Thread Tools | Search this Thread | Display Modes |
#181 |
Tach Drive Plugs for unit Triumph Motorcycles
http://www.lowbrowcustoms.com/tach-d...torcycles.aspx These tach plugs let you remove the tach drive hanging off the front, left side of your unit Triumph engine and plug the hole with some class. For unit motors '63 & up. Available in Aluminum or Brass, as well as for Early motors ('63-'68) with the right hand threads, and Late motors ('69 & up) when Triumph changed the thread and went to a left hand thread. These are each individually hand-made.These tach plugs let you remove the tach drive hanging off the front, left side of your unit Triumph engine and plug the hole with some class. For unit motors '63 & up. Available in Aluminum or Brass, as well as for Early motors ('63-'68) with the right hand threads, and Late motors ('69 & up) when Triumph changed the thread and went to a left hand thread. These are each individually hand-made. $19 for Aluminum, $22 for Brass ![]() ![]()
#182 |
DiCE Magazine Issue 30
DiCE Issue 30 is now in stock and shipping out, get yours now, $8 http://www.lowbrowcustoms.com/motorc...er-2009-1.aspx
#183 |
Wassell 200 watt high output Stator and Wassell Rotor Combo
http://www.lowbrowcustoms.com/wassel...-norton-2.aspx Order a new Wassell Rotor and a 200 watt High Output Stator as a set and save $5. This will make your charging system operate way better than when it was new and stock! These 16 amp high output stators made by Wassell in the UK will fit your Triumph, BSA or Norton with a OEM Lucas stator. Stock is only 10 amp, these 16 amp stators produce up to 200 watts, which blows away the stock stators that produce maybe 100 - 120 watts. Replace your old, stock Lucas rotor with one of these new ones made by Wassell in the UK. Fits Triumph / BSA / Norton, check your parts book for fit, OEM #54202299. A good test to see if your rotor is junk is to take it off the bike, set it on the table and try and lift it with a large screwdriver. If it won't hang from a screwdriver then it needs to be replaced. This is a common problem with vintage motorcycle charging systems. The benefit to this mid-range upgrade is that you don't have to change anything else on your bike, this component will fit and wire like stock but with the added benefit of better charging and brighter lights. $198 ![]()
#184 |
Four Aces Cycle Bonneville Salt Support Shirt 2010
http://www.lowbrowcustoms.com/triump...ntities-1.aspx Lowbrow Customs is proud to present the Four Aces 2010 Bonneville Commemorative shirt. 100% of the proceeds from the sales from these t-shirts is used to support the Four Aces team to race their vintage Triumphs at Speedweek. The shirts are a natural unbleached cotton, and available in limited quantities, get one while they last. Get a super cool shirt and help support vintage Triumph racing at the same time! $18 each, sizes S - 3XL available ![]() ![]()
#185 |
Buy one of Wes' Bonneville shirts, while they last! Support vintage racing.
#186 |
Greasy Kulture Magazine Issue 13
GKM 13 just arrived yesterday, get yours here for only $8.50: http://www.lowbrowcustoms.com/motorc...ssue-12-1.aspx
#187 |
Sparx 220 watt High Output Rotor, Stator and Regulator for Triumph / BSA / Norton
http://www.lowbrowcustoms.com/sparx-...sa-norton.aspx This 220 watt kit from Sparx includes an 18 amp, 220 watt stator, a new Sparx rotor, Sparx Regulator, and a pair of NGK 5k ohm resistor spark plug caps (necessary when running this high output charging system). This effectively doubles the output of your stock charging system, perfect for great charging, bright lights, and you can even run a halogen headlight with this setup. $289
#188 |
Narrow Alien Chopper Motorcycle Gas Tank
http://www.lowbrowcustoms.com/narrow...-gas-tank.aspx These 2.1 gallon gas tanks are top quality, nice thick steel with an offset American style filler bung that accepts any stock cam-style filler cap. 1/4" dual petcock bungs at the rear. Mounting tab front and rear that is undrilled, drill for mounting to your custom application. $129 ![]() ![]()
#189 |
got my 4 aces shirt and my Isle of man shirt, great quality, thanks Tyler!
