1974 ironhead oil routing help!! - The Jockey Journal Board
Old 03-02-2011, 06:47 PM   #1
steven666
Default 1974 ironhead oil routing help!!
i know there is probably a million of these but im running an after market oil bag and all 3 fittings are on the bottom, i am also running a cooler and a after market oil filter, wondering if there was a good diagram or if someone had some input on it...?? thanks
steven666 is offline   Reply With Quote
Old 03-02-2011, 06:56 PM   #2
shovithead
shovithead's Avatar
Default Re: 1974 ironhead oil routing help!!
First you need to determine which hole is for what function. The fitting that is flush with the bottom of the tank, should be the supply. On most aftermarket tanks, the return will have a tube, that goes close to the top of the tank, with no restriction. The vent will usually have a restricted end and will also go near the top of the tank. The cooler and the filter is a looks/hose routing situation. I run my return to the filter first, then the cooler and then the tank. But you could do it opposite if the hoses were ugly as hell.
72 Chevy C30 truck
73 Custom Shovel
70 XLH
69 XLH
69 XLH *project*
68 XLCH *project*
68 XLCH *project*
66 FLH *Daily Rider*
66 Shovel/Pan/Pan*project*
65 XLCH *project*
60 XLCH*project*
51 FL *project*
Old 03-02-2011, 08:30 PM   #3
weezil
weezil's Avatar
Im gonna be running a remote oil filter on mine too.. You put the filter in the return line.. Routing it you want to just keep it simple, direct and away from anything movin' try to keep it tucked in too just in case you dump the bike in a parking lot 100 miles from home you won't screw a line up and leave you stranded.
The comfy
98' Heritage Softail
The fast and soon to be gone
05' KTM 450 Supermoto
The in pieces and soon to be chopped, bobbed, or whatever you want to call it
76 XLCH
"This is gonna' be bigger than gold teeth!"
-Billy Lane
weezil is offline   Reply With Quote
