shovelhead carb - The Jockey Journal Board
Old 01-14-2010, 07:56 PM   #1
ratcaddy65
ratcaddy65's Avatar
Default shovelhead carb
im trying to weigh my options for carbs for my shovel project been thinking about a dual throat or mabey a su im looking for style and function also im running short ass pipes let me know what ya think
ratcaddy65 is offline   Reply With Quote
Old 01-14-2010, 08:05 PM   #2
bforbes
Send a message via AIM to bforbes
Default Re: shovelhead carb
i just put a re-jetted cv on my ironhead, and its never run as good as it is now. iv got open pipes and a hi-flow filter.
BUY A HARLEY, IT WILL RUN FOREVER, AS LONG AS YOU KEEP FIXING IT.
bforbes is offline   Reply With Quote
Old 01-14-2010, 08:09 PM   #3
Loffer
Loffer's Avatar
Dual Amals with a downdraft mani.!
Old 01-14-2010, 08:14 PM   #4
shupe
shupe's Avatar
The CV on a Shovel is a great combo.
shupe is offline   Reply With Quote
Old 01-14-2010, 08:17 PM   #5
knuckle frank
i ran SU's for years and love them, a CV has a rubber diaphram that has a tendency to wear and get holes, especially in arizona where they have the winter blend that makes rubber components less flexible
knuckle frank is offline   Reply With Quote
Old 01-14-2010, 08:17 PM   #6
Destralo Roach
Moderator
Destralo Roach's Avatar
S&S super E.............Roach.
Old 01-14-2010, 08:39 PM   #7
lilbill
lilbill's Avatar
who's going to tune it ? it takes more than a little skill to get a non stock fuel delivery system to work properly, especially if there are other modifications to the engine. virtually anything can be physically mounted and made to work but not everybody is capable of doing it.
RIP SwedeBobb
Old 01-14-2010, 08:48 PM   #8
Art
Art's Avatar
Got a S&S on my 76 flh works great, just don't leave the enrichener on to long when you first start it, it fouls the plugs.
www.fastlanedecals.com
Art is offline   Reply With Quote
Old 01-14-2010, 08:51 PM   #9
gasketscraper
With short ass pipes its gonna run like shit no matter what you run. But the super E is probably the most user friendly carb to tune and install and most importantly START! I dig the SU I'm running, but it takes a little more tweaking and finessing to get right, and still doesn't start as well as a Super E.
gasketscraper is offline   Reply With Quote
Old 01-14-2010, 09:24 PM   #10
FearNoEvo
Nobody likes em and that's why there so cheap....Keihin with the andrews accelerator pump work just fine if you aren't trying to build a hot rod
FearNoEvo is offline   Reply With Quote
Old 01-14-2010, 09:46 PM   #11
mr haney
Run a 371 Hilborne Injected blower on it !
mr haney is offline   Reply With Quote
Old 01-14-2010, 09:59 PM   #12
gasketscraper
I know all about the lift plunger, know all about the tickler. I've owned 4 shovelheads and ironheads with the super E. All of them started first kick. Haven't seen any SUs can do that, and I'm not the only one in my riding circle thats running one. That said I love the way the fucker performs once its running. But the enrichner circuit and accelerator pump on the E is tits!
Old 01-14-2010, 10:35 PM   #13
ratcaddy65
ratcaddy65's Avatar
im going with a s&s e thanks
Old 01-15-2010, 12:36 AM   #14
caschnd1
caschnd1's Avatar
I've heard of that happening, but never experienced it with any of my CV carbs. I've got two that I've run long term. One has about 101K miles on it, the other has 70K miles.
-Craig
caschnd1 is offline   Reply With Quote
Old 01-15-2010, 05:50 AM   #15
Angelking
I run an SU on mine and it starts first kick everytime. As long as it has the right needle, no air leaks, adjusted points, timing set right and good compression, should start easily with no problems.
AK
Angelking is offline   Reply With Quote
Old 01-15-2010, 06:23 AM   #16
YETI CUSTOMS
just took the su of mine it poked out a bit two far have fitted a 42mm mikuni what a prick of a job but it on there now.
YETI CUSTOMS is offline   Reply With Quote
