Risers for a 2006 Sportster - The Jockey Journal Board
Old 05-08-2011, 11:27 PM   #1
tbortnem
Default Risers for a 2006 Sportster
Hey I recently bought a 2006 Sportster and I am looking to make it more low profile. I want to put on some short risers and drag bars, but I am not sure how short of a riser I can put on there and still have the speedometer clear the gas tank. If anyone knows the shortest riser possible or has any ideas I would appreciate the help. Thanks guys.
tbortnem is offline   Reply With Quote
Old 05-09-2011, 12:55 PM   #2
the beeza kid
the beeza kid's Avatar
Default Re: Risers for a 2006 Sportster
Does the speedo bolt to the risers like this?
How would it interfere with the tank?
Ok, call me slow, but i'm still trying to figure out what, "Flammer" is. Is this a reference to ones sexuality????? - slim55g
DonovanSpeed.com
the beeza kid is offline   Reply With Quote
Old 05-11-2011, 07:54 AM   #3
tbortnem
No, my speedometer is below the handlebars and risers so if I put on short risers I'm not sure how low I can go without having to relocate the speedometer. Or it might miss the tank with short risers on too because the stock ones are bent towards the tank. I just wanted to see if anyone had tackled this problem before I go out and bought the risers and realized they wont work. Thanks again
Old 05-11-2011, 05:01 PM   #4
OGGandhi
I originally had the stock 1" risers on my sportster but it also came with the standard Bull horn bar.I replaced them with drag bars and 6" risers.You can go with the standard 1" risers,but you will be hunched over(good for 18yo),6" risers give you a straighter back.I'll show pics later tonight.
OGGandhi is offline   Reply With Quote
Old 05-16-2011, 10:33 AM   #5
tbortnem
Yeah any pictures would be great. Thanks guys
Old 05-16-2011, 10:45 AM   #6
berub9a2
berub9a2's Avatar
just flip it over, so the speedo is on top.
I have an 01 xl1200c, when i got it the previous owner put the speedo up top. When i changed the bars out i diddnt like the speedo up high so i just flipped the top clamp and popped the dummy lights out and flipped them.
berub9a2 is offline   Reply With Quote
Old 05-16-2011, 11:23 AM   #7
worn
worn's Avatar
I have a C and moved the speedo onto the the upper triple clamp with a Dyna speedo mount and a couple of 1" spacers. The holes in the Dyna bracket had to be opened up a bit to match those in the upper triple clamp.
worn is offline   Reply With Quote
Old 05-16-2011, 11:38 AM   #8
berub9a2
berub9a2's Avatar
Thats a good idea, i never thought of setting it up like that.
Do you happen to have any more pictures?
Old 05-16-2011, 12:25 PM   #9
elginyouth
elginyouth's Avatar
on my 94 I went with riserless bars...i guess you could call them t-drag bars? And used two 1 inch ness cable brackets to mount the speedo...hard to make it sound like it looks I guess. Ill post up some pics when I get back to the house today
my build thread
elginyouth is offline   Reply With Quote
Tags
risers, sportster
