Acme Choppers Springer front end and Custom frames - Jockey journal special - The Jockey Journal Board
Go Back   The Jockey Journal Board > The Jockey Journal Marketplace > Jock Shops
Old 09-17-2008, 01:54 PM   #1
fltchop
Default Acme Choppers Springer front end and Custom frames - Jockey journal special
*Custom springer front ends*
SUPERIOR QUALITY, WE USE ONLY THE BEST PARTS AND MATERIALS
...including:
*.188 wall thickness DOM tubing on rear legs*
*3/4" solid front legs*
*Stainless steel spring rods*
*Progressive rate inner and outer springs (8 springs per front end)*
*Delron spring rod isolators*
*Highest quality chrome hardware (Gardner-Wescott)*
*Timken-Torrington needle roller bearing lower rockers*
*CNC MACHINED PARTS*
*FULLY RADIUSED EDGES*
*ALL PARTS ARE PRECISION TIG WELDED AND FULLY COOLED IN FIXTURE BEFORE ASSEMBLY*
*YOU MUST MEASURE WHAT LENGTH FRONT END YOU NEED,
MAKING SURE TO TAKE INTO ACCOUNT ENGINE/TRANSMISSION AND RIDER WEIGHT
MEASURE FROM THE BOTTOM OF NECK TUBE (LOWEST POINT) TO CENTER OF AXLE (incluing tire height)
*available in wide or narrow configuration*
***available in chrome or powdercoat for additional charge***
our normal retail on these is twelve hundred bucks...
$1000.00 SHIPPED (lower 48)
fltchop is offline   Reply With Quote
Old 03-25-2012, 09:24 PM   #2
the beeza kid
the beeza kid's Avatar
Default Re: Acme Choppers Springer front end and Custom frames - Jockey journal special
This thread is old as shit, but I just got a pair of T bars from these guys and they are top notch. The quality is great and the prices are very reasonable. Nice guys and quality work.
Ok, call me slow, but i'm still trying to figure out what, "Flammer" is. Is this a reference to ones sexuality????? - slim55g
DonovanSpeed.com
the beeza kid is offline   Reply With Quote
Old 03-26-2012, 12:25 AM   #3
fifty
fifty's Avatar
are ya all open to doing a JJ frame deal>????
http://fiftyshaze.blogspot.com/
fifty is offline   Reply With Quote
Old 08-29-2013, 07:37 PM   #4
tomsoftail
tomsoftail's Avatar
i wish this deal was still available but the op isnt active no more.
Old 08-29-2013, 07:50 PM   #5
HD48FL
Super Moderator
Yeah that is a really old post and the op hasn't been here in a long time either. You could contact them directly though.
HTML code is Off
