Stroking a big Flatty - The Jockey Journal Board
Old 09-24-2010, 08:04 AM   #1
69v700
Question Stroking a big Flatty
Been thinking on a UL/ULH stroker motor and I'm seeking any info/experience someone may have to share if they care to. How big can one go and what parts to use.I have access to machine tools and experience to operate so that might be a plus. My riding habits are pretty mild so it won't have to stand up to racing or high revs. I know there will be trade offs as with any Hi po mods. Maybe some one knows of a book or mag article on the subject I can hunt down? Thanks for your time and info.
69v700 is offline   Reply With Quote
Old 09-24-2010, 10:17 AM   #2
choptop37
Default Re: Stroking a big Flatty
I think truett still has stroker wheels
choptop37 is offline   Reply With Quote
Old 09-24-2010, 11:40 AM   #3
sLowrider
sLowrider's Avatar
Victory has T&O wheels listed up to 5" = 92 cubes.
http://victorylibrary.com/stroker-flywheels.htm
also a booklet on perfomance mods:
http://victorylibrary.com/80PER.htm
Lots of expertise on the FHP board too:
http://www.sscycle.com/tech/viewforu...dda2e7ebfa1153
Cheers Johnny
sLowrider is offline   Reply With Quote
Old 09-24-2010, 01:01 PM   #4
pzokes
pzokes's Avatar
You can buy Truett & Osborn flywheels direct from T&O. They will also balance and assemble them. I only find a PO box listed for Victory. I can't find any any balancing or assembly offered. Does anyone know of a shop that Victory has done any work in/at?
Some of the best flathead info is from "Frankenstien" http://www.freewebs.com/dicky_linn/index.htm
He's build stroker big twin flatheads and adapts Sportster oil pumps to make them live.
I'd talk to someone in person that has built a big twin stroker flathead before doing any performance modifications.
pzokes is offline   Reply With Quote
Old 09-24-2010, 04:45 PM   #5
Underworld stevo
Underworld stevo's Avatar
American Cycle Fab, Bloomsburg, PA are the ones to talk to.
http://www.americancyclefab.com/
Underworld stevo is offline   Reply With Quote
Old 09-24-2010, 10:53 PM   #6
pzokes
pzokes's Avatar
I'd like to find out more about what American Cycle Fab is doing. I think that they are changing the combustion chamber in the heads, and modifying the oil pump, but I can't verify it.
I'm putting together an 84" Flathead now. It's going to have "Frankenstein's" piston squirters and Sportster oil pump conversion. I've already had T&O balance and assemble a set of their flywheels for me.
Old 09-25-2010, 04:53 AM   #7
69v700
Thumbs up Re: Stroking a big Flatty
Thanks for the links and advice. I had a boss years ago that used corvair pistons to pump up his flatty back in the day. Said it ran the cylinders dull red at night till he got the carb and timing set right..."but man it would go"! He's passed on so can't get the details anymore and saw that mod mentioned in one of the links. Anyway thanks again, Ed J. in KS
Old 09-26-2010, 05:51 AM   #8
pzokes
pzokes's Avatar
On the Jalopy Journal site there is some up to date information on hopping up a Flathead V8 that also applies to a UL. A lot of theories on porting and relieving have changed over the years. The days of oversize ports on a street motor are in the past. High velocity small ports work a lot better in a street motor.
I did see some Victory pamplets on a table at a party that I was at, and did read them. I haven't bought any. He does produce a range of pamplets for Harleys and car motors.
The Corvair piston modification was in an Easyrider magazine, by another author, in the 80's. You can have any piston custom made by Ross and a few others, in lots of six. I have OEM compression plates, used for Mexican gas, that I'm using as stroker plates.
One of my friends that built a Flathead told me: "I never spent so much money to go so slow".
Old 09-26-2010, 01:46 PM   #9
jerseymutt
+1 on Paul's work and knowledge. I think the Corvair piston thing is outdated, there are better ways now. Paul is usually at the AMCA White Rose show and swap and it's a good place to pick his brain alittle if you get to the area.
Mutt
jerseymutt is offline   Reply With Quote
