Flathead replica springer problem - The Jockey Journal Board
Old 08-20-2009, 07:54 AM   #1
uwiik
Default Flathead replica springer problem
Hi all,
I am in the process of building my first semi custom bike (1997 heritage softail based).
I fitted a flathead springer replica on my bike (stock frame & springer length). Now everytime I apply front brake, the whole front end would try to fly up instead of diving like a normal shock would. The mech told me that all flathead replica have that tendency and it is normal. I personally dont like it and think it is dangerous. Is there any way to correct this tendency? Would fitting a friction ride control or shock absorber help?
Here is the specification of my suspension and tires:
F tire: 130/90/R16
R tire: 180/60/R16
Springer: 22" (bottom neck to bottom rear rocker hole)
Rear shock: stock height.
Thanks a million for taking the time to answer my questions, appreciate it.
uwiik is offline   Reply With Quote
Old 08-20-2009, 08:11 AM   #2
ironwigwam
ironwigwam's Avatar
Default Re: Flathead replica springer problem
And my names Rocky and I like your introduction? Did you apply the time machine as well?
1957 S/VG
ironwigwam is offline   Reply With Quote
Old 08-20-2009, 08:18 AM   #3
uwiik
Sorry LOL... I was so frustated with this problem today and was posting in a hurry. Please look at newbie section. once again sorry...
Old 08-20-2009, 08:23 AM   #4
Danny F.
Danny F.'s Avatar
A picture from that front end with fitted brake would help a lot...
Why do you say "flathead" replica..?
Danny F. is offline   Reply With Quote
Old 08-20-2009, 08:38 AM   #5
uwiik
Thanks for the reply.. Here is some pics of the front end.... I am suspecting they screwed up the spring tension, or wrong front fork length?? the rocker angle position looks too slanted...
Sorry the pics is not too clear, it was taken with a blackberry...
Old 08-20-2009, 08:39 AM   #6
uwiik
I called it flathead replica because it was made by some local guy who happen to be really good at welding and He use stock hydra glide springer for measurement and shape.
can anyone tell me how to display my picture in good size. Mine looks way too big...
Old 08-20-2009, 08:52 AM   #7
Danny F.
Danny F.'s Avatar
No pictures yet..only 2 red stars are visible for me...mail me those pics now.. danny.hd@skynet.be
A Hydra-Glide has a Glide front end, not a springer, but I think you are just mistaken names here..
Old 08-20-2009, 08:57 AM   #8
uwiik
Thanks a million for the heads up, I will try to fix the image.Yes I am mistaken. I meant early panhead with springer forks. Pictures sent to your email.
Old 08-20-2009, 09:04 AM   #9
uwiik
I hope the pictures showing now...
Old 08-20-2009, 09:04 AM   #10
uwiik
Old 08-20-2009, 09:07 AM   #11
michaelbarry
Is it just me..or do those front legs look tweaked? May just be my eyes playing tricks on me with the angle of the pics.
michaelbarry is offline   Reply With Quote
Old 08-20-2009, 09:11 AM   #12
uwiik
No it is not tweaked. I have tried riding with it and it runs fine. The only problem is the extreme upward front end stop whenever I applied front brake. It feels like I am about to get thrown over the handlebar. I could only use the rear brake...
Old 08-20-2009, 09:11 AM   #13
Hoat69
hard to tell with those aweful pics and weird angles
Hoat69 is offline   Reply With Quote
Old 08-20-2009, 09:15 AM   #14
uwiik
I'll take better pics tomorrow and post it..
Old 08-20-2009, 09:23 AM   #15
Danny F.
Danny F.'s Avatar
Geometry from anchor rod should be looked after again...and make sure everything is working "loose" with the correct bushings at pivot points... when the frontend comes up while braking it usually means something is "to tight" that should be not tight at all...
Also read this..
http://www.jockeyjournal.com/forum/s...ont+brake+stay
Old 08-20-2009, 09:26 AM   #16
uwiik
after comparing to so many different springer pictures, I noticed that the rebound spring (upper spring) is not compressed enough, so maybe when I applied front brake the momentum of the bike forced the front end to retract upward instead of diving because there is not enough pressure from the rebound spring..... Am I correct???
Old 08-20-2009, 09:27 AM   #17
uwiik
Ok I will check with the rebound spring factor and "too tight" factor somewhere in the joint..
