45 motor in a trw frame? - The Jockey Journal Board
Old 06-17-2011, 09:09 AM   #1
MARIO MEDEIROS
Default 45 motor in a trw frame?
Can this be done or has anyone seen this done before.Have a 45 motor and a 4sp triumph tranny just no frame.Thanks
MARIO MEDEIROS is offline   Reply With Quote
Old 06-17-2011, 03:32 PM   #2
Goldy
Goldy's Avatar
Default Re: 45 motor in a trw frame?
No offense, but it sounds like your trying to stuff 20 gallons of shit into a ten gallon hat...could it be done - probably...should it be done - I doubt it.
But then again, nothing ventured, nothing gained.
This too shall pass.
Old 06-17-2011, 05:57 PM   #3
Apehanger Hank
Apehanger Hank's Avatar
I put a 45 motor and a preunit Triumph trans in a BSA A10 frame about 10 years ago. It was a tight fit. There's a book about 45 choppers in Europe (don't remember the name of the book) but most of them are some type of bitsa using the 45 motor and an english frame.
Hank
Old 06-17-2011, 06:28 PM   #4
chassy55
I've never done it, but I've heard tri. trans. in H.D. 45 was done often, think I've read about it in magazine tech articles.
chassy55 is offline   Reply With Quote
Old 06-17-2011, 06:36 PM   #5
servi53
servi53's Avatar
panhead and flathead site has a 45 in an ariel frame in the 45 projects section, looks pretty cool
servi53 is offline   Reply With Quote
Old 06-17-2011, 06:42 PM   #6
chopaweeza
chopaweeza's Avatar
Send a message via Yahoo to chopaweeza Send a message via Skype™ to chopaweeza
Over the years I've seen people squeeze 45's into pretty much anything from all nature of British frames to Jap , German and Russian .
But , I've seen a 45 a mate used to own and that was in a rigid 500 pre unit Triumph frame with most of the stock parts attached including transmission . A classic case of his Triumph motor died , he couldn;t afford the parts to repair it and the 45 was drafted into play . Supposedly a simple affair to do and it was claimed that two blokes did the conversion over a long weekend . Looked rough engineering wise but it worked well .
Chopaweeza Enterprises
Late model & Early model Bike and Parts Importer
http://www.chopaweeza.com
chopaweeza is online now   Reply With Quote
Old 06-17-2011, 08:20 PM   #7
BORED
I"ll try to find a pic of mine... 45 in a hardtail'd triumph frame, Norton Tranny, HD springer front end,HD 45 gas/oil tanks, jockey shift, Yamaha alloy high shouldered rims-Ha!
"I would never want to belong to a club that would have me as a member"
BORED is offline   Reply With Quote
Old 08-15-2011, 06:51 AM   #8
MARIO MEDEIROS
Still looking for a pic,seen a few 45 motors in Norton frames and a few in BSA A10 frames but no Triumphs .I can get a hold of a rigid 500 or 650 but i thought a trw would work best as i already have a triumph 4speed tranny.Thanks
Old 08-15-2011, 10:58 AM   #9
Englishman
Englishman's Avatar
Brewdude made his own frame for the 45 magnum.
Englishman is offline   Reply With Quote
Old 08-15-2011, 11:12 AM   #10
j chit
j chit's Avatar
Yea the trump trans and 45 is somewhat common. Seems to me it'll work just fine. Not easy im sure
j chit is offline   Reply With Quote
Old 08-15-2011, 01:30 PM   #11
danisdead
danisdead's Avatar
Hank
Whoa Hank, If you think of the name of this book...I need to know so I can hunt it down and own it.
Thanks-
sorry for the hi-jack
LTRRTC
danisdead is offline   Reply With Quote
Old 08-15-2011, 02:19 PM   #12
rustybill
I saw this a few years back at the Mass BIA show. Pics and info from:
http://www.massbia.com/bikes/paulduncan.htm
  • 1945 Harley-Davidson 45" flathead stroker
  • 53” with Indian Chief flywheels
  • Harley Davidson Model K cams “modified”
  • Combustion chambers are copies of Francis Clifford’s WLDR’s for racing with Black Diamond valves and 38 Mikuni carburetors, etc.
  • 1950’s Triumph Speed Twin frame with rear spring hub suspension and four speed transmission
  • Belt drive primary with Triumph alternator
rustybill is offline   Reply With Quote
Old 08-15-2011, 02:22 PM   #13
rustybill
I don't know much about the TRW frames, but I believe they are slightly smaller and there is less clearance in the head area than say a speedtwin frame. I spoke with a guy at a swapmeet this year who had a t110 engine in a trw frame, and said it was a tight squeeze clearing the rocker boxes.
Old 08-15-2011, 08:25 PM   #14
tombat
tombat's Avatar
[/QUOTE]
"I don't know much about the TRW frames, but I believe they are slightly smaller and there is less clearance in the head area than say a speedtwin frame. I spoke with a guy at a swapmeet this year who had a t110 engine in a trw frame, and said it was a tight squeeze clearing the rocker boxes. "
TRW and TR5 rigid frames are a "keystone" type where the front motor mount replaces the lower section of the front down tube and yes, they are tighter but you can stuff a 650 triumph engine in them, I have seen many photos of examples but not fortunate enough to see one up close in person yet. I have one each of TRW and a rigid TR5 frames but I have not attempted to stuff a 650 in either myself yet. I assume if you don't mind the possibility of cutting you could stuff a 45" in a TRW frame..... by the way, the one above looks like fun! Anyone know if it's still around?
Tombat
tombat is offline   Reply With Quote
