evo motor fit to twin cam frame - The Jockey Journal Board
Old 07-16-2010, 05:53 PM   #1
camoback
camoback's Avatar
Default evo motor fit to twin cam frame
just wondering if a evo motor, tranny ect. will fit right into a twin came frame or is it all sorts of trouble. thanks
camoback is offline   Reply With Quote
Old 07-16-2010, 06:15 PM   #2
Wild Wade
Default Re: evo motor fit to twin cam frame
not even close.
Wild Wade is offline   Reply With Quote
Old 07-16-2010, 06:20 PM   #3
LightninMike
LightninMike's Avatar
Trouble.....unless you can fab,machine, and weld in which case its really easy
Insert witticism here
LightninMike is offline   Reply With Quote
Old 07-16-2010, 06:23 PM   #4
Wild Wade
Yeah, the steering head will work. The rest has to be made.
Old 07-16-2010, 06:41 PM   #5
low and slow
low and slow's Avatar
There are mounting plates you can buy that will allow an EVO to mount in a Twin Cam frame and vice versa.
low and slow is offline   Reply With Quote
Old 07-16-2010, 06:41 PM   #6
Destralo Roach
Moderator
Destralo Roach's Avatar
Depends on what kind of frame?? Dyna? then Yes, FLT? then Yes, Softail? Then NO!
........Roach.
Old 07-16-2010, 08:45 PM   #7
camoback
camoback's Avatar
cool, thanks. i found a softail roller for pretty cheap and was just toying with the idea.
Old 07-16-2010, 09:41 PM   #8
LightninMike
here's your mounts
http://www.network54.com/Forum/47852...mount+castings