Old 08-20-2009, 10:23 AM   #18
agarden
Hey uwiik,
I just got done working out similar problems on my springer, although my setup is using a front drum. I think this is what is causing your problem:
Think of your front end as a parallelogram. two sides are the two fork legs on your springer. One side is the line from your rocker bolt to your axle. The final side is the line from your brake stay fork anchor and the brake stay disc anchor.
The fork sides of the parallelogram are parallel naturally as your springer was built that way. It is CRITICAL that you brake stay and rocker are parallel.
If they aren't then you will experience very odd behavior when you apply your brakes. What exactly will depend on what type of misalignment you have. In your case, when you apply the front brake, the forward rotational force of your wheel will put huge load on your brake stay and that force will be transferred to your springer leg then compressing your springs.
If your brake stay is parallel to your rocker then the regardless of your front-end movement they will remain parallel and the force applied to your brake stay when you apply the brake will be pulling "straight" on your fork leg and will prevent your brake from rotating, thus keeping your front-end true.
Hope that makes sense! I don't have time to sketch out diagrams for you this morning but if you're still stuck I'll cad it out later today.
agarden is offline   Reply With Quote
Old 08-20-2009, 10:33 AM   #19
Dragstews
The brake mount to the axle must float on the axle....Make sure that it does.
Old 08-20-2009, 10:43 AM   #20
panhead_pete
You guys made that front end from scratch? Cool.
Old 08-20-2009, 11:10 AM   #21
little d
little d's Avatar
+1 on what agarden said, here is a pic of a stock stay on a springer. look at how it runs parallel with the rocker.
Old 08-20-2009, 01:24 PM   #22
LTW
LTW's Avatar
that brake stay/rocker parallel thing makes sense. seeing your home built springer is inspiring, but maybe you could move that anchor for the brake stay on the rear leg up towards the stem a bit. that should make the brake stay rod jut out parallel to the rocker. the fact that the stay rod is currently pointing up, away from the rocker would explain why you get that rising sensation when you brake.
good luck.
LTW is offline   Reply With Quote
Old 08-20-2009, 02:30 PM   #23
BORED
[quote=Danny F.;521309]Geometry from anchor rod should be looked after again...and make sure everything is working "loose" with the correct bushings at pivot points... when the frontend comes up while braking it usually means something is "to tight" that should be not tight at all...
...What Danny F said, I think the Anchor rod geonetry he refers to are the pivot point on front of the rocker and axle point in relation to the rear pivot point on the rear springer leg"anchor" To "Rock" the front pivot point should be 1/8 to 1/4" higher (measruring vertically from the ground when the bike is standing with the wheel straight. If not, that combined with the nuts too tight or improper bushing fitmit, size, greasing can make the bike "Pogo" when it hits a bump on in breaking. Instead of the rocker "rocking" and compressing springs it "drives" the whole front end upward...or at least that 's what happended on mine.
ted
"I would never want to belong to a club that would have me as a member"
BORED is offline   Reply With Quote
Old 08-20-2009, 04:43 PM   #24
ampdesign
ampdesign's Avatar
I think everyone is looking to much into this problem, is it me or do those springs look like they are not compressed at all. If you press down on your bike, is the front end real squishy? It looks like both the top and bottom springs need to be tighter, or "pre loaded" so that its not so loose.
ampdesign is offline   Reply With Quote
Old 08-20-2009, 07:38 PM   #25
Destralo Roach
Moderator
Destralo Roach's Avatar
All springers will post up when ya hit the front break, if you dont like it, put the Hydraglide back on, only Hydraglides dive when ya hit the break....Roach.
Old 08-21-2009, 01:15 AM   #26
geasy$
geasy$'s Avatar
Move the brake stay up on the back leg as stated several times already. The rod should be parallel to the ground. As it sits, when you apply the brake, the reaction you are feeling is from the rod, as it is being pulled foreward, it wants to "level out". If the rod was already parallel to the ground, it would be pulled foreward, instead of UP, which in turn forces the back leg UP, and you feel the bike going UP, as you brake.
Hope that explains it a little better.
Support Your Local Jockey Shifters............OG
"I hope I don't poop before we get home" ........BFG
geasy$ is offline   Reply With Quote
