knuckleworks's Avatar
Thanx
uıɐƃɐ ʎɐqǝ ɟɟo pɹɐoqʎǝʞ ɐ ʎnq ɹǝʌǝu ןן,ı
Lex Talionis
R I P Tippo 110426 my best friend for 13 years,you're missed
Old 06-29-2011, 12:09 PM   #7
klunkers
klunkers's Avatar
Thank YOU!
klunkers is offline   Reply With Quote
Old 06-29-2011, 12:13 PM   #8
FeHd
FeHd's Avatar
Cool site. I'm a (was) body designer, a couple of views and and some projections is all it takes. But the way you did it is even faster.
Sportster Choppin Bastard CTFS
"dentists and bueracrats and pussyboy software designers gettin up on a Harley cuz they think it makes them cool. Well you aint cool skeeziks, your fuckin chilly. And chilly aint never been cool." GC
FeHd is offline   Reply With Quote
Old 06-29-2011, 01:09 PM   #9
old.wrench
old.wrench's Avatar
Thanks for posting that Pete. Very slick. That calculator gives the same results as using the old pipefitting technique for making coping templates. It eliminates all the calculating and graphing you had to do back in "the old days". Nice looking job on your cope too. By the way, if you don't have any Dykem at hand, a blue, red, or black magic marker works pretty well. The contrast with your scribed line will not be quite as distinct as with Dykem, but perfectly servicable. Magic marker drys faster and isn't as messy.
Regards,
Geo.
Old 06-29-2011, 02:29 PM   #10
knuckleworks
i use ordinary 1k blue met rattlecan paint as contrast paint,quick dry easy to clean off and cheap
Lex Talionis
Old 06-29-2011, 04:51 PM   #11
Stinky Pete
That's cool - I'd never considered marker or paint, but it's a great idea. My dad's a mechanical engineer and spent a lot of time in tool rooms, so he picked up a lot of tricks and practical how-to's.
We were standing in a tooling supply store and he handed my a bottle of Dykem. I got the bottle and brush setup so it takes a min to dry and I have lots of tiny blue dot spray on every work surface in my garage
Usually I'm putting the fluid on some steel I just got done wirebrushing, so the heat in the metal makes it dry right away.
Old 06-29-2011, 05:22 PM   #12
Spring-Onion
Nice find thanks for sharing
Spring-Onion is offline   Reply With Quote
Old 06-30-2011, 11:13 AM   #13
The Punisher
The Punisher's Avatar
This is a fantastic link. I've been building some new pipes for my shovel and this just saved me a bunch of time!
The Punisher is offline   Reply With Quote
Old 06-30-2011, 11:55 AM   #14
britbikebuilder
britbikebuilder's Avatar
great link keep em coming
Todd
Tech Support
britbikebuilder is offline   Reply With Quote
Old 06-30-2011, 12:05 PM   #15
tattooedblue
tattooedblue's Avatar
Thanks for the link!!
I will be book marking that!
I do a lot of tube work on Jeeps, and that will come in handy!
tattooedblue is offline   Reply With Quote
Old 06-30-2011, 12:26 PM   #16
Dr. Benway
Mod Squad
Dr. Benway's Avatar
Years ago I used this shareware program to calculate & lay out conical shapes to transfer onto sheet metal...I don't have a PC so I can't check out what it's like now, but it may still be of use. 21 day trial-
http://www.softpedia.com/get/Science...e-Layout.shtml
Old 06-30-2011, 05:02 PM   #17
wadehammer
The tubing calculator rules! I use it to build my hardtail and handlebars. Free and brainless!
wadehammer is offline   Reply With Quote
