how to wire a triumph pre unit with magneto? - The Jockey Journal Board
Old 01-02-2010, 09:57 PM   #1
76ratty
Default how to wire a triumph pre unit with magneto?
does anyone have a simple diagram for wiring a preunit with a mag.im only running a headlight and tail/brake light.No signals no extra crap.any help would be greatly appreciated.
"rock it till the wheels fall off "
76ratty is offline   Reply With Quote
Old 01-02-2010, 10:03 PM   #2
Necron99
Necron99's Avatar
Default Re: how to wire a triumph pre unit with magneto?
There are some options under "Simplified wiring diagrams" at the bottom of this page. http://www.britishcycle.com/help.htm
I did run my Norton with a mag and no battery. Problem is, at a stop light the rpm's drop and the lights almost go out. This can make your brake light appear to go out and you risk getting run over by some inattentive idiot in car. I eventually installed a tiny 12v industrial battery in my Norton. I tried capacitors to no avail.
Necron99 is offline   Reply With Quote
Old 01-02-2010, 10:04 PM   #3
lowbrowcustoms
lowbrowcustoms's Avatar
With the magneto your wiring circuit is totally separate. You have your stator wires that go to a rectifier (Podtronics or similar), your rectifier will then have a black and a red lead. One will be ground and one power, however you want to run it positive or negative ground. Just ground the one wire and run power to your headlight, tail light and running light and that is it!
Tyler
lowbrowcustoms is offline   Reply With Quote
Old 01-02-2010, 11:03 PM   #4
Tony the torch
Tony the torch's Avatar
Tyler
and put a fuse in it.... the Podtronic units are about $90
Old 01-02-2010, 11:18 PM   #5
Rubone
76ratty,
You didn't say if your pre-unit is generator or alternator. Hard to answer without that info, although there seems to be a lot of assumption so far!
Robbie
Rubone is offline   Reply With Quote
Old 01-02-2010, 11:49 PM   #6
Bozi
Bozi's Avatar
Podtronics makes unit for Genny, or altenator. 6v or 12v as well.
Sparx makes a neat regulator that is cone shaped & kinda mimics a Zender diode thatd be neat to use on that.
Painfully simple, wires from Genny/alt to regulator, regulator wires to batt.
Run a ground from batt to frame. Now run you power to lights thru a switch.
Run the power to your brake light thru a brake light switch.
Bozi is offline   Reply With Quote
Old 01-03-2010, 11:45 AM   #7
lowbrowcustoms
You can do it super simple. No battery necessary for the lighting, but you will then only have lights when bike is running. No switch needed for headlight, I just wire mine up to high beam only so it is always on when bike is running.
Tyler
Old 10-30-2011, 03:36 PM   #8
choppermrns
I've been doing some looking around on this topic and found a few replies, but still have questions.
I have an early T110 pre unit and want to run no battery and magnito as well, but I thought the dynamo/generator needed a battery to create a magnetic field to produce power. When I bought the bike it also had a capacitor, what's that used for???
Thanks for the help.
jonŽ
choppermrns is offline   Reply With Quote
Old 10-30-2011, 03:38 PM   #9
choppermrns
I've also seen alot of diagrams showing + going to the ground, does this mean the dynamo/generator will only work that way?
jonŽ
Old 10-30-2011, 03:47 PM   #10
Tony the torch
jonŽ
you could polarize the generator ether way but all the voltage regulators are positive ground.
Old 10-30-2011, 03:51 PM   #11
Tony the torch
jonŽ
a generator will work without a battery but it really helps to have one, it filters the power and makes the charging a lot easier on the generator as well as voltage spikes going to the lights.
A cap helps but a battery is best.
Old 11-06-2011, 09:14 AM   #12
choppermrns
I got a small 6v, how should I wire it in? And if I use a battery is the cap not needed?
Thanks!
Jon
Old 11-06-2011, 09:33 AM   #13
Tony the torch
Thanks!
Jon
a capacitor and a battery are the same thing, so you only need one or the other.
wire the battery with the positive (red) lead going the chassis ground, and the negative terminal gets the black (negative) wire from the voltage regulator and all the hot wires going to all the lights and stuff.
Just remember, on a positive ground bike, the "hot" wires are negative wires and they will fry if they short out to the frame.
Old 11-06-2011, 03:23 PM   #14
choppermrns
Tony,
Thanks for the help. Last question is for the mag wiring. The wire that comes from the cap of the mag that's used for the kill switch needs to ground to the frame also, correct? Would that make that wire the positive for the mag?
Old 11-06-2011, 04:22 PM   #15
Tony the torch
that wire only needs to be grounded when you want the bike to stop running,through a momentary contact switch, and stop thinking of it being positive, it's ground. so you are grounding out the magneto and stopping it from firing the plugs.
Old 11-06-2011, 05:34 PM   #16
Necron99
Necron99's Avatar
Your mag is a SEPARATE INDEPENDENT CIRCUIT.
The wire that comes off the mag is simply for the kill switch.
Old 11-06-2011, 09:06 PM   #17
choppermrns
Sounds good! Where in all this wiring is the best place to wire in a key switch for security? Could I use that as the kill switch too some how?
thanks for helping me out guys!
Old 11-06-2011, 09:15 PM   #18
Necron99
Necron99's Avatar
You will need a special ignition switch for a magneto, one that will be open in the "run" position and closed int he "off" position which is opposite of the normal ignition. I used a keyed switch from Cole Hersee part # 95539
http://www.colehersee.com/home/item/cat/94/95539/
Old 11-06-2011, 10:02 PM   #19
Tony the torch
an ignition key never really stopped any bike from being stolen.
what good is a keyed switch when all you have to do is disconnect the wire going to the magneto to start it.
Old 11-06-2011, 10:06 PM   #20
Necron99
Necron99's Avatar
Originally Posted by Tony the torch View Post
an ignition key never stopped any bike from being stolen.
Never said it would but it satisfies the insurance companies.
