Tech. - How to use a file - The Jockey Journal Board
Go Back   The Jockey Journal Board > The Archives > Tech Archives
Old 12-18-2007, 01:15 PM   #1
Jive Ass'd Turkey
Default Tech. - How to use a file
Grinder this. Grinder that. Phooey.
Buy a good set of Nicholson files and put the grinder down if you'd like to put a really nice finish on something.
Understand that a file only cuts one way and that's usually forward. All that seesawing back and forth people do is bad and dulls your file. Clamp whatever you're working on down to something so you can apply firm pressure to it while filing. Hold the file with two hands; one on the handle and one at the other end. When filing tubing or round things slide the file across as well as forward to keep your round thing round. Files talk. If you're using one correctly it will say zzzzz, zzzzz, zzzzz like Fiscars scissors do. It will also FILE rather than gouge.
Think files are archaic? Go ask the best machinist you can find if he thinks so. He'll convince you otherwise.
Jive Ass'd Turkey is offline   Reply With Quote
Old 12-18-2007, 01:16 PM   #2
Big Nick
Big Nick's Avatar
Default Re: Tech. - How to use a file
very good point! I just started using files more and it makes a difference.
Big Nick is offline   Reply With Quote
Old 12-18-2007, 01:20 PM   #3
noodelz
noodelz's Avatar
I live by my files. Draw filing with a mill smooth file is the best way to keep something's shape and give a bitchin finish, I can actually feel the surface through my file and tell how good it is. The only thing better that that is surface grinding, but not everyone has access to a machine.
It's funny I see all these young apprentices going full bore with a grinder and fucking shit up. They all give me funny looks when I break out my files and blow them away.
Dragon
The problem stems from relying on internet opinions to frame your perspective and actions.
Just get out there and (buy bike, ride bike, re-engineer bike in garage etc..)
just DO IT.
Originally Posted by Dragon View Post
You know (these days), looking cool when parked has a much higher priority that actual useful function.
YOU NEED TO CHECK THIS OUT! I'M STRONGLY SUGGESTING IT! YOU'LL BE GLAD YOU DID....
http://lowsidemag.blogspot.com/
noodelz is offline   Reply With Quote
Old 12-18-2007, 01:21 PM   #4
NewYorkAndy
NewYorkAndy's Avatar
Send a message via AIM to NewYorkAndy
100% back this.
I took down the rib weld on my fender w/ a file and it came out dialed.
The control you get with a file is unreal.
I like to be able to control the amount of material removed w/ out looking down and going... oh, shit.
Big up to a good set of files and taking the time to use them.
NewYorkAndy is offline   Reply With Quote
Old 12-18-2007, 01:22 PM   #5
Dr. Benway
Moderator
Dr. Benway's Avatar
Yes to all this...I love my vixen file, I'm amazed at the nice gradual shaping you can do with it.
Old 12-18-2007, 01:23 PM   #6
Richie
Richie's Avatar
I love to file....
It drives me NUTS when the people I work with "see-saw" as you call it...
But they know everything so I just let them go...
Yeah, but no.
Richie is offline   Reply With Quote
Old 12-18-2007, 01:30 PM   #7
sickboi55
sickboi55's Avatar
some files do work back and forth.
sickboi55 is offline   Reply With Quote
Old 12-18-2007, 01:31 PM   #8
JasonMcElroy
JasonMcElroy's Avatar
I decked my '66 BSA cases last week with some Dykem and a nice chalked coarse file. . . perfectly fucking flat, and better yet, SQUARE with the crank axis.
Took WAY less time than making a fixture for the Bport.
jason
Old 12-18-2007, 01:31 PM   #9
scraper
scraper's Avatar
i only have a couple shitty old files i got at a yard sale for a buck. can someone post a link to a "set" that would be ideal for a backyard metal masher like me?
scraper is offline   Reply With Quote
Old 12-18-2007, 01:32 PM   #10
Big Nick
Big Nick's Avatar
Just as Jive Ass'd Turkey said
http://www.eastwoodco.com/shopping/p...icholson_files
Old 12-18-2007, 01:35 PM   #11
Dr. Benway
Moderator
Dr. Benway's Avatar
jason
What does the chalk do, keep it from loading up?
Old 12-18-2007, 01:44 PM   #12
RAZ
RAZ's Avatar
Don't forget a filecard to keep your files cleen.
Work out?? I don`t need to work out, I get
enough exercise just pushing my luck.
RAZ is offline   Reply With Quote
Old 12-18-2007, 01:46 PM   #13
scraper
scraper's Avatar
nice - thanks nick - im'ma forward that link right over to santa.
Old 12-18-2007, 01:47 PM   #14
sickboi55
sickboi55's Avatar
i think i may be wrong about some cutting both ways. tried to find some and no go
Old 12-18-2007, 01:51 PM   #15
Big Nick
Big Nick's Avatar
yup
Old 12-18-2007, 01:59 PM   #16
Dan
Dan's Avatar
having a proper handle on the file is huge help also, not trying to hang on to the tang...
can anyone list the uses for the different files, i.e. mill, bastard, vixen, etc...
Dan is offline   Reply With Quote
Old 12-18-2007, 02:05 PM   #17
hatchethairy
hatchethairy's Avatar
this is all news to me. thanks for the heads up. i find it funny though, cause i was just scoping out a set of files for christmas gift ideas....
hopefully the wife isn't a stupid whore and gets me what i suggested.
hatchethairy is offline   Reply With Quote
Old 12-18-2007, 02:09 PM   #18
HD48FL
Moderator
Definately essential tools!
Old 12-18-2007, 02:11 PM   #19
Big Nick
Big Nick's Avatar
Old 12-18-2007, 02:16 PM   #20
reid
reid's Avatar
File in one direction when working with steel and back and forth when working with aluminum. It will clean out the aluminum on the back stroke. Especially when using a fine file.
Ah.. OK, one more beer.
reid is offline   Reply With Quote
