Here is a question. - The Jockey Journal Board
Old 11-03-2010, 07:47 PM   #1
Link-Belt
Link-Belt's Avatar
Default Here is a question.
Alright, so back to my springer. Got this springer for a good deal. I plan on running it on my Triumph. I want to run a front brake since I've heard Triumph rear drum brakes suck. I've seen disk brakes on wishbone style springer but if you notice this is a straight leg style. Anyone know a set up I can run in such a narrow space?
Link-Belt is offline   Reply With Quote
Old 11-03-2010, 08:29 PM   #2
lilbill
lilbill's Avatar
Default Re: Here is a question.
back in the day we would put jap drum brake wheels in them
Hello, my name is LilBill and I'm a Chopaholic
The next time somebody pisses you off, just walk a mile in their shoes. That way you'll be a mile away from the bastard and you'll have his shoes
Old 11-03-2010, 08:34 PM   #3
slategrey
do you really need brakes??
slategrey is offline   Reply With Quote
Old 11-03-2010, 08:40 PM   #4
Loffer
Loffer's Avatar
I think one type are Honda xl wheels with the mini drums. The only thing most of them are 5/8" axel and your springer is probobly a 3/4" axel? I was talking with someone about this and we thought of using a bushing to make up the difference in axel size so you can just use the wheel/ axel as is and not have to mess with bearings and stuff. Then you just need a tab to keep the drum in place. Alot of the wheel are sold on ebay with brake cables with them.
Old 11-03-2010, 08:47 PM   #5
Dr. Benway
Moderator
Dr. Benway's Avatar
Maybe this sort of springer setup?
Old 11-03-2010, 08:49 PM   #6
Link-Belt
Link-Belt's Avatar
Thanks lilbill and Loffer, If I go with the drum in the front too that will keep it more 70's as well. Hmmm I wonder if the Triumph front drum brake will fit?
Old 11-03-2010, 09:17 PM   #7
Loffer
Loffer's Avatar
Fab Kevins got the mini disc with the caliper , bracket and hardware like the Dr. posted if you can fit that.
Old 11-03-2010, 09:19 PM   #8
justice66
I dont think the triumph brake will fit
justice66 is offline   Reply With Quote
Old 11-04-2010, 09:25 AM   #9
The Chop Shop
The Chop Shop's Avatar
Hallcraft Mini drum, or spool drum. That was the ticket back in the day, I guess. I have got one for sale. It is missing the internals, but is in pretty good shape.
When in doubt, Chop it out www.jeffersonchopshop.blogspot.com
The Chop Shop is offline   Reply With Quote
Old 11-04-2010, 12:40 PM   #10
Danny F.
Danny F.'s Avatar
Even a Hallcraft singel and dual disc front wheel will fit that Jammer narrow springer..
The setups I've seen at swapmeets are usually beaten up pretty bad..
Danny F. is offline   Reply With Quote
Old 11-04-2010, 12:50 PM   #11
Okiecockfighter
here is the hallcraft disc wheel . . looks like a spool on one side . . . you can use a little brake caliper like off of a racing go cart or something . . . I have this wheel and will be around dallas area this weekend . . . holler if you want me to throw it in the truck . . . its a 19 and it will clean up nice . . . will trade something your not using for it
I likes the way you talk . . .
http://stores.ebay.com/Oklahoma-Harley-parts?_rdc=1
Okiecockfighter is offline   Reply With Quote
Old 11-04-2010, 12:52 PM   #12
wompy5000
wompy5000's Avatar
Talk to Freddy Hernanandez from Freddy's Frames. He has just what you need.
wompy5000 is offline   Reply With Quote
Old 11-04-2010, 03:26 PM   #13
littlebike
littlebike's Avatar
Dr.Benway post is the way to go,for a disc set up I think that setup runs about 250-275$.I also wanted to run drums so I ended up with this. It's a 68-70 suzuki 21"wheel with a 2LS drum. It is 5" wide at the axle
holes and fits between the 5" wide Finch springer rockers
WWILD..
"If you can't afford to do it right, the first time,..what makes you think you can afford to do it twice".shovithead
littlebike is offline   Reply With Quote
Old 11-04-2010, 03:37 PM   #14
vorhese
Bultaco Bultaco Bultaco
1962 Triumph Bonneville Build
Need some pre-unit parts - Jockey Journal Wanted Ad
vorhese.blogspot.com - blog, follow my bike builds, new art, baby boy, and whatever else floats my boat.
vorhese is online now   Reply With Quote
Old 11-04-2010, 03:49 PM   #15
Lucky59
Lucky59's Avatar
http://www.360brake.com/itworks.html
Lucky59 is offline   Reply With Quote
Old 11-04-2010, 04:46 PM   #16
Link-Belt
Link-Belt's Avatar
Yeah right Lucky59 I guess I should have mentioned this is kinda a budget build. Plus in this economy not many folks can afford 1500 bucks for a brake.
Old 11-04-2010, 04:53 PM   #17
pelican
pelican's Avatar
Originally Posted by Lucky59 View Post
I like the idea of this, and definitely like how it looks. Heard a lot of bad things about them in use though.
pelican is offline   Reply With Quote
Old 11-04-2010, 05:07 PM   #18
Lucky59
Lucky59's Avatar
Me neither and probably wouldn't if I could, more of a FYI thing. If you already have a good hub and wheel to use adapting a disc to it would probably be cheapest way to go. I like big brakes myself, but some of this looks interesting if you just want something to help scrub off a little speed. I was looking at the last disc, but don't know the diameter and wouldn't use it if it weren't stainless. I thought someone was still making a Hallcraft style mini brake, but that would be big bucks too?
http://www.partsforscooters.com/All-...TV-Brake-Parts
Old 11-04-2010, 06:01 PM   #19
Lucky59
Lucky59's Avatar
Link-Belt
I just realized from your collection of parts in the pic you want to build something period correct? Well, I was around in the late 60s when the first disc brakes came out and no one liked the looks of them at all, took a long time for anyone to come around to them. There were a few people selling small mechanical discs, more of hill holder thing I think at the time. Triumph people would rather be shot than put Asian parts on their bikes back then, not to mention the 36 spoke hole thing/problem. As I recall it was a small Hallcraft brake or nothing on a Triumph chopper till at least 1975.
Old 11-04-2010, 06:06 PM   #20
Link-Belt
Link-Belt's Avatar
Thanks Lucky I got a few leads I am following up on.
Old 11-04-2010, 08:08 PM   #21
Dr mac
and get a steped bronze bushing . 3/4 od and whatever smaller id and just drill it out . check with the loacal hardware stores .
Dr mac is offline   Reply With Quote
