triumph neck bearings - The Jockey Journal Board
Old 11-05-2008, 12:01 AM   #1
Triumphteer
Triumphteer's Avatar
Default triumph neck bearings
i have a '69 triple and fork set up with a '65 frame. i am planning on buying a new set of tapered roller bearings to slip in there to replace the older style cup bearings.....am i going to be o.k.?? i am 90% sure, but once i was 90% sure i found the right girl to marry too.
so i think i need some assurance or a kick in the head to be completely sure or completely unsure, whatever the case may be. any expert advice or pictures of single female friends would be appriciated.
thanks.
Triumphteer is offline   Reply With Quote
Old 11-05-2008, 12:07 AM   #2
big_b
big_b's Avatar
Default Re: triumph neck bearings
i think you should be good with the bearing setup. if i remember right it wasnt till the 70's that they changed stem size.
big_b is offline   Reply With Quote
Old 11-05-2008, 12:11 AM   #3
Triumphteer
thanks for the reply, but no way is she single!! really?
Old 11-05-2008, 12:14 AM   #4
joes bakery
joes bakery's Avatar
LMAO ...... careful what you ask for .... you could drink her pretty
joes bakery is offline   Reply With Quote
Old 11-05-2008, 02:27 AM   #5
La Dolce
La Dolce's Avatar
Not sure if it is me but I think you need to install new races to hold the tapered bearings. I am putting a 71 tree onto a 65 frame I have new races but I don't know their name. I don't think the issue is stem size, it's needing the race. Hopefully the next guy will clear this up.
If a deal don't end in a hand shake than it ain't a good deal!
La Dolce is offline   Reply With Quote
Old 11-05-2008, 09:42 AM   #6
Triumphteer
and the plot thickens........
Old 11-05-2008, 10:02 AM   #7
JEKYL JOOZ
That one would take a powerfull lot of drink'in........BUT;.I ain't in the habit of turning it down.
JEKYL JOOZ is offline   Reply With Quote
Old 11-05-2008, 10:36 AM   #8
Dragon
Dragon's Avatar
You want the complete conversion kit, with the taper bearings and races. The races have a shim/sleeve that fits them into the pre-oil frame. Need the whole kit.
http://www.raskcycle.com/cgi-bin/car...=Fork+Bearings (first item)
Dragon is offline   Reply With Quote
Old 11-05-2008, 10:48 AM   #9
vicious
vicious's Avatar
i have a '74 fork and a '69 frame
i bought a conversion kit for the frame with the intention of buying differnt bearings to fit the fork
would a stem spacer be a better approach and shim the stem to the bearing i.d.
thanks
normal is a setting on the washing machine
vicious is offline   Reply With Quote
Old 11-05-2008, 11:21 AM   #10
Dragon
Dragon's Avatar
thanks
In this case, I would take the bearing from the kit and a bearing from a stock oil-frame (or the stem) to a bearing house.
Have them match the o.d. of the kit bearing & the i.d. of the o.i.f. bearing with a new bearing for your combo, rather than fabbing/adding a new part like a sleeve or shim.
Old 11-05-2008, 12:38 PM   #11
B.M.G.
B.M.G.'s Avatar
65 bonneville frame, DNA springer. when i switched i used this:
http://britcycle.com/Products/99/99_3733a.htm
worked like a champ. . . . .
peace.. B.M.G.
B.M.G. is offline   Reply With Quote
Old 11-05-2008, 05:08 PM   #12
Daddy Boy
What Dragon says MAY be easier said than done about finding bearings to fit a 73 f/e to a 69 frame, I did it decades ago as a kid and the same tapered rollers are still going strong, they have dust seals too, but needed a sleeve turned up for the OD of the bearing shell. To totally keep out the crap, stuff some foam in the frame.
Old 11-14-2008, 09:47 AM   #13
vicious
vicious's Avatar
went to bearing house and they said that they do not make a bearing with the 1.9800 od (69 frame) and .750 id (74 neck)
second thought was get a pre 70 neck but is the tube diameter of the pre 70 fork tube the same 35mm?? if so wouldn't this be the simple answer??
Old 11-14-2008, 06:23 PM   #14
Daddy Boy
Google SRM Engineering in England, they make bearings for this purpose for 73 tri f/end to fit 60's Beeza frames, so if a BSA gooseneck is the same as early trump you could have an in there Vicious.
Old 11-14-2008, 06:49 PM   #15
hillbillyhell
hillbillyhell's Avatar
The race OD for a pre 71 is more like 2.090"..not 1.98". This is why all the tapered roller conversions have a sleeve shrunk onto the OD of the race (they start with a 2.0" OD race)
IIRC, if you just order a pre 70 conversion kit and a set of 71+ bearings, you're good to go.
hillbillyhell is offline   Reply With Quote
Old 11-23-2008, 08:49 AM   #16
vicious
vicious's Avatar
bought a 69 stem saturday and solved the whole issue.
thanks
