Old 02-26-2008, 03:03 PM   #1
fuckwinter
fuckwinter's Avatar
Default pic request - just rattle can paint jobs
wondering if it would be beneficial to others as well to have a thread with rattle can jobs and maybe the paints used?
lookin to do some samples on my chop before getting it done by a pro. this will help with final decision.
fuckwinter is offline   Reply With Quote
Old 02-26-2008, 03:10 PM   #2
Flatironmike
Default Re: pic request - just rattle can paint jobs
Kinger in BBQ Black
visit: http://flatironmike.blogspot.com/
Flatironmike is offline   Reply With Quote
Old 02-26-2008, 03:12 PM   #3
Jackster31
Just a basic paint job with a few different cans of Duplicolor
Jackster31 is offline   Reply With Quote
Old 02-26-2008, 03:14 PM   #4
Fredo
I used the appliance paint rattle can. HArd as nails and wet sands nice and glassy. You have your choice of colors. Black, white or avacado for that "retro" look.
Fredo is offline   Reply With Quote
Old 02-26-2008, 05:24 PM   #5
gr8paradox
gr8paradox's Avatar
Rust-Oleum Satin Enamel. Not real hard, but easy to touch up. Has that old look if you ask me. Does not hold up to gas. Clear engine enamel and lots of wax on tank. The shamefull sales pitch. Tank decal from eDecals.com
gr8paradox is offline   Reply With Quote
Old 02-26-2008, 05:37 PM   #6
JustBurn
I rattle can everything. haha. Usually Orchard Supply Hardware satin black enamel, the cheap stuff in the big can. doesn't rust through like primer, and no need to primer.
Just make sure to sand well and get a good surface for the paint to lay flat on.
JustBurn is offline   Reply With Quote
Old 02-26-2008, 05:39 PM   #7
Brundlefly
Brundlefly's Avatar
Fredo, Don't forget "Harvest Gold" to complete the 70's collection.
Any self respecting biker that attends a "Biker Rally" that bans "Nips" has forfeited his "balls" as well.
-Dragon-
Brundlefly is offline   Reply With Quote
Old 02-26-2008, 05:46 PM   #8
RI t100r
RI t100r's Avatar
dupli color. too heavy on the clear it was my first time. but it has held up well.
- Skip
RI t100r is offline   Reply With Quote
Old 02-26-2008, 06:00 PM   #9
el krapp
Photobucket
Photobucket
Photobucket
Photobucket
el krapp is offline   Reply With Quote
Old 02-26-2008, 06:01 PM   #10
el krapp
this is how it looks today,but this tank will soon be nothing more than wallart, a certain member of this board is in the middle of taking me out of the rattlecan world, in spectacular fashion
Photobucket
Photobucket
love always
brian
Old 02-26-2008, 06:35 PM   #11
S.Krelborn
S.Krelborn's Avatar
duplicolr primer, paint, and clear. wet sanded, compunded, and buffed.
www.hatedoftheworld.com
S.Krelborn is offline   Reply With Quote
Old 02-26-2008, 06:51 PM   #12
hotsos
hotsos's Avatar
Here's mine, I painted with spray bomb and then did a number of things to age it like it was found in a burned up barn or something (after doing the two color job I sanded it, massaged in wood stain, buffed it off, put on black paint and whit paint, and buffed them as it dried, rubbed in lin seed oil, washed it with gas and oil) I'm doing something different now, but it looked kinda neat for the summer, everyone thought it was "real" patina.
hotsos is offline   Reply With Quote
Old 02-26-2008, 06:58 PM   #13
Tre900
Send a message via MSN to Tre900
S.Krelborn
WOW. I have to see this one again from a different angle!! Are you kidding me, that was from a rattle can? Nice work. That's inspiring.
Tre900
_
(_)=='(_)
Tre900 is offline   Reply With Quote
Old 02-26-2008, 08:11 PM   #14
S.Krelborn
S.Krelborn's Avatar
Originally Posted by Tre900 View Post
S.Krelborn
Old 02-26-2008, 08:15 PM   #15
Gazza
Gazza's Avatar
Duplicolor metal cast smoke and red over the metal cast base coat...
Gazza
Gazza is offline   Reply With Quote
Old 02-26-2008, 08:44 PM   #16
STANDARD
STANDARD's Avatar
dont tell anyone.....lol
STANDARD is offline   Reply With Quote
Old 02-26-2008, 09:32 PM   #17
hatch
hatch's Avatar
Henry Fords cars were originally painted with a brush, then hand rubbed. Later on, paint was wet sanded with gasoline before polishing. Rattle cans are actually very hi-tech. Or how about the guys painting their cars with rustoleum and a hi-density roller...then wet sanding and polishing. It works, I tried it on my deuce coupe.
WWW.GreasyKulture.com
(You know you need it!!!!)
hatch is offline   Reply With Quote
Old 02-26-2008, 09:48 PM   #18
governor
governor's Avatar
governor is offline   Reply With Quote
Old 02-26-2008, 09:57 PM   #19
VISHOUS
Krylon...
layed down several wet coats of red oxide than a couple light coats of the green than taped off the scallopps and painted them ivory.
Let it set up for a few hours than wet sanded everything with 400 grit until I got the effect I wanted... $17.00 best paint job I've ever had..
http://vishouscycle.blogspot.com/
VISHOUS is offline   Reply With Quote
Old 02-26-2008, 10:02 PM   #20
fivepointink
fivepointink's Avatar
el krapp, what color blue did you use on the "jesus died" tank? all these jobs look killer by the way!
i'll sleep when i'm dead
fivepointink is offline   Reply With Quote
