EVO Sportster cam install? - The Jockey Journal Board
Old 03-21-2008, 09:52 AM   #1
Trumposorousrex
Default EVO Sportster cam install?
I need to put the cams back in the converted 1200 evo sportster engine and I have never worked on a harley motor. has any one on here installed them. Or know where I can find out how? Thanks Matt
Trumposorousrex is offline   Reply With Quote
Old 03-21-2008, 10:18 AM   #2
TurboRoadster
TurboRoadster's Avatar
Default Re: EVO Sportster cam install?
yup, get yerself a manual, it will save you tons of searching for answers.
www.ConroePowderCoating.com
JJ member discounts 832-818-3905
Tim@ConroePowderCoating.com
Highway HorrorS cc
TurboRoadster is offline   Reply With Quote
Old 03-21-2008, 10:31 AM   #3
archemitis
archemitis's Avatar
if its 91 and later its too easy.
put them in untill all the marks line up, turn the motor over a couple times with the pushrods out, or collapsed to make sure they still all line up and your done. its not like the old ones with shims and all that craziness... but ya, get a manual.
archemitis is offline   Reply With Quote
Old 03-21-2008, 11:05 AM   #4
TwoWheelFiend
TwoWheelFiend's Avatar
its easy, but get a shop manual
you could probly go to a stealership and they'd photocopy it out of a book for you
Mother tested, daughter approved.
TwoWheelFiend is offline   Reply With Quote
Old 03-21-2008, 01:46 PM   #5
Trumposorousrex
Thanks, I'll give it a go and I will get the manual.
Old 03-21-2008, 02:10 PM   #6
WhiteFox
I used this post for my 2001. The manual was no help, it didn't even match the markings on the cams like the pic in this thread does. Thats how I found this post, because I couldn't figure the manual out, all I needed was the picture. It was easy to do, but getting the lifters up while installing the cams correctly was a pain in the ass.
http://xlforum.net/vbportal/forums/s...ht=cam+install
WhiteFox is offline   Reply With Quote
Old 03-21-2008, 02:12 PM   #7
bigdeze
bigdeze's Avatar
Good info here also.
http://www.nrhsperformance.com/tech_xlcaminstall.shtml
If you find yourself in a fair fight, your tactics suck!
http://www.myspace.com/bigdeze75
bigdeze is offline   Reply With Quote
Old 03-21-2008, 02:30 PM   #8
Trumposorousrex
WhiteFox, That's just what I needed thanks. I think you just saved me a bunch of time.
