Paint Question, removing clear-coat - The Jockey Journal Board
Old 04-16-2008, 07:46 AM   #1
JLeather
JLeather's Avatar
Default Paint Question, removing clear-coat
So, this is technically for my car, but I'm sure someone has this problem with their bike too. And since there are some awesome painters here I thought I'd ask. On my car the clearcoat is peeling off in some patches. I'd like to remove all the remaining clearcoat, wetsand the base coat, and re-clear it. Can that be done? What's the best way to remove clear coat without ruining the base coat? Could I just carefully sand it off?
JLeather is offline   Reply With Quote
Old 04-16-2008, 08:20 AM   #2
Jackster31
Default Re: Paint Question, removing clear-coat
That is about the only way you could do it safely.
Jackster31 is offline   Reply With Quote
Old 04-16-2008, 08:22 AM   #3
A-V
My opinion is that sand it, base coat it and paint it. Otherwise the new clear will just peel off after a few years...
A-V is offline   Reply With Quote
Old 04-16-2008, 10:32 AM   #4
Bozi
Bozi's Avatar
No you can not save the base. The clear (is it GM, Ford or Chryl?) depending on make either deterorates, or delaminateds. You can on most cafefully take a razor blade & get it off the remainder of top surfaces. Or just DA it with 220 then 320. The clear usually will only be bad on the top surfaces out to where panels bend down, side panels should be fine.
Ideally you need to remove clear, DA (sand) top panels, finish with 320 or 400 feather edging along where it rolls over to sides, prime top affected areas, resand, shoot whole car.
I was at Dealers for 15 years, did hundreds or the corsicas, Vans, s-10's, ford trucks , etc. under warranty. Some of the GM's would be peeling at less then a year. They where more peelers, fords as well, Chryl was more of a clear coat deterorated (cant spell) & turned to chauk.
PM me if you need help, Ill give you my number.
But, ya, no easy way out. If you sand basecoat at all, you need to rebase (if a metallic)
Jeff
Bozi is offline   Reply With Quote
Old 04-16-2008, 10:49 AM   #5
JLeather
JLeather's Avatar
You got a PM Jeff
Old 04-16-2008, 10:56 AM   #6
Jackster31
It can be done, but you really have to know what you're looking for when you sand it down. Plus- it's hella time consuming. Not really worth it IMHO.
Old 04-16-2008, 11:15 AM   #7
oilstainedjeans
oilstainedjeans's Avatar
Send a message via Yahoo to oilstainedjeans
same thing happened to my '65 Riviera, previous owner did a paint job and the clear coat started popping off, only solution I found was to block the whole car, and repaint, cause you don't know what the real reason why it's coming off, dust on the surface when it was cleared is a common issue,
Talk Shit Spit Blood
oilstainedjeans is offline   Reply With Quote
Old 04-16-2008, 05:21 PM   #8
mrwelbilt
Greetings, BOZI has pretty much hit the nail on the head with his info. The only thing I would add to stripping of the clear is to try preasure washing the old clear first and try catching an edge were it has already delammed. Many times you can blow of sheets of the old clear with high water preasure. Good luck , Mike
mrwelbilt is offline   Reply With Quote
Old 04-16-2008, 05:35 PM   #9
back yard bobbers
back yard bobbers's Avatar
I have the same prob on my 53 dodge I am going to use chemical paint stripper, and take her down to the steel.
back yard bobbers is offline   Reply With Quote
Old 04-16-2008, 06:16 PM   #10
chicagocody
chicagocody's Avatar
Send a message via AIM to chicagocody
ya bozi is dead on..the american car companies used a water based primer to get the epa out of there butts..but they never got the formula quite right... but on a good note they did know they were gunna lose some moeny with repaiting and having to pay out people so they just jacked up the prices a little..after convincing most of the people with those paint problems that it was acid rain or air pollution in thier area they really only had to repaint/ pay for about 10 % of the cars with that shitty primer so if you do have one of those models mentioned above... bring it down to bare metal get a nice 2k self etching primer and start over...ive stripped a complete 4 door car, roof to rockers with that problem with 2 razor blades (clear, base and primer)
Sooner will a camel pass through a needle's eye than a great man be "discovered" by an election.
chicagocody is offline   Reply With Quote
Old 04-16-2008, 09:45 PM   #11
JLeather
JLeather's Avatar
I'd bring it down to bare metal but there isn't any. It's a vette, fiberglass and such (actually SMC but who's counting). Not sure how to strip/prep a 'glass car. Gonna bug Bozi some more. Thanks for the feedback guys.
Old 04-17-2008, 06:23 AM   #12
mrwelbilt
Greetings, I have found that media blasting or soda blasting has the best results for stripping paint off vettes without severe damage to the gelcoat. Some chemical stripper attack the gelcoat . Good luck, Mike
