Best donor bike - The Jockey Journal Board
Old 07-13-2009, 06:18 PM   #1
peterdallan
Default Best donor bike
Hi,
Going through this forum, virtually all the Triumphs feature a non duplex frame. Is this just for styling or because they are more plentiful. I would like to build a Triumph bobber style bike, is there an 'ideal' donor bike to base the build off?
cheers
Peter
peterdallan is offline   Reply With Quote
Old 07-13-2009, 06:26 PM   #2
Dragon
Dragon's Avatar
Default Re: Best donor bike
If you mean "duplex" in the purely traditional sense, as in the one Triumph used from 1960-'62.....well, the oil-bearing frames started in '71 with "duplex" dual downtubes.
And those oil-frames can be fitted with weld-on rear section, or easily cleaned up for a swingarm custom. I suppose "bobbing" is in the eye of the beholder, these days.
But yes the most common 650 '63 - '70 frames were single-downtube.
Dragon is offline   Reply With Quote
Old 07-14-2009, 03:40 AM   #3
peterdallan
This is the frame I am looking at.
Any thoughts to suitability?
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=330343526536
Peter
Old 07-14-2009, 07:58 AM   #4
Gordo-uk
Gordo-uk's Avatar
Peter
It depends what you want to end up with. The number plate chasers are on it already so it will go for a fair bit more. Why not get a single downtube and a letter from the science museum or owners club for dating for a quater of the price?
Gordo-uk is offline   Reply With Quote
Old 07-14-2009, 08:49 AM   #5
M.O.Ther
M.O.Ther's Avatar
Just an opinion, but I would think you would be a lot better off starting with a complete motorcycle. Starting with just a frame will nickle and dime (or pence and pound) you to death and you'll spend A LOT more money in the end.
If some is good, then more is better, and too much is just about right.
Old 07-14-2009, 09:02 AM   #6
rukwikenuf
rukwikenuf's Avatar
i agree with M.O.ther, i'd start with a complete, running bike, unless you've done this before. i'm guessing you HAVEN'T done this before, judging by your inquiry. and there's nothing wrong with that.
if it ain't broke, fix it till it is!
rukwikenuf is offline   Reply With Quote
Old 07-14-2009, 09:32 AM   #7
peterdallan
Hi,
Thanks for the advice. I will go along the route you suggest and look for a complete bike.
Question, and I know this is subjective, but is there a model that has particularily lent itself well to a bobber conversion, assuming not too bothered whether unit or pre unit?
Peter
Old 07-14-2009, 11:31 AM   #8
speedfiend
speedfiend's Avatar
I agree about starting w/ a complete bike. As far as an ideal donor, well there are alot of opions. Pre-units are expensiveto buy and to rebuild. For unit construction (pre OIF's) 69 and 70 are great, but pricey. To save alot of dough, look for an OIF model. They're not as collectable, so they're alot more affordable. And they're more pleantiful. But they do require a weld on hard atil instead of the bolt on varity available for pre-OIF's. Also, TR6's (single carb heads)Trophys and Tigers tend to be a little cheaper then the more famous Bonnivilles. I've never found the performance to be noticably diffrent, infact the single carbs produce more bottom end torque. And they're eaiser to tune. Check out the OIF thread for some ideas. Oh, one more thing. The trans on 71 and 72 uses a leaf spring for the index instead of plungers. They suck to work on! And, the early 5 speeds(73-74) had issues with jumping out of gear and poor shifting, But don't let this scare you away from one these bikes if the deal is good, they can be made to work properly. So for my money I would look for a 76-79, 750cc.if you don't mind that they shift on the wrong side. Plus they have disc brakes.
speedfiend is offline   Reply With Quote
Old 07-14-2009, 01:44 PM   #9
6T Sinner
6T Sinner's Avatar
Read this please:
http://www.jockeyjournal.com/forum/s...h+build+bobber
This guide will get you started right.
6T Sinner is offline   Reply With Quote
Old 07-14-2009, 02:26 PM   #10
peterdallan
cheers everyone, food for thought there.
Appreciate it.
Old 07-14-2009, 03:27 PM   #11
Destralo Roach
Moderator
Destralo Roach's Avatar
Originally Posted by 6T Sinner View Post
Read this please:
Nice one, when ya getting back up this way????
And remember that 80% of all britt bike got sent out of England, so finding a doner will be tough, I only seen a few when I was there back in the 80's....Roach.
Old 07-14-2009, 11:52 PM   #12
6T Sinner
6T Sinner's Avatar
Roach,
No plans for heading North as of yet. The damn weather here is too nice! My Triumph's still in a million pieces but looks promising. As soon as it starts coming together I'll let you in on my photos... Keep the faith!
Old 07-15-2009, 12:00 AM   #13
daytonabobber69
daytonabobber69's Avatar
Lets not forget time....... which alot of us lack!
Amost Finished!!!
daytonabobber69 is offline   Reply With Quote
