replace EVO compensating sprocket with solid sprocket? - The Jockey Journal Board
Old 05-05-2008, 06:41 PM   #1
crebo
crebo's Avatar
Question replace EVO compensating sprocket with solid sprocket?
Found the following on the web:
"The compensating sprocket reduces the intensity of the power pulses thru the drivetrain. Putting on a solid sprocket is like switching to a belt drive, it will feel alot more "agressive" with no "give" to the driveline. if you don't mind that agressive feel, then have at it..."
has anyone done this on an EVO? if so what kind of sprocket did you use? would like to use standard HD clutch and primary chains...
thanks
"Don't cry because it's over, smile because it happened"
crebo is offline   Reply With Quote
Old 05-05-2008, 08:07 PM   #2
Nottso
Nottso's Avatar
Default Re: replace EVO compensating sprocket with solid sprocket?
I've never tried running a solid sprocket on an Evo. You might find this interesting. I think I'd try one of these if I needed to replace one, or of I was building fresh.
New type of compensator from BDL
BDL (Belt Drives Limited) recently came out with their own compensator for chain primary Harley's. It's about half the price of other stock-style compensator's, not to mention less than half the weight. After all, BDL has an excellent reputation and have been in the Harley drive business for quite a while.
Good that there is much less weight hanging on the end of the sprocket shaft, plus the weight is closer to the motor, since there's no spring cup. Plus it does away with the shaft extension, more weight loss.
So how does it work? Instead of stacked conical springs it uses Teflon washers, which it compresses under load. The hub, or "lead flange" is splined to fit the sprocket shaft and it's threaded on the outside to fit the inside threads of the sprocket.
It goes on the shaft first (after the spacer), followed by a Teflon washer, followed by the sprocket, then another Teflon washer, then the nut flange (also splined but not threaded) then the nut, tightened to stock torque.
Since the sprocket has right-hand threads, the motor tries to "tighten" the lead flange into the sprocket, compressing the inner Teflon washer. On rebound, the sprocket tries to unscrew, compressing the nut flange Teflon washer.
So is it as good as, better than or worse than the stock setup?
BDL must have road tested this thing, they went to all the trouble to machine the parts on a mass scale.
It lists for $83. That's about the price of just an OEM sprocket without the rest of the compensator.
Nottso is offline   Reply With Quote
Old 05-05-2008, 08:45 PM   #3
crebo
crebo's Avatar
good stuff! thanks for the info, I was looking at stock ones on ebay and they want good bucks for even a used one. BDL has a great rep from what I have seen, I'm going to look into this one, thanks again!
Old 05-05-2008, 09:03 PM   #4
bigassbike
have used a few of these for x-drive type softail conversions. but they were 1" offset to move the trans over and use a primary to engine case spacer. worked fine. they do list the first two without offset.
http://vulcanworks.net/Motor-Sprocke...0-p-1-c-6.html
Do you even have a bike?
bigassbike is offline   Reply With Quote
Old 05-05-2008, 09:51 PM   #5
Blue Collar Moto
Blue Collar Moto's Avatar
Why change? A comp sprocket is a good thing. Helps reduce chain stretch.
"Simplicity is the ultimate sophistication."
-Leonardo DaVinci
Blue Collar Moto is offline   Reply With Quote
Old 05-05-2008, 10:05 PM   #6
crebo
crebo's Avatar
not changing, I got nothing! ordered an inner primary case from egay that should be here in a few days and Nottso is sending me a clutch shell need to fill in the rest...
Old 05-05-2008, 10:06 PM   #7
crebo
crebo's Avatar
hmmm, that looks good too...
Old 05-05-2008, 10:21 PM   #8
crebo
crebo's Avatar
this one looks good too, and its only 20 bucks? looks like it will fit evo?
http://www.ridegear.com/rg/item/F-48...win-55-84.html
Old 05-05-2008, 10:24 PM   #9
FlashMotorWorks
FlashMotorWorks's Avatar
Send a message via Yahoo to FlashMotorWorks
a compensator is much beter if your running a chain
FlashMotorWorks is offline   Reply With Quote
Old 05-05-2008, 10:26 PM   #10
crebo
crebo's Avatar
thinking of running just the sprocket in place of the compensator, guess I would still need spacer, shaft extension, nut etc...... was hoping someone had already done it so I can see an example.... thanks for the help, I need to think and research some... I think i like the original BDL post...
here is a description of the splined sprocket from ebay:
HARLEY 24 TOOTH ENGINE SPROCKET. FITS ALL 1955 UP BIG TWINS WITH SPLINED SHAFT. PANHEADS, SHOVELHEADS, AND EVO'S. DIRECT REPLACEMENT FOR STRAIGHT SPROCKETS OR REPLACE THAT EXPENSIVE JUNK COMPENSATOR WITH THIS STRAIGHT SPROCKET. BOLTS RIGHT ON IN PLACE OF THAT NOISY COMPENSATOR.
Old 05-06-2008, 10:07 AM   #11
crebo
crebo's Avatar
these guys had the bdl compensating sprocket for 68.95 with free shipping if your order is $99 or over, so I ordered it along with a mainshaft sprocket to get the free shipping. The more I read about the bdl the more I liked!
http://www.phatperformanceparts1.com...DL-COMPENSATOR
