#1 |
Need help any info, tips or pics for installing oil
pump timing it and timing the cams. The manuals arnt helpn. Thanks |
#2 |
www.xlforum.net should have the knowledge of which you desire.
The comfy 98' Heritage Softail The fast and soon to be gone 05' KTM 450 Supermoto The in pieces and soon to be chopped, bobbed, or whatever you want to call it 76 XLCH "This is gonna' be bigger than gold teeth!" -Billy Lane |
#3 |
Keep a couple things in mind. The cam timing uses the pinion gear timing mark (ignore where the flywheel and oil pump breather is). The oil pump uses the 40' advanced flywheel timing mark (ignore where the cam timing marks are). The info on the XLforum shows using the pinion timing for both.
#4 | |
#5 |
That sounds about right. Here's a couple shots showing the cams timed to the pinion, then the oil pump timed to the 40' flywheel mark.
Cams http://tinyurl.com/6kr5muc Pump http://tinyurl.com/6ad7cnj |
#6 |
Thanks for the info. Got it running solid.
| Display Modes | |
