Redesigning The 1956 Triumph - A Pre Unit Build by Alp - Page 13 - The Jockey Journal Board
Old 01-31-2012, 06:19 PM   #241
astek
astek's Avatar
Default Re: Redesigning The 1956 Triumph - A Pre Unit Build by Alp
I'm glad you liked my design, thanks a lot.. and bdavanza has all the key questions.
So i took these pictures for you bdavanza , i think they will answer your questions..
In my previous post you saw just the mock-up of my set-up.
The picture below is final and assembled. You are not going to see any welds, its all hidden underside.
You also see the steel spring seat which will protect the brass spacer, it has the same continous taper form and holds the spring in place.
The steel seat can be internal threaded or just kept in place with a cotter pin.
One item that is not in the picture is the leather gasket that will be under the brass spacer.
ALp
www.sungurtekin.com
Old 01-31-2012, 06:26 PM   #242
HCC
HCC's Avatar
Sweeeeet!
HCC is offline   Reply With Quote
Old 02-01-2012, 12:09 PM   #243
inkmunky
is the pin all that will be welded? then the brass used as an accent/spacer? Or will you braze the brass to the steel collar?
Either way inspiring details
71 Ironhead Sporty project... http://www.jockeyjournal.com/forum/s...3799&showall=1
inkmunky is offline   Reply With Quote
Old 02-01-2012, 06:02 PM   #244
crawler07
You have superb style ALp!
crawler07 is offline   Reply With Quote
Old 02-02-2012, 03:06 AM   #245
astek
astek's Avatar
Thanks a lot guys..
Yes, the brass spacer will stay like this, no brazing here, this way I keep the clean look.. What about you, now you're looking for a triumph project?
ALp
www.sungurtekin.com
Old 02-02-2012, 08:42 AM   #246
inkmunky
Any idea on the shearing force created by the downward motion of the seat? simply will that pin bend at the weld with the seat pressing down and back on it? I see it's undercut to build up weld and get the penetration, another thought would be chamfer the inside of the brass spacer and use a plain round rod then build up a filet weld where the chamfer will clear, should create a stronger joint.
or further still, countersink and chamfer the brass spacer and turn a rod with a larger OD on the bottom to distribute any forces over a wider area. Sorry the engineer side of me comes out.
Not to Hijack but yup may have found a candidate, this is for after the ironhead but a build on this motor that i haven't seen before i think will look really cool.
Old 02-02-2012, 12:46 PM   #247
astek
astek's Avatar
Have you seen the original spring mounts on the rigid triumph frames? Mine is kind of similar, I basically used the same dimensions, but instead of an external welded collar my rod runs through the frame directly.
And actually, the welds around the rod extend to 1” of a diameter and tapers upwards. So like you mentioned I had to countersunk the brass spacer to have a perfect fit, this added even more strength to my set-up.. What makes this design unique is that there are no exposed welds/braze, I can always adjust the dimensions of the components according to the needs of the project..
Appreciate your input inkmunky, looking forward for more updates on your ironhead..
ALp
www.sungurtekin.com
Old 02-02-2012, 05:22 PM   #248
inkmunky
I get it now, i didn't know you were going through the frame with the rod. Should hold up awesome that way, glad to see some people thinking stuff through!
Looks great keep it up!
Old 02-02-2012, 05:43 PM   #249
redtiger
redtiger's Avatar
Nice work!
redtiger is offline   Reply With Quote
Old 02-02-2012, 10:21 PM   #250
Black Knight 1
Black Knight 1's Avatar
That is pretty darn clever ! great work on those !
La critique est aisee mais L'art est difficil.
(Criticizing is easy but art is difficult)
Black Knight 1 is offline   Reply With Quote
Old 02-03-2012, 04:41 AM   #251
knallert
knallert's Avatar
Im very impressed by your work astek...
you make it look so easy, still I know how much time and thought that is required to make parts like that.. (not that i have the skill)
awesome is the word that comes to mind!
just fucking awesome!
now i cant wait to get in the garage and make stuff... hehe!
thanks for inspiring me. cheers // Kenneth
"Good judgment comes from experience. Unfortunately, the experience usually comes from bad judgment."
My build thread... Shovelhead -79
knallert is offline   Reply With Quote
Old 02-03-2012, 12:35 PM   #252
Dan Boy
Dan Boy's Avatar
Hey astek, if it's possible I would like to see how you cut the fish mouth on the brass pieces, they look so clean...
You do some great work, Dan
My completed Triumph build:
http://www.jockeyjournal.com/forum/s...ad.php?t=62358
My Website
Old 02-04-2012, 04:31 AM   #253
astek
astek's Avatar
Thank you guys,
I used my tube notcher, the same one that i made the frame.
Here you go,
ALp
www.sungurtekin.com
Old 02-06-2012, 07:21 PM   #254
astek
astek's Avatar
Within the last three days I built the clutch lever assembly. I designed and made it from scratch but kept the approximate standard geometry plus a safety ball. It seems to work very well..
ALp
www.sungurtekin.com
Old 02-06-2012, 07:26 PM   #255
Black Knight 1
Come on man ^^^^^^ Are you serious ????!!! I always thought everyone bought theirs.... You are making it hard for all of us mortals !
Old 02-06-2012, 07:47 PM   #256
Nottso
Nottso's Avatar
Damn, that's nice.
Welcome to the Church Of The Holy Cabbage. Lettuce pray.
For small, extremely clean, remote oil filters please see my new Jock Shop.
Nottso is offline   Reply With Quote
Old 02-06-2012, 07:50 PM   #257
Loffer
Loffer's Avatar
wow
Old 02-07-2012, 10:53 AM   #258
bdavanza
bdavanza's Avatar
Any disassembled pics? That's a sexy lever.
bdavanza is offline   Reply With Quote
Old 02-07-2012, 12:57 PM   #259
Dan Boy
Dan Boy's Avatar
^OMG, that is insane
My Website
Old 02-07-2012, 02:28 PM   #260
redasphalt3
redasphalt3's Avatar
Send a message via AIM to redasphalt3
Jesus!
redasphalt3 is offline   Reply With Quote
Tags
alp, build, pre unit, rigid, triumph
