The Jockey Journal Board
Register  |  Calendar  |  Members List  |  Search  |  FAQ
Thread Tools Display Modes
Old 01-03-2009, 02:21 PM   #1
whizzerick
whizzerick's Avatar
Status: whizzerick is offline
Default Tech: a REAR wheel speedo drive
Local code requires a working speedometer, as per OEM in 1974.
Since I'm running an early Sporty drum instead of the original single disk (1), I can't use the '74's speedo drive/spacer up front.
Besides, I don’t want to clutter the front end with a cable and a speedo. I fabricated a bracket and installed the speedo to the left of my seat (2).
Instead, I thought I could use the rear wheel to drive the speedometer. There is ample room on the left side (3).
With a BFH in a vise, I cracked open the original speedo drive, revealing the precious inner elements that will be used in the project (4).
I carefully measured everything (5), and essentially reverse-engineered a new speedo drive/spacer from the parameters of the original (6).
Using basic woodworking tools (7), I built a casting pattern that will provide a 'blank' for machining the drive/spacer (8).
Menu board letters are added forming the AMF anagram, to stump the HD experts as to the origin of the part ... (9).
The pattern is painted, 'gating' is added (10).
Because of the shape of the work, a follower has to be prepared out of plaster and plywood. We are ready to cast (11).
www.royalspeed.com
Old 01-03-2009, 02:23 PM   #2
whizzerick
whizzerick's Avatar
Default Re: Tech: a REAR wheel speedo drive
I cast a blank in beautiful yellow brass, a strong alloy with a very high machinability index (12).
And machined away (13). This is all very new to me, and I'm learning as I go.
Everything went according to plan (14). I will probably have to bend the tang of the drive's 'arm' upon assembly to seat it in the hub's recess.
(To account for the reduction in wheel circumference (94,72%), the speedo face will be re-calibrated with additional spacing between numerals) (15).
www.royalspeed.com
Old 01-03-2009, 02:31 PM   #3
CB550 Matt
CB550 Matt's Avatar
Status: CB550 Matt is offline
nice fab work, you get out to ride test it yet?
Old 01-03-2009, 02:32 PM   #4
littlebike
littlebike's Avatar
Status: littlebike is offline
Hot Dam, You got some major Skills, but you know that .Awesome!!
WWILD
Old 01-03-2009, 02:39 PM   #5
NaK
Status: NaK is offline
Holy shit. I can't get enough of this type of stuff.
www.nakstudio.blogspot.com
Old 01-03-2009, 02:41 PM   #6
whizzerick
whizzerick's Avatar
I wish... This is a pic of my backyard at 5 am this morning.
That glow is from my inground pool fence lighting...
www.royalspeed.com
Old 01-03-2009, 03:54 PM   #7
chip
Status: chip is offline
Holy shit, southern boy here. I have never been in snow that deep. Don't think I would like it much. I'm already jonesin for spring and summer. I cant stand the short gray days of winter.
The speedo drive is nice work.
Old 01-03-2009, 04:25 PM   #8
zboy403
Status: zboy403 is offline
I'm very very impressed! Nice fabbing!
Old 01-03-2009, 04:37 PM   #9
Bumpstick
Bumpstick's Avatar
Status: Bumpstick is offline
Beautiful!!!!
Old 01-03-2009, 04:52 PM   #10
ElkCreek
ElkCreek's Avatar
Status: ElkCreek is offline
Awsome post! Thanks a ton. I suck at Math, so Im out...But The casting principal is something I will try with less "precision" required parts. Good to see how little it really requires to produce a one-off part. NO CNC's!! Basic tools. Cool Shit!! 20 feet of snow outside helps too!!
Illegitimi Non Carborundum
( Dont Let The Bastards Grind Ya Down)
Thread Tools
Copyright 2007: Atomic Industry.
Powered by vBulletin. Copyright © 2000-2007 Jelsoft Enterprises Limited.