And thanks for the swag, lovin it.. |
#190 |
Shovelhead Motor Workshirt
http://www.lowbrowcustoms.com/triump...ork-shirt.aspx A classy t-shirt with a cutaway view of a Shovelhead motor. These brand new, short-sleeve workshirts have the cutaway Shovelhead engine on the back, and small motor and wording on the left chest above the pocket. They have two buttoning pockets on the front. 65% poly / 35% cotton blend. $30 ![]()
#191 |
Triumph TT Style Exhaust Pipes
http://www.lowbrowcustoms.com/triump...ust-pipes.aspx These brand new Triumph TT exhaust pipes are 1-3/4" OD throughout and fit over the exhaust head spigots on your pre unit or unit Triumph motorcycle. These are really nice in that they have threaded bungs welded on (before the beautiful chrome of course!) so you can use your stock style exhaust stays that bolt on to your case to nicely mount these (exhaust stays not included). Both pipes tuck underneath frame, great for your chopper, cafe or race bike. Made In England. $179 ![]()
#192 |
BUMP... I am about to order in a batch of Akront Morad rims from overseas for some friends, order goes in tomorrow, if you want any PM or email me right away. Price will be approximately $175 per rim drilled to your spec (I need to know what year, model etc of bike hub it needs to be drilled for), plus shipping from me to you. Price can vary slightly based on int'l air shipping and currency exchange rates. Anyway, if you want one get a hold of me pronto
#193 |
Finned Aluminum Magneto Cover by Goodson - Hunt / Morris
http://www.lowbrowcustoms.com/triump...nt-morris.aspx Back in stock after a year! We have a new small batch of these killer aluminum magneto covers by Dennis Goodson, get one while they last. These peaked, aluminum magneto covers are hand made by Dennis at Goodson in small batches. They fit all Fairbanks Morse bodied magnetos, such as Joe Hunt and Morris Magnetos, from old cast bodies up to the new CNC'd ones. They are polished, cast aluminum, and the inside of the cover is sealed with high heat powdercoating. They include a high quality cork gasket, four stainless screws for installing the cover, and a new set of terminals for the ends of your plug wires, as well as installation instructions. This is for the cover only, it does not include a magneto! $135 ![]()
#194 |
Sporty Sportster Chopper Motorcycle Gas Tank
http://www.lowbrowcustoms.com/sporty...-gas-tank.aspx These 2.5 gallon gas tanks are top quality, nice thick steel with a center mount American style filler bung that accepts stock style screw in filler cap. Single 13/16" petcock fitting, and a vent tube that is soldered shut. To run the vent tube just melt the solder out, though the gas cap bung is set up for a vented cap anyway. $129 ![]()
#195 |
Series 530 Chain - long 120 link for Chopper or Bobber hardtail motorcycle
http://www.lowbrowcustoms.com/triump...l-motorcy.aspx This is a good, dependable economy chain, series 530, that is 120 links. Great for any motorcycle that takes a series 530 chain. This chain is long enough for your hardtailed Triumph motorcycle with 4" of stretch to it or less. Not quite long enough for a 6" over Triumph hardtail. Simply install on your bike, cut down to necessary length and use the included master link to secure it. I have been running one of these chains for a few years with no trouble whatsoever, after the initial chain stretch and adjustment it has remained in great shape, offering flawless service. For a step-by-step tech article on shortening a chain for your bobber or chopper, check out the How To Shorten a Motorcycle Chain article in our Lowbrow Customs DIY Tech Section! $48
#196 |
Belmit Development Single Bolt Universal Glass Oil Filter
http://www.lowbrowcustoms.com/single...il-filter.aspx Mounting holes in top cap are tapped 5/16"-18 UNC thread. The lower cap has a very powerful rare earth magnet inserted to trap any steel or iron debris. Maximum diameter is about 3.25" and the overall length is about 6-1/4". Included is one Baldwin P1433 oil filter. This housing will also accept a Fram CH8765 filter or any oil filter that fits a 2000 Oldsmobile Intrigue. These filters are very common on many newer cars and should be easy to find come replacement time. $250 ![]()
#197 |
Triumph Upswept Drag Exhaust Pipes
http://www.lowbrowcustoms.com/triump...england-1.aspx These brand new Triumph drag pipes are 1.75" OD throughout and feature a front mounting tab. These are 'upswept' drag pipes as they have a slight bend in bottom run towards the rear of the pipe. It actually makes these pipes flow quite well with a hardtailed Triumph. Beautiful chrome, these pipes will slip right over your exhaust spigots and look great. Fits both pre unit and unit Triumph motorcycles. Why mess with old beat up exhaust pipes on your Triumph bobber or chopper? These are not some cheapo ones, they are made in England! $175 ![]()
#198 |
OOh! I should also mention that even though it took a month to get the oil tank from Lowbrow it was well worth it. It is excellent quality and came at a reasonable price.
I will definately buy from them again!
If crazy could pay the bills I'd never have to worry about money again. |
#199 |
what was the hold up? Tyler is usually really good about shit like shipping
if it ain't broke, fix it till it is! |
#200 |
The oil tanks are made to order, and there seemed to be a flood of oil tank orders so things got a little backed up, though are now back to normal! We stock everything on our site, it is all on the shelf aside from custom order items such as some of the fenders, oil tanks, frames and some magnetos. We usually ship orders within hours of them coming in!
Cheers Tyler |
| Display Modes | |
