What weight and brand oil for a Shovelhead? - The Jockey Journal Board
Old 07-27-2008, 08:14 PM   #1
Bugman
Bugman's Avatar
Default What weight and brand oil for a Shovelhead?
I searched and didn't really find the answer I was looking for. I've got a '77 74 CI Shovelhead, fairly recent rebuild(I'd say no more than 4,000 miles ago), and solid lifters. Most of my riding is at highway speeds. I've always used Harley brand 20W-50(cause I worked at a dealer and it was cheap). Now that I have to actually buy my own oil, I was wondering if there was something I should be using instead. It leaks a bit(and I'm a cheap bastard), so I don't want to use a synthetic. Are there any brands you'd recomend? Should I use the "specifically formulated for air cooled engines" stuff, or will regular oil do? What weight should I be using? Thanks for the help.
I'm a bad ass hardcore biker. Ok, maybe not bad ass, but definatly hardcore. Well, not even that hardcore really....does it look like it might rain to you?
Bugman is offline   Reply With Quote
Old 07-27-2008, 08:22 PM   #2
blackcrown
blackcrown's Avatar
Default Re: What weight and brand oil for a Shovelhead?
50w.
an intelligent man wins his battles with pointed sticks...I'm sorry, I meant words...pointed words.
http://mrcrownsmotorservice.wordpress.com/
blackcrown is offline   Reply With Quote
Old 07-27-2008, 08:24 PM   #3
ampdesign
ampdesign's Avatar
I use 60w, but that is just what i have used on my shovel and its been working out good for the last 2 years.
ampdesign is offline   Reply With Quote
Old 07-27-2008, 08:32 PM   #4
bigdeze
bigdeze's Avatar
Amsoil 60w.
If you find yourself in a fair fight, your tactics suck!
http://www.myspace.com/bigdeze75
bigdeze is offline   Reply With Quote
Old 07-27-2008, 08:32 PM   #5
Larry T
Larry T's Avatar
Different weight for different conditions. The service manual breaks it down. Readers Digest version, 60 wt. when it's hot, 50 Wt. when it's not. Even thinner oil when it's too cold to ride. ;^).
Larry T
My old Panhead build: http://www.jockeyjournal.com/forum/s...ead.php?t=9455
Occasionally updated Knucklehead project: http://www.jockeyjournal.com/forum/a...p?albumid=3625
Old 07-27-2008, 09:05 PM   #6
dan r
dan r's Avatar
i see your across that big lake from me so i would guess your weather conditions are more or less the same as mine.
shovels are not that friendly with multi weights except for winter use or short trips.
synthetics just heat up and turn piss thin.
synthetics may lube better but if it's to thin to pump...
my 70 hated synthetics after about 10 miles.
i run 50W Valvoline in cooler temps and 60W when it's hot like today.
for extended highway use maybe a small shot (only a few ounces) of that Lucas oil goop at high temps.
if you had hydraulic tappets that shovel would tell you when the oil is to thin.
dan r is offline   Reply With Quote
Old 07-27-2008, 09:47 PM   #7
bustedlifter
I run 60w Valvoline in summer and 20-50 all other times of the year.
Old 07-27-2008, 10:58 PM   #8
motomotard
motomotard's Avatar
ive been running 20-50w in my ironhead. whats the difference between that and a straight 50w? i cant find the straight 50 anywhere anyway.
motomotard is offline   Reply With Quote
Old 07-27-2008, 11:09 PM   #9
shortchop
shortchop's Avatar
Live in Vegas (super hot) 60w Amsoil synthetic.
shortchop is offline   Reply With Quote
Old 07-28-2008, 07:06 AM   #10
bustedlifter
Try NAPA.
Old 07-28-2008, 07:17 AM   #11
wayne dude
I have a 73 and 78 ,both with oil coolers and have run Valvoline 50w racing oil for the last 15 years with good results. And their both stroker motors.
wayne dude is offline   Reply With Quote
Old 07-28-2008, 07:30 AM   #12
bigassbike
you got your bike on the road?
Do you even have a bike?
bigassbike is offline   Reply With Quote
Old 07-28-2008, 07:31 AM   #13
Trent
Atomic Custom
Trent's Avatar
Send a message via Yahoo to Trent
Straight 60w Amsoil.
Atomic Trent
505-281-2520
Atomic Custom Website
https://atomiccustom.bigcartel.com
http://instagram.com/atomictrent/
"Custom parts are good only when they're cooler than factory parts. By cooler I mean have better lines, work better, etc."
Trent is offline   Reply With Quote
Old 07-28-2008, 07:35 AM   #14
TigerAlex
Drag Specialties 20W-50 in Northern Virginia in a 75 Shovel. Drag gets their oil from the same guys that supply Harley, or so I'm told. Same oil but 1-2 $ cheaper by the quart.
TigerAlex is offline   Reply With Quote
Old 07-28-2008, 07:46 AM   #15
Guy
Guy's Avatar
I've always run straight 50W (Pennzoil) in my shovels, and now the Pan. Getting hard to find here now ...
Guy is offline   Reply With Quote
Old 07-28-2008, 07:48 AM   #16
leadsled
leadsled's Avatar
I agree the drag specialties oil is just as good as the harley oil. I would stick to the 20w-50. I have been using that in my pan for the past 3 years. My thoughts on the full synthetic oils are concerning the inhibators. I can't explain to myself how the anti-foaming or moisture inhibators are different in the two types. As long as acid doesn't develope in the mineral oil the oil dosen't go bad, but the inhibators do.
leadsled is offline   Reply With Quote
Old 07-28-2008, 07:54 AM   #17
garagebuiltbob
garagebuiltbob's Avatar
60w valvoline racing oil...autozone.
garagebuiltbob is offline   Reply With Quote
Old 07-28-2008, 07:59 AM   #18
motomotard
motomotard's Avatar
yup yup yup. did the shake down this weekend. had a buddy lay it down, vibration broke the headlight mount off at 2 in the morning... all the usual.
Old 07-28-2008, 09:31 AM   #19
Nads
Straight 60 Kendall here in Florida.
There's a fine line between a Hog Member and a hog's member.
Nads is offline   Reply With Quote
Old 07-28-2008, 09:37 AM   #20
SuperMario
SuperMario's Avatar
I live in Md. Straight 70w in summer 60w fall&spring and 50w winter.
SuperMario is offline   Reply With Quote
