#1 |
my sporty tank is pretty rusty inside, and i dont want to cut it up.....at least not just yet. what's the best and easiest way to clean that rust out?
if it ain't broke, fix it till it is! |
#2 |
I've used nuts and washers with kerosene (not too much though). Shake it up pour it out, do it again till clean
#3 |
Fill it up with molassis and water (or coca cola syrup) and let it sit for a week. Pour out, clean with soap and wqter and it'll be good to go.
#4 |
I like muratic acid and water mixed 5 to one . Let it soak then rinse out with soapy water . then MEK to collect the moisture .
http://www.trumpnut.com |
#5 |
Email Scootermcrad, he just did one. Definately use a coating kit when you finish!
#6 |
Por15 - I've heard nothing but good things about it and plan on using it on a tank I've got.
http://www.por15.com/PRODUCTS/COMPLE...3/Default.aspx
hard wrenchin' knuckle draggin' guerilla warfare motorcycle mayhem
news. pics. video. builds. tech. Updated daily! www.knucklebusterinc.com |
#7 | |
TI_Tuesday
#8 |
[QUOTE=grail21]Por15 - I've heard nothing but good things about it and plan on using it on a tank I've got.
hmm. i've used por15 for my floor board on my 66 plymouth, but never thought about using it for a tank. hmm. does it work good inside a tank? that could save me some cash. i have a shit load of that stuff laying around.
Where'd I put my Keys??? HellBent Kustoms |
#9 |
I don't think they meant the regular por-15 paint. Por-15 has a specific gas tank sealer system.
#10 |
[quote=Shopshirt MoFo]
I don't think they meant the regular por-15 paint. Por-15 has a specific gas tank sealer system. [quote] POR 15 is great stuff. Follow directions and use plenty of the sealer. A little $$ but worth it. I sealed a tank with pinholes 2 years ago on a rigid mount. No problems.http://www.por15.com/bSPECIAL-Quart-...2&category=180 Damon |
#11 |
I like the muatic acid, but I was going to say..I've been told that you have to be really careful with the sealer because if it does not cover 100% of the inside of the tank, it will flake away in your tank. I've just used muratic acid and then kept gas in the tank at all times so it doesn't rust. and don't let it sit, you have to keep riding or it will rust again quickly. I've cleaned about four tanks and I finally came to my sences. Don't buy a kit for 30 dollars, just log onto flyritechoppers.com and buy a new sporty tank for like ..80 bucks.
On one tank I did, I used muratic acid on it and the flakes from the sealer started comming loose. It seemed impossible to clean, so I junked the tank.
thanks for the help. |
#12 |
Nuts and washers will do the trick.....if not maybe take it to a car radiator shop,they might be able to "boil" it out......
#13 |
On another board I use a guy showed pics of using a box of BB's. First he took off the petcock and taped the opening closed, used an old gas cap and poured in about half a box (small milk carton size). Wrapped the tank in a big comforter, then stuffed it in the ol lady's drier. He packed blankets around the tank so it would not move, then turned the drier on with NO HEAT. Let it run while he had a cpl of beers and the damn thing came out like new. Pretty fucking niffty. No solvents, no standing there shaking it till your arms fall of. And you still have amo for the rats donwn at the dump.
#14 |
Fastest, easiest, and cheapest way I've found is "The Works" bathroom cleaner. You can get it at the dollar store for around a buck and it cleans up with water. This stuff has some kind of acid in it because it will eat rust right off of metal in an hour or two.
#15 |
the molases trick works the best.and it's cheap. start of by cleaning off the scale with nuts and bolts..i use copper chain. then i use the molases....it works nicely. and dont fuck up your original paint.
#16 |
Would a quart of por-15 sealer be enough for a sporty tank??
#17 |
a cheap ass such as myself will try damn near anything once, molasses ,the works, bolts, but I know only from personal use the acid trick works on rusty steel ,also there is a gas tank lining sealer called creem,napa auto stores used to carry it ,great shit ,chheap holds up good,but be sure to follow instructions and make sure you dont seal off your petcock fitting,Dr.Frankensickle
#18 |
check out this link, going to try it on my 78 http://twinoak.altelco.net/~jacil/cl...ElecSetup.html
#19 |
I used vinegar and the POR 15 tank sealer. vinegar is just weak acid so it's the same as any other acid method, just takes longer and is easier on the skin.
Just make damn sure before you seal the tank that the interior is 100% dry. Any moisture will ruin the adhesion and it will gum up everything. |
#20 |
ive read some great things about a product called" rusteco " anyone used this stuff?
#21 |
I have used phospheric acid, available at Home Depot, with great results and absolutely no harm to paint. The acid will disolve the existing rust and leave a rust resistant "etch" on the inside of the tank. Expanding on the directions on the bottle: Pour the bottle of acid full strength into the tank and fill the rest of the tank with water (up to 2 gallons water with 1 quart of acid). The severity of the rust will determine the "soak" time. Usually overnight is sufficiant. Don't worry, you will not oversoak and damage the metal but you want to soak long enough to disolve the rust. I pour the dilluted acid into gallon milk jugs to save for later use. Allow the tank to air dry. The rusted areas will turn black and the rest of the surface will look chalky white. If the black areas are scaley, I will drop in a small handful of steel washers and agitate to break it loose. Remove the washers (magnet) and blow the dust out with compressed air. I do a final water rinse to neutralize the acid and flush out any remaining trash. I prefer to force dry the tank (air nozzle) to be sure that all the water is removed.
I have used this method many times and the most difficult part is being patient while the acid does it's job. I have done severely rusted tanks that required the acid full strength and I would rotate the tank every couple of hours for several days. Once the scale is removed and the tanks are water rinsed and dried, the the tanks can be put in service. I pressure test tanks that were severely rusted because of the possibility of pin holes. If neccessary, repair & seal (another catagory)
Steve Triplett Trinity Frame & Fab Dallas, Texas 214-475-0068 I don't have enough ammo to win but I can damn sure get on TV |
#22 |
I would go over all the welds,mounts, tank tabs etc. to make sure they are sturdy and mig or tig any that are shaky. Next Fit your tank to the frame. Shim a gap with a washer or spacer , Never try to draw a gap closed by overtightening a bolt and nut. Send it to North Cintry radiator in Queensbury, NY. ph# 800-244-1788 for their RENU gas tank sealing service. It last Forever as long as you don't apply heat to the tank. We send all our Taiwanese/aftermarket tanks to them before installing them. I haven't had one leak yet.
#23 |
I went to a "Triumph" friends house in KY to visit one day and buy some parts
I saw something strange in his back yard His RIDING MOWER was on jack stands RUNNING!!! in low gear attatched to the wheel with bungee cords was a Gas Tank slowly spinning I asked "What you doing? "Cleaning my tank" he said "with sharp gravel inside" I had to look inside WOW!!! No rust kinda of a "Redneck" way to do it But it sure works!! Last edited by Trichop; 09-11-2007 at 09:03 PM. |
| Display Modes | |
