'82 Shovelhead woes...any advice? - The Jockey Journal Board
Old 06-06-2011, 12:26 PM   #1
jimmi
jimmi's Avatar
Default '82 Shovelhead woes...any advice?
I'll make it short. I've been working on finishing my buddy's bike while he's away fighting wars in Iraq and Afghanistan. I got it put together and wired and fired it up. Fresh engine and all. It ran great for a week or so. I upgraded to a very nice S7S carb. It then ran even better! Rode it nice and easy for another week, just slowly breaking in the engine. After a few weeks of babying it around, I felt it was ready for normal riding. I had my wife hop on the back and we rolled over to friends for a BBQ....
So that's when things went South. It started to miss a little, then got worse. Eventually it would't run except at idle. It stack fires and back fires from both cylinders. It can't get any RPM's without sounding like a barrage of cannonfire.
Well, I thought it might be the carb, so I went back to the CV and no change. Then I checked the intake boots. No leaks. I did a compression test and that's good. Pushrods seem to be adjusted properly as well. Points look good, but I can't remember if he had new ones in it when I got it from him. Points spark when running is blue and seems consistent?
I'm at a loss. Does anyone have any ideas? Anyone gone through this before? My friend is coming home for few weeks really soon and I'd love to have it ready for him to ride. Any and ALL help would be much appreciated.
jimmi is offline   Reply With Quote
Old 06-06-2011, 12:36 PM   #2
notcool
notcool's Avatar
Default Re: '82 Shovelhead woes...any advice?
oil to the topend??? exhaust valves sticking???
Love, Peace, and chicken grease.
Born-Free Show Blog
Freedom Machinery & Acc
notcool is offline   Reply With Quote
Old 06-06-2011, 12:40 PM   #3
Tha Nutz
Replace the coil and check your battery with a load tester. It may show that it is charged, but fail when a load is placed on it. I bet it's one of those two.
Tha Nutz is offline   Reply With Quote
Old 06-06-2011, 01:01 PM   #4
hogster
hogster's Avatar
Location: find the nicest trailer in the park,I live under it
I had the same sympyoms,turned out to be the coil ,it sporadically made hot enough good spark when it did the unburned fuel set off and created backfire,would run at idle but wouldnt make power cause coil didnt make enough spark,sounds similar .I suppose it may be voltage regulator ,or stator ,or condenser-points. the first thing to do is put new plugs in.hope it works out thanks for being a good friend to one of our finest and good luck
looking for a good re-tox facility
hogster is offline   Reply With Quote
Old 06-06-2011, 01:12 PM   #5
Loydo50
I agree with the coil. I just went through that. When the bike was cold it ran awesome...when at running temp it ran like crap. I replaced the coil and it improved dramatically. I also replaced the springs in my advance weights and new points. Totally different bike now. Runs and idles great when at running temp.
Loydo50 is offline   Reply With Quote
Old 06-06-2011, 01:17 PM   #6
Bodyworx
Bodyworx's Avatar
I completely agree. Definitely ignition related. Sounds like it's getting plenty of fuel.
Bodyworx is offline   Reply With Quote
Old 06-06-2011, 02:16 PM   #7
Buellbomb
Timing weights sticking? Does it have them?
My '79 would do that.
Buellbomb is offline   Reply With Quote
Old 06-06-2011, 03:32 PM   #8
jimmi
jimmi's Avatar
Timing weights not sticking. Coil has 4.3 ohms resistance which seems ok.
Old 06-06-2011, 04:02 PM   #9
beanie boy
Start with some new plugs, Autolite #4265 . I tried fancy pants plugs in my shovel and when they went bad, it was like the 4th of July coming out of my exhaust!
beanie boy is offline   Reply With Quote
Old 06-06-2011, 04:02 PM   #10
choke
choke's Avatar
spark plugs are a very good indicator of issues if you read em right, hopefully youve examined them already.
http://www.visegripaustin.com/
choke is offline   Reply With Quote
Old 06-06-2011, 04:26 PM   #11
hdshovel82
hdshovel82's Avatar
my coil on my 82 had a hair line crack in it caused the same problems but more under a load
hdshovel82 is offline   Reply With Quote
Old 06-06-2011, 04:33 PM   #12
jimmi
jimmi's Avatar
OK, I'm gonna go pick up some new plugs. I have an Accel supercoil, but it's a 4 ohm unit that I got for my Triumph, so I don't think that installing it on the Shovel is going to help me out. I will try to source a replacement coil locally, but if I strike out, does anyone have one I could buy? Just checking.
Thanks for all the advice and help to all of you. My friend is going to be stoked if I get it going. He's Special Forces and been through Hell and back. Seems the least I can do to get his machine rolling so he can blow off some stress and troubles with his knees in the breeze.
Old 06-06-2011, 04:46 PM   #13
Druid73
Druid73's Avatar
replace the condenser you must have converted it over to a points system ????? replace it condensers will do that after they get warm an start to break down, Been through that many a time
Beyond The After Life
Druid73 is offline   Reply With Quote
Old 06-06-2011, 04:51 PM   #14
jimmi
jimmi's Avatar
SUH-WEEET!!! I think I found the culprit. One lead going to the coil was frayed and grounding on the rear head!! This is so good. I'm very happy for my friend. Gonna go fix it up and fire it. Will check back and let you all know how it worked out.
Old 06-06-2011, 06:37 PM   #15
jimmi
jimmi's Avatar
Still doing it, but not as bad. Damnit. Better get those plugs and put the S&S back on it then see what happens.
Old 06-11-2011, 01:36 PM   #16
jimmi
jimmi's Avatar
To all concerned, it seems to be back to normal. Replaced the condenser, reset points gap, new plugs, reset timing and she fired up real nice. My buddy is gonna be stoked to ride again. Hell, anything is better than Ass-crack-istan. Thanks for all the advice and help.
Old 06-11-2011, 01:48 PM   #17
hogster
hogster's Avatar
Thats awesome man so glad it wasnt major congratulations.
Old 06-12-2011, 05:04 PM   #18
SpartanSPS
SpartanSPS's Avatar
jimmi, Grumpys cycle has a ton of shovelhead parts. I wish I could remember what town he's in but I know it's in Washington. he ran into a few huge lots of parts and stuff for sale on shovelhead.us all the time. If you need anything I'd give them a shout.
here is a link
http://customcyclesnorthwest.com/default.aspx
SpartanSPS is offline   Reply With Quote
Old 06-13-2011, 11:00 AM   #19
jimmi
jimmi's Avatar
Thanks, Spartan. I'll check it out. I'm having some issues with the clutch, so if I need anything I'll look him up.
