#1 |
Can ya'll take a look and critique me on this? I've never wired up a bike, but have done a LOT of research. More than anything, I need to know Where I need What fuses. Do I appear to be missing anything? This is going on a '99 twin cam. The thunderheart ignition does away with all the factory harness/wiring and uses the crank position sensor to fire the plugs. Thanks a bunch.
#2 |
If ya have gear drive cams, or not, get the camcover conversion ingnition cover to run the Evo typ ing, it will save ya a lot of headachs, the Thunder Hart stuff is junk, just pure junk, I hate to rewire bikes that had the mod go bad, like under 2500 miles, some bikes were lucky to get ten thou out if it befor it went bad, and you either have to get onother unit, or rewire to bike, just my 2c. Roach.
The Road to success is covered by the Backs of Many! I chose the Hard way!!!! |
#3 |
Looks good. Isolate the ign. module away from the heat of the engine and it will be reliable. The cam cover conversion cost, will buy a bunch of modules.
#4 |
I don't have the gear driven cams and I already have the thunderheart, soooo that's not really an option. Thanks for the suggestion though. It's going to be mounted remotely from the engine, rather than paired with the coil and mounted where the horn went.
#5 | |
I found an older post from Irish Rich regarding how to wire one of these Pollak switches and made some minor changes.
#6 |
Looks like you've done your homework, and Dragon will be delighted to see that you used the "Search" function!
I don't know about the push the key for horn function. I would put the button on the bars, you don't have time to fumble for the key switch in an emergency and don't want one hand off the bars in an emergency situation. I have a couple small switches , one of which I am going to use for horn. They are tiny and flanged just drill a small hole in the bars and wire. I have the thunderheart ignition on a twin cam. Use the deutz connectors (the crimp tool is spendy!) if at all possible.
#7 |
Damn, I was hoping I'd be able to get around using the Deutsch connectors! Maybe I can borrow/rent the tool from a shop or something, it's just One connection. I'm still not 100% on fuses. Do I need one for the horn circuit? According to Rich I need one between Terminal A and the Thunderheart, what size? Seems like one should be between Terminal S and the starter, don't know. Like I said, never done this before, so I'm going into it kinda blind.
#8 |
20 amp for the A cercit. no fuse on the main starter wire, and use hevy gage.....Roach.
#9 |
I use a cheap d-sub crimper from radio shack for my Deutsch pins. Works great and never had one fall off.
http://www.radioshack.com/product/in...ductId=2103683 The diagram looks ok. I don't know if your ignition switch has 2 "on" positions but I set mine up so I can kill all the lights and still run the bike. In case I get a short in the lighting circuit, the bike will still run and get me home, (not that I would ever switch off the lights while riding to run in "stealth mode" ). I never run a horn, (clutch and rev works for me).
#10 | |
#11 |
Yeah, 12g should be fine, but Make shure its a good brand, dont skip on the wire.....Roach.
#12 | |
#13 |
The "proper" crimpers are always spendy. Designed for high volume manufacturing, not for Average Joe. You can also snip the connector off altogether and go with a couple bullet plugs or a different type of connector. Since the lighting is not on the same breaker as the ignition you'll be okay in that event. I wire my bikes up a little different and give the 'spensive-puter-trickery ignition modules their own breaker or fuse. It'll be covered by the 30A in your diagram but I like it separated from the starting circuit.
Mine's got a toggle switch under the tank for the lighting. |
#14 |
See, I couldn't understand why not just cut the connector off and use a more common type. I may do away with the one Deutsch connector altogether. How would I separate the ignition circuit from the starting any further than it is? Just by putting an inline fuse between the switch and ignition box?
#15 |
#16 | |
#17 |
^^ yeah, Cant go wrong!!!
#18 |
I agree about the Deutsch connectors. They are very nice.
I also agree on using good wire, I used This wire http://www.mcmaster.com/#7304k131/=5qyloe You can get away with a smaller gauge wire than conventional too. It is not cheap though. Last edited by nigel; 02-09-2010 at 07:33 PM. Reason: wrong link |
#19 |
if you have to extend wires make sure you use butt connectors with the shriktube hanging out the ends. before shrinking them fill the ends with silicone to get a tight seal this will prevent corrosion.
#20 |
This is all really helpful advice, I sure appreciate it.
| Display Modes | |
